Constant errors in logs while using timers
    Anytime there is a running timer I get these errors in the log:
    EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Mar-08 14:25:58 EasyTrigger DEBUG Device 321 string changed to 12:01
    Mar-08 14:25:58 HSTouch Server Debug 02:25:58:0365 ~ String change event, value is: 723
    Mar-08 14:25:58 HSTouch Server Debug 02:25:58:0365 ~ String change event for to string:12:01
    Mar-08 14:25:58 EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Mar-08 14:25:58 EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Mar-08 14:25:58 EasyTrigger DEBUG Device 321 value changed from 722 to 723
    Mar-08 14:25:58 HSTouch Server Debug 02:25:58:0195 ~ Value change ref:321 Address: NewVal: 723OldVal: 722
    Mar-08 14:25:57 EasyTrigger DEBUG Device 321 string changed to 12:00
    Mar-08 14:25:57 HSTouch Server Debug 02:25:57:2347 ~ String change event, value is: 722
    Mar-08 14:25:57 HSTouch Server Debug 02:25:57:2347 ~ String change event for to string:12:00
    Mar-08 14:25:57 EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Mar-08 14:25:57 EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Mar-08 14:25:57 EasyTrigger DEBUG Device 321 value changed from 721 to 722
    Mar-08 14:25:57 HSTouch Server Debug 02:25:57:2187 ~ Value change ref:321 Address: NewVal: 722OldVal: 721
    Mar-08 14:25:56 EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Mar-08 14:25:56 EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Mar-08 14:25:56 EasyTrigger DEBUG Device 321 value changed from 720 to 721
    Mar-08 14:25:56 HSTouch Server Debug 02:25:56:0174 ~ Value change ref:321 Address: NewVal: 721OldVal: 720
    Mar-08 14:25:55 EasyTrigger DEBUG Device 321 string changed to 11:59
    Mar-08 14:25:55 HSTouch Server Debug 02:25:55:4087 ~ String change event, value is: 720
    Mar-08 14:25:55 HSTouch Server Debug 02:25:55:4087 ~ String change event for to string:11:59
    Mar-08 14:25:55 HSTouch Server Debug 02:25:55:4087 ~ Value change ref:128 Address:F51A30F1-030 NewVal: 0OldVal: 0
    Mar-08 14:25:55 EasyTrigger DEBUG Device 321 string changed to 11:58
    Mar-08 14:25:55 HSTouch Server Debug 02:25:55:2325 ~ String change event, value is: 720
    Mar-08 14:25:55 HSTouch Server Debug 02:25:55:2325 ~ String change event for to string:11:58
    Mar-08 14:25:55 EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Mar-08 14:25:55 EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Mar-08 14:25:55 EasyTrigger DEBUG Device 321 value changed from 719 to 720
    Mar-08 14:25:55 HSTouch Server Debug 02:25:55:2155 ~ Value change ref:321 Address: NewVal: 720OldVal: 719
    Mar-08 14:25:54 EasyTrigger DEBUG Device 321 string changed to 11:57
    Mar-08 14:25:54 HSTouch Server Debug 02:25:54:0343 ~ String change event, value is: 719
    Mar-08 14:25:54 HSTouch Server Debug 02:25:54:0343 ~ String change event for to string:11:57
    Mar-08 14:25:54 EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Mar-08 14:25:54 EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Mar-08 14:25:54 EasyTrigger DEBUG Device 321 value changed from 718 to 719
    Mar-08 14:25:54 HSTouch Server Debug 02:25:54:0143 ~ Value change ref:321 Address: NewVal: 719OldVal: 718
    Mar-08 14:25:53 EasyTrigger DEBUG Device 321 string changed to 11:56
    Mar-08 14:25:53 HSTouch Server Debug 02:25:53:2295 ~ String change event, value is: 718
    Mar-08 14:25:53 HSTouch Server Debug 02:25:53:2295 ~ String change event for to string:11:56
    Mar-08 14:25:53 EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Mar-08 14:25:53 EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Mar-08 14:25:53 EasyTrigger DEBUG Device 321 value changed from 717 to 718
    Mar-08 14:25:53 HSTouch Server Debug 02:25:53:2135 ~ Value change ref:321 Address: NewVal: 718OldVal: 717
    Mar-08 14:25:52 EasyTrigger DEBUG Device 321 string changed to 11:55
    Mar-08 14:25:52 HSTouch Server Debug 02:25:52:0284 ~ String change event, value is: 717
    Mar-08 14:25:52 HSTouch Server Debug 02:25:52:0284 ~ String change event for to string:11:55
    Mar-08 14:25:52 EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Mar-08 14:25:52 EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Mar-08 14:25:52 EasyTrigger DEBUG Device 321 value changed from 716 to 717
    Mar-08 14:25:52 HSTouch Server Debug 02:25:52:0124 ~ Value change ref:321 Address: NewVal: 717OldVal: 716
    Mar-08 14:25:51 EasyTrigger DEBUG Device 321 string changed to 11:54
    Mar-08 14:25:51 HSTouch Server Debug 02:25:51:2286 ~ String change event, value is: 716
    Current Date/Time: 3/8/2018 14:33:54
    HomeSeer Version: HS3 Standard Edition 3.0.0.368
    Operating System: Microsoft Windows 10 Pro - Work Station
    System Uptime: 0 Days 2 Hours 26 Minutes 20 Seconds
    IP Address: 192.168.1.144
    Number of Devices: 243
    Number of Events: 122
    Available Threads: 400
    Enabled Plug-Ins
    2.0.54.0: BLBackup
    2.0.76.0: BLLock
    3.0.0.43: EasyTrigger
    3.7.1.0: Harmony Hub
    3.6.203.3: HSBuddy
    0.0.0.38: Pushover 3P
    1.0.0.7: Restart
    3.0.5.7: SDJ-Health
    3.0.0.83: weatherXML
    3.0.1.190: Z-Wave
    I'm not using timers but receiving the same errors since updating to the latest version. I disabled the events that used the newer functionality with no change:
    Apr-20 9:42:58 AM EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Apr-20 9:42:58 AM EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Apr-20 9:42:58 AM EasyTrigger DEBUG Device 428 value changed from 618.48 to 643.68
    Apr-20 9:42:58 AM EasyTrigger DEBUG Device 434 value changed from 716.88 to 737.28
    Apr-20 9:42:55 AM EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Apr-20 9:42:55 AM EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Apr-20 9:42:55 AM EasyTrigger DEBUG Device 581 value changed from 114 to 124
    Apr-20 9:42:55 AM EasyTrigger DEBUG Device 581 string changed to 124 minutes
    Apr-20 9:42:54 AM EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Apr-20 9:42:54 AM EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Apr-20 9:42:54 AM EasyTrigger DEBUG Device 479 value changed from 967.92 to 1368.48
    Apr-20 9:42:52 AM EasyTrigger DEBUG Stack: at HSPI_EasyTrigger.EasyTriggerApp.HSEvent(HSEvent eventType, Object[] parms)
    Apr-20 9:42:52 AM EasyTrigger ERROR HSEvent callback. Object reference not set to an instance of an object.
    Apr-20 9:42:52 AM EasyTrigger DEBUG Device 581 value changed from 126 to 114
    Apr-20 9:42:52 AM EasyTrigger DEBUG Device 581 string changed to 114 minutes
      you probably have an event trigger that references a group which does not exist anymore.
      Please install and test version 3.0.0.47 available here which fix this problem and log a warning if such trigggers are detected.
      WARNING An event is referencing group X which does not exist
        Was a device group I made a change to one and it was being referenced by a disabled event
