Originally posted by racerfern
View Post
Discussions related to HS3 build 3.0.0.425
HSSentry is finally working as it should. It will restart HomeSeer after a couple of minutes, if it stops for any reason. When I am doing maintenance, I use task manager to stop the service.
Guest
Originally posted by racerfern View PostIt seems that if you purposely shutdown HS3 then that should be that, no? HSSentry should know the difference between being shutdown by clicking "X" on the HS3 screen and an abrupt end to the program.
Don't know if it it realated to .430 but alexa says '' sorry device x is not responding'' for all the hs3 device. and no action take place
But it responds ''ok '' and the actions occurs with the ''scene '' ( event from hs3)
Originally posted by racerfern View PostIt seems that if you purposely shutdown HS3 then that should be that, no? HSSentry should know the difference between being shutdown by clicking "X" on the HS3 screen and an abrupt end to the program.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by rjh View PostFYI, we are still fighting with issues with the Longitude change. It has been broken for a long time (-/+ backwards). But with the latest HS3 with it corrected, HSTouch weather screens have the incorrect weather. Hope to have a fix shortly.
Originally posted by Summerguy View PostDon't know if it it realated to .430 but alexa says '' sorry device x is not responding'' for all the hs3 device. and no action take place
I believe build 433 finally fixes the longitude setting issues. I tested it with the HSTouch weather screens, setting the value manually, and setting the value with the drop list. Also tested it with EU settings.
See later builds.
If you changed your longitude with any build after 425 you will need to go back into setup and reset it.
Note that the setting will be reversed if you check it in the settings.ini file, but HS fixes it when loads it. It has to stay reversed in the settings for HSTouch.Last edited by rjh; April 19, 2018, 09:06 PM.
Originally posted by rjh View PostI believe build 433 finally fixes the longitude setting issues. I tested it with the HSTouch weather screens, setting the value manually, and setting the value with the drop list. Also tested it with EU settings.
Build 433 for Windows is here:
https://homeseer.com/updates3/SetupHS3_3_0_0_433.msi
Linux builds are uploaded also, use SSH to update.
Thanks for sticking with this!cheeryfool
Guest
Originally posted by charlesmbell View Postyeah. 433 same alexa issue. looks like myhs not communicating with aws api. i get no errors in log, so not sure what info to provide.
I do not have the problem with imperihome, which communicate with myhs too.
So it has to be something else.
.433 here too
Originally posted by cheeryfool View PostYikes, not such a Quick Win after all. Are you going to tackle the settings.ini issue with a later update of HSTouch?
.425 was working w/alexa
I would provide logs but I get nothing. just voice error from amazon "sorry device is not responding"
alexa app shows "device not communicating"
but events called from alexa work just fine
Last one for today!
JSON was indeed broken in 432, this is now fixed. This affected Alexa and third party control.
Build 434 for Windows is here:
https://homeseer.com/updates3/SetupHS3_3_0_0_434.msi
Linux builds have also been uploaded.
