ISY Insteon 1.0.4.26
    #46
    Originally posted by bpwwer View Post
    Hi Todd,
    No, I haven't had any reports of problems with leak sensors. I do have one and I see some issues with status changes but HS is running so slow right now that I can't really debug it. I'm also seeing that the ISY is sending messages about the leak sensor that I haven't seen before so I need to see what UDI has added there.
    Thanks for reporting this.
    Bob
    I just saw this on the UDI forums http://forum.universal-devices.com/v...465a0fc0e3c353
    I wonder if it really is working mostly as designed. I am seeing messages about status change but when I put the sensor in a bit of water, it's in another room so by the time I get back to the computer and refresh the screen it may changed to wet and back to dry.
    Are you seeing the ISY reporting dry/off wet/on over a long enough period of time to refresh the HS status and see that they're out of sync?
    Have you tried setting up a homeseer event to trigger on a status change and see if the event does trigger?
    It may be a couple of days before I get a chance to run some tests and do some actual debugging with this.
    Bob Paauwe
    ISYInsteon Plug-in
      #47
      Originally posted by tmcgowan View Post
      Hello Bob,
      I've recently purchased a few of the Insteon Leak Sensors (Model 2852-222) and added them to my ISY99i interface. The devices show up in HS/2 okay, but when the status changes (simulated moisture on the sensors) they don't seem to register in HS even though the ISY sees them.
      Have you had any other reports of this type of problem?
      With version 1.0.4.15 that I just posted the leak sensors should report properly now. I had some special handling for certain sensors (motion and triggerlincs) but it looks like all the sensors in that class will need that same type of handling. This change should make the new door sensor report properly too along with any other new sensors like this that Smarthome comes out with.
      Bob Paauwe
      ISYInsteon Plug-in
        #48
        Delay Reaction Tiime?
        New to the plugin and to ISY994i/IR Pro. Just set my unit up and moved all my Insteon over to the unit. Also ordered the Z-Wave module that should be here soon.
        In the meantime I am trying to adjust a few Events I have in Homeseer as I have a number of three-way Z-Wave dimmer switches.
        I have a Hall Night Light Event that I created that triggers on us being Asleep, Hall Light Off, and Hall Motion On. The motion sensor is Insteon and now on the ISY. The Hall Light is a three-way Z-wave still on Homeseer.
        The event now is unstable and hits and misses on the motion sensor triggering? It use to almost instantly trigger the light when someone entered the all. Now it seems to hit and miss. Sometimes it takes up to 3 triggers of the Motion Sensor before the lights come on?
        Is this a nature delay due to Homeseer having to use the plugin to get the Motion Sensor status?
        Rich
        PS: I just danced up and down the hall and counted 8 flashes / triggers of the Motion Sensor before the lights finally came on?
          #49
          Welcome Rich!
          I have almost the same set up. I have an insteon motion sensor triggering a zwave switch. However, I currently have it all set up in the ISY as I do have the zwave module.
          So I just tried a test. I create a HomeSeer event to turn on other (insteon) lights when the motion sensor triggers. For me, it's working every time. There's a slight delay such that the insteon lights are coming on after the zwave lights, but not unexpected given that I'm triggering a scene and the additional network/processing it goes through.
          It should not be hit and miss. We need to do a little trouble shooting to figure where the problem is. And because it's a motion sensor, it may take a bit effort.
          First make sure the ISY is seeing the events from the sensor. You can do this by opening the event viewer from the ISY's admin console. It's under Tools -> Diagnostics ->Event viewer.
          Every time you trigger the motion sensor you should see a line in the event viewer like:
          Mon 12/16/2013 08:22:56 PM : [  23 18 84 1]      DON   1
          If that's happening reliably then we know that the ISY is seeing the events fine.
          Next, if you set the ISY plug-in's log level to "Status" (this is configurable on the ISY Plug-in Configuration page). Set the log level and save the configuration. You should then see corresponding events in the HomeSeer log.
          ISY Insteon  EVNT: Den/Den motion sensor-Sensor sent 1
          Event  Event Trigger "Den Motion"
          TTS  Speak ():Den Motion activated
          If your computer and the ISY have the same time, the timestamps between the event viewer and the HS log should be with a few seconds.
          Bob Paauwe
          ISYInsteon Plug-in
            #50
            I have Homeseer running on my Home Server. I noted that it was using "time.windows.com" as its NTP. I told it to update now and then I set the ISY unit to use the same NTP...
            My Event Trigger is set to:
            Monday to Sunday...
            Group 1
            Property Home We Are is ASLEEP Device: Property Home We Are is ASLEEP AND
            2nd Floor Hallway Light is OFF Device: 2nd Floor Hallway Light is OFF AND
            2nd Floor Motion Hall-Sensor is On Device: 2nd Floor Motion Hall-Sensor is On
            My Event Action reads like this:
            2nd Floor Hallway Light Dim to 8%
            1st Floor Stair Way and Front Entry Light Dim to 10%
            2nd Floor Hallway Light Off Delay: 00:00:35
            1st Floor Stair Way and Front Entry Light Off Delay: 00:00:35
            Triggered the motion sensor again. This time about 31 seconds later the light came on.
            Here is the Event Viewer from ISY:
            Mon 12/16/2013 09:38:12 PM : [ 14 BE FF 1] DON 1
            Mon 12/16/2013 09:38:12 PM : [ 14 BE FF 1] ST 255
            Mon 12/16/2013 09:38:42 PM : [ 14 BE FF 1] DOF 1
            Mon 12/16/2013 09:38:42 PM : [ 14 BE FF 1] ST 0
            Here is the Log from HS:
            12/16/2013 9:37:45 PM ISY Insteon EVNT: ISY Heartbeat message.
            12/16/2013 9:37:45 PM ISY Insteon EVNT: Event Queue is now empty.
            12/16/2013 9:38:05 PM Event Event Trigger "NetMon"
            12/16/2013 9:38:05 PM Event Running script in background: Jon00RCCNM_A.vben("network","")
            12/16/2013 9:38:05 PM HSTouch Server Debug 09:38:05:0836 ~ String change event for N2 to string: IP: 192.168.1.104 Online: 67 days 6 hrs 22 mins 54 secs Last offline: 10/10/2013 3:14:16 PM Ping1: 0 msec Ping2: 0 msec Ping3: 0 msec Last updated: 12/16/2013 9:38:05 PM
            12/16/2013 9:38:05 PM HSTouch Server Debug 09:38:05:0836 ~ String change event, value is: 1
            12/16/2013 9:38:05 PM HSTouch Server Debug 09:38:05:0992 ~ String change event for N1 to string: IP: 192.168.1.103 Online: 0 days 1 hr 39 mins 59 secs Last offline: 12/16/2013 7:57:07 PM Ping1: 1 msec Ping2: 1 msec Ping3: 1 msec Last updated: 12/16/2013 9:38:05 PM
            12/16/2013 9:38:05 PM HSTouch Server Debug 09:38:05:0992 ~ String change event, value is: 1
            12/16/2013 9:38:05 PM HSTouch Server Debug 09:38:05:1148 ~ String change event for N4 to string: IP: 192.168.1.100 Online: 13 days 3 hrs 56 mins 8 secs Last offline: 12/3/2013 5:40:59 PM Ping1: 0 msec Ping2: 0 msec Ping3: 0 msec Last updated: 12/16/2013 9:38:05 PM
            12/16/2013 9:38:05 PM HSTouch Server Debug 09:38:05:1148 ~ String change event, value is: 1
            12/16/2013 9:38:06 PM HSTouch Server Debug 09:38:06:4400 ~ String change event for N5 to string: IP: 192.168.1.165 Offline: 2 days 2 hrs 12 mins 16 secs Last online: 12/14/2013 7:21:49 PM Ping1: timed out Ping2: timed out Ping3: timed out Last updated: 12/16/2013 9:38:06 PM
            12/16/2013 9:38:06 PM HSTouch Server Debug 09:38:06:4400 ~ String change event, value is: 0
            12/16/2013 9:38:07 PM HSTouch Server Debug 09:38:07:9368 ~ String change event for N6 to string: IP: 192.168.1.110 Offline: 0 days 0 hrs 37 mins 59 secs Last online: 12/16/2013 8:25:07 PM Ping1: timed out Ping2: timed out Ping3: timed out Last updated: 12/16/2013 9:38:07 PM
            12/16/2013 9:38:07 PM HSTouch Server Debug 09:38:07:9368 ~ String change event, value is: 0
            12/16/2013 9:38:08 PM HSTouch Server Debug 09:38:08:0616 ~ String change event for N99 to string: IP: 8.8.8.8 Online: 4 days 19 hrs 11 mins 18 secs Last offline: 12/12/2013 2:19:53 AM Ping1: 33 msec Ping2: 34 msec Ping3: 34 msec Last updated: 12/16/2013 9:38:08 PM
            12/16/2013 9:38:08 PM HSTouch Server Debug 09:38:08:0616 ~ String change event, value is: 1
            12/16/2013 9:38:09 PM HSTouch Server Debug 09:38:09:4336 ~ String change event for N7 to string: IP: 192.168.1.166 Offline: 2 days 1 hr 48 mins 17 secs Last online: 12/14/2013 12:24:50 PM Ping1: timed out Ping2: timed out Ping3: timed out Last updated: 12/16/2013 9:38:09 PM
            12/16/2013 9:38:09 PM HSTouch Server Debug 09:38:09:4336 ~ String change event, value is: 0
            12/16/2013 9:38:10 PM ISY Insteon EVNT: ISY Heartbeat message.
            12/16/2013 9:38:10 PM ISY Insteon EVNT: Event Queue is now empty.
            12/16/2013 9:38:13 PM ISY Insteon EVNT: 2nd Floor/Motion Hall-Sensor sent 1
            12/16/2013 9:38:13 PM ISY Insteon EVNT: Event Queue is now empty.
            12/16/2013 9:38:13 PM ISY Insteon EVNT: 2nd Floor/Motion Hall-Sensor now set to 255
            12/16/2013 9:38:13 PM HSTouch Server Debug 09:38:13:5819 ~ Status change [16 Command: 2Level: 0 Status: Off
            12/16/2013 9:38:13 PM HSTouch Server Debug 09:38:13:5819 ~ Sending DEVICECHANGE notification to clients REF:3063 Cmd: 2 CAPI Stat: Off
            12/16/2013 9:38:13 PM HSTouch Server Debug 09:38:13:5819 ~ Status change [16 Command: 2Level: 255 Status: On
            12/16/2013 9:38:13 PM HSTouch Server Debug 09:38:13:5819 ~ Sending DEVICECHANGE notification to clients REF:3063 Cmd: 2 CAPI Stat: On
            12/16/2013 9:38:13 PM HSTouch Server Debug 09:38:13:5819 ~ Value change [16 NewVal: 255OldVal: 0
            12/16/2013 9:38:35 PM ISY Insteon EVNT: ISY Heartbeat message.
            12/16/2013 9:38:35 PM ISY Insteon EVNT: Event Queue is now empty.
            12/16/2013 9:38:43 PM ISY Insteon EVNT: 2nd Floor/Motion Hall-Sensor sent 1
            12/16/2013 9:38:43 PM ISY Insteon EVNT: 2nd Floor/Motion Hall-Sensor now set to 0
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Status change [16 Command: 3Level: 255 Status: On
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Sending DEVICECHANGE notification to clients REF:3063 Cmd: 3 CAPI Stat: On
            12/16/2013 9:38:43 PM Event Event Trigger "Night Light - Hall"
            12/16/2013 9:38:43 PM Device Control Device: 2nd Floor Hallway Light (Q5) Dim 8%
            12/16/2013 9:38:43 PM Device Control Device: 1st Floor Stair Way and Front Entry Light (Q1) Dim 10%
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Status change Q5 Command: 4Level: 8 Status: Dim 8%
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Sending DEVICECHANGE notification to clients REF:2881 Cmd: 4 CAPI Stat: Dim 8%
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Value change Q5 NewVal: 8OldVal: 0
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Status change Q1 Command: 4Level: 10 Status: Dim 10%
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Sending DEVICECHANGE notification to clients REF:1323 Cmd: 4 CAPI Stat: Dim 10%
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Value change Q1 NewVal: 10OldVal: 0
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Status change [16 Command: 3Level: 0 Status: Off
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Sending DEVICECHANGE notification to clients REF:3063 Cmd: 3 CAPI Stat: Off
            12/16/2013 9:38:43 PM HSTouch Server Debug 09:38:43:5215 ~ Value change [16 NewVal: 0OldVal: 255
            12/16/2013 9:38:43 PM ISY Insteon EVNT: Event Queue is now empty.
            12/16/2013 9:38:59 PM ISY Insteon EVNT: ISY Heartbeat message.
            12/16/2013 9:38:59 PM ISY Insteon EVNT: Event Queue is now empty.
            12/16/2013 9:39:05 PM Event Event Trigger "NetMon"
            12/16/2013 9:39:05 PM Event Running script in background: Jon00RCCNM_A.vben("network","")
            12/16/2013 9:39:05 PM HSTouch Server Debug 09:39:05:0768 ~ String change event for N2 to string: IP: 192.168.1.104 Online: 67 days 6 hrs 23 mins 54 secs Last offline: 10/10/2013 3:14:16 PM Ping1: 0 msec Ping2: 0 msec Ping3: 0 msec Last updated: 12/16/2013 9:39:05 PM
            12/16/2013 9:39:05 PM HSTouch Server Debug 09:39:05:0768 ~ String change event, value is: 1
            12/16/2013 9:39:05 PM HSTouch Server Debug 09:39:05:1079 ~ String change event for N1 to string: IP: 192.168.1.103 Online: 0 days 1 hr 40 mins 59 secs Last offline: 12/16/2013 7:57:07 PM Ping1: 1 msec Ping2: 1 msec Ping3: 1 msec Last updated: 12/16/2013 9:39:05 PM
            12/16/2013 9:39:05 PM HSTouch Server Debug 09:39:05:1079 ~ String change event, value is: 1
            12/16/2013 9:39:05 PM HSTouch Server Debug 09:39:05:1079 ~ String change event for N4 to string: IP: 192.168.1.100 Online: 13 days 3 hrs 57 mins 8 secs Last offline: 12/3/2013 5:40:59 PM Ping1: 0 msec Ping2: 0 msec Ping3: 0 msec Last updated: 12/16/2013 9:39:05 PM
            12/16/2013 9:39:06 PM HSTouch Server Debug 09:39:06:3241 ~ String change event for N5 to string: IP: 192.168.1.165 Offline: 2 days 2 hrs 13 mins 16 secs Last online: 12/14/2013 7:21:49 PM Ping1: timed out Ping2: timed out Ping3: timed out Last updated: 12/16/2013 9:39:06 PM
            12/16/2013 9:39:06 PM HSTouch Server Debug 09:39:06:3241 ~ String change event, value is: 0
            12/16/2013 9:39:07 PM HSTouch Server Debug 09:39:07:8209 ~ String change event for N6 to string: IP: 192.168.1.110 Offline: 0 days 0 hrs 38 mins 59 secs Last online: 12/16/2013 8:25:07 PM Ping1: timed out Ping2: timed out Ping3: timed out Last updated: 12/16/2013 9:39:07 PM
            12/16/2013 9:39:07 PM HSTouch Server Debug 09:39:07:8209 ~ String change event, value is: 0
            12/16/2013 9:39:07 PM HSTouch Server Debug 09:39:07:9456 ~ String change event for N99 to string: IP: 8.8.8.8 Online: 4 days 19 hrs 12 mins 17 secs Last offline: 12/12/2013 2:19:53 AM Ping1: 36 msec Ping2: 34 msec Ping3: 36 msec Last updated: 12/16/2013 9:39:07 PM
            12/16/2013 9:39:07 PM HSTouch Server Debug 09:39:07:9456 ~ String change event, value is: 1
            12/16/2013 9:39:09 PM HSTouch Server Debug 09:39:09:3176 ~ String change event for N7 to string: IP: 192.168.1.166 Offline: 2 days 1 hr 49 mins 17 secs Last online: 12/14/2013 12:24:50 PM Ping1: timed out Ping2: timed out Ping3: timed out Last updated: 12/16/2013 9:39:09 PM
            12/16/2013 9:39:09 PM HSTouch Server Debug 09:39:09:3176 ~ String change event, value is: 0
            12/16/2013 9:39:18 PM Event Event Trigger "Light (delayed action)"
            12/16/2013 9:39:18 PM Device Control Device: 2nd Floor Hallway Light (Q5) OFF
            12/16/2013 9:39:18 PM Event Deleting event after run: "Delayed Actions Light (delayed action)"
            12/16/2013 9:39:18 PM HSTouch Server Debug 09:39:18:0674 ~ Status change Q5 Command: 3Level: 0 Status: Off
            12/16/2013 9:39:18 PM HSTouch Server Debug 09:39:18:0674 ~ Sending DEVICECHANGE notification to clients REF:2881 Cmd: 3 CAPI Stat: Off
            12/16/2013 9:39:18 PM HSTouch Server Debug 09:39:18:0674 ~ Value change Q5 NewVal: 0OldVal: 8
            12/16/2013 9:39:18 PM Event Event Trigger "Light (delayed action)-1"
            12/16/2013 9:39:18 PM Device Control Device: 1st Floor Stair Way and Front Entry Light (Q1) OFF
            12/16/2013 9:39:18 PM Event Deleting event after run: "Delayed Actions Light (delayed action)-1"
            12/16/2013 9:39:18 PM HSTouch Server Debug 09:39:18:0674 ~ Status change Q1 Command: 3Level: 0 Status: Off
            12/16/2013 9:39:18 PM HSTouch Server Debug 09:39:18:0674 ~ Sending DEVICECHANGE notification to clients REF:1323 Cmd: 3 CAPI Stat: Off
            12/16/2013 9:39:18 PM HSTouch Server Debug 09:39:18:0674 ~ Value change Q1 NewVal: 0OldVal: 10
            12/16/2013 9:39:24 PM ISY Insteon EVNT: ISY Heartbeat message.
            12/16/2013 9:39:24 PM ISY Insteon EVNT: Event Queue is now empty.
              #51
              The good news is that both the ISY and the plug-in seem to be catching the events. The timestamps are within 1 second for both the on and off events from the motion sensor.
              Monday to Sunday...
              Group 1
              If I'm reading this right, you have a "Condition" event. The trigger type is set to "Condition" and you define three conditions that have to be met. Is that right?
              I believe that HomeSeer checks condition at a fixed period, something like 30 or 60 seconds. So that may explain the behavior.
              I would suggest you change the trigger to be an ISY Sensor trigger and have it fire the event when the motion sensor sends an ON. You can still set conditions on the event for the hallway light being off and the asleep is true.
              I think what you have now is something like:
              every 60 seconds check
                  if we are ASLEEP   AND
                  if 2nd floor hallway light is off   AND
                  if 2nd floor motion sensor is on  THEN
                  Turn on lights for 35 seconds
              What you want is:
              when 2nd floor motion sensor sends ON
                  if 2nd floor hallway light is off   THEN
                  Turn on the lights for 35 seconds
              Bob Paauwe
              ISYInsteon Plug-in
                #52
                Hi Bob...
                First... A real big thanks for the support and really fast response and all the hard work on this plugin!!
                OK You stated:
                I was unaware of this!! Wow, this little bit of knowledge was worth all the trouble!!!
                OK I did as you suggested and sure enough it was an almost instantaneous response!!!! I'm on my computer in the office and the hall is right out the door. So I am able to walk backwards out the door and hit start on the stopwatch the minute the ON shows on the ISY Motion Hall-Sensor window... This time it happened so fast I didn't have to bother...
                Here's the supporting data for other to reference as well, I highlighted the Motion times in RED.
                I am adding another question for you that I was not seeing yesterday that has to do with the Insteon Thermostat 2441TH. I highlighted these in BLUE.
                Made the change you suggested, re-synced the clocks,...
                ISY Event Viewer:
                Tue 12/17/2013 10:06:04 PM : [ 14 BE FF 1] DON 1
                Tue 12/17/2013 10:06:04 PM : [ 14 BE FF 1] ST 255
                Tue 12/17/2013 10:06:34 PM : [ 14 BE FF 1] DOF 1
                Tue 12/17/2013 10:06:34 PM : [ 14 BE FF 1] ST 0
                Homeseer Log:
                12/17/2013 10:06:04 PM ISY Insteon EVNT: 2nd Floor/Motion Hall-Sensor sent 1
                12/17/2013 10:06:04 PM Event Event Trigger "Night Light - Hall"
                12/17/2013 10:06:04 PM Device Control Device: 2nd Floor Hallway Light (Q5) Dim 8%
                12/17/2013 10:06:04 PM Device Control Device: 1st Floor Stair Way and Front Entry Light (Q1) Dim 10%
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Status change Q5 Command: 4Level: 8 Status: Dim 8%
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Sending DEVICECHANGE notification to clients REF:2881 Cmd: 4 CAPI Stat: Dim 8%
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Value change Q5 NewVal: 8OldVal: 0
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Status change Q1 Command: 4Level: 10 Status: Dim 10%
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Sending DEVICECHANGE notification to clients REF:1323 Cmd: 4 CAPI Stat: Dim 10%
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Value change Q1 NewVal: 10OldVal: 0
                12/17/2013 10:06:04 PM ISY Insteon EVNT: 2nd Floor/Motion Hall-Sensor now set to 255
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Status change [16 Command: 2Level: 0 Status: Off
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Sending DEVICECHANGE notification to clients REF:3063 Cmd: 2 CAPI Stat: Off
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Status change [16 Command: 2Level: 255 Status: On
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Sending DEVICECHANGE notification to clients REF:3063 Cmd: 2 CAPI Stat: On
                12/17/2013 10:06:04 PM HSTouch Server Debug 10:06:04:3282 ~ Value change [16 NewVal: 255OldVal: 0
                12/17/2013 10:06:04 PM ISY Insteon EVNT: Event Queue is now empty.
                12/17/2013 10:06:13 PM HSTouch Server Debug 10:06:13:3833 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                12/17/2013 10:06:13 PM HSTouch Server Debug 10:06:13:3833 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                12/17/2013 10:06:16 PM ISY Insteon EVNT: ISY Heartbeat message.
                12/17/2013 10:06:16 PM ISY Insteon EVNT: Event Queue is now empty.
                12/17/2013 10:06:28 PM HSTouch Server Debug 10:06:28:3515 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                12/17/2013 10:06:28 PM HSTouch Server Debug 10:06:28:3515 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                12/17/2013 10:06:34 PM ISY Insteon EVNT: 2nd Floor/Motion Hall-Sensor sent 1
                12/17/2013 10:06:34 PM ISY Insteon EVNT: 2nd Floor/Motion Hall-Sensor now set to 0
                12/17/2013 10:06:34 PM HSTouch Server Debug 10:06:34:2577 ~ Status change [16 Command: 3Level: 255 Status: On
                12/17/2013 10:06:34 PM HSTouch Server Debug 10:06:34:2577 ~ Sending DEVICECHANGE notification to clients REF:3063 Cmd: 3 CAPI Stat: On
                12/17/2013 10:06:34 PM HSTouch Server Debug 10:06:34:2577 ~ Status change [16 Command: 3Level: 0 Status: Off
                12/17/2013 10:06:34 PM HSTouch Server Debug 10:06:34:2577 ~ Sending DEVICECHANGE notification to clients REF:3063 Cmd: 3 CAPI Stat: Off
                12/17/2013 10:06:34 PM HSTouch Server Debug 10:06:34:2577 ~ Value change [16 NewVal: 0OldVal: 255
                12/17/2013 10:06:34 PM ISY Insteon EVNT: Event Queue is now empty.
                12/17/2013 10:06:39 PM Event Event Trigger "Light (delayed action)"
                12/17/2013 10:06:39 PM Device Control Device: 2nd Floor Hallway Light (Q5) OFF
                12/17/2013 10:06:39 PM Event Deleting event after run: "Delayed Actions Light (delayed action)"
                12/17/2013 10:06:39 PM HSTouch Server Debug 10:06:39:0575 ~ Status change Q5 Command: 3Level: 0 Status: Off
                12/17/2013 10:06:39 PM HSTouch Server Debug 10:06:39:0575 ~ Sending DEVICECHANGE notification to clients REF:2881 Cmd: 3 CAPI Stat: Off
                12/17/2013 10:06:39 PM HSTouch Server Debug 10:06:39:0575 ~ Value change Q5 NewVal: 0OldVal: 8
                12/17/2013 10:06:39 PM Event Event Trigger "Light (delayed action)-1"
                12/17/2013 10:06:39 PM Device Control Device: 1st Floor Stair Way and Front Entry Light (Q1) OFF
                12/17/2013 10:06:39 PM Event Deleting event after run: "Delayed Actions Light (delayed action)-1"
                12/17/2013 10:06:39 PM HSTouch Server Debug 10:06:39:0575 ~ Status change Q1 Command: 3Level: 0 Status: Off
                12/17/2013 10:06:39 PM HSTouch Server Debug 10:06:39:0575 ~ Sending DEVICECHANGE notification to clients REF:1323 Cmd: 3 CAPI Stat: Off
                12/17/2013 10:06:39 PM HSTouch Server Debug 10:06:39:0575 ~ Value change Q1 NewVal: 0OldVal: 10
                12/17/2013 10:06:41 PM ISY Insteon EVNT: ISY Heartbeat message.
                12/17/2013 10:06:41 PM ISY Insteon EVNT: Event Queue is now empty.
                12/17/2013 10:06:43 PM HSTouch Server Debug 10:06:43:3118 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                12/17/2013 10:06:43 PM HSTouch Server Debug 10:06:43:3118 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                12/17/2013 10:06:58 PM Event Event Trigger "NetMon"
                12/17/2013 10:06:58 PM Event Running script in background: Jon00RCCNM_A.vben("network","")
                12/17/2013 10:06:58 PM HSTouch Server Debug 10:06:58:0696 ~ String change event for N2 to string: IP: 192.168.1.104 Online: 68 days 6 hrs 51 mins 47 secs Last offline: 10/10/2013 3:14:16 PM Ping1: 0 msec Ping2: 0 msec Ping3: 0 msec Last updated: 12/17/2013 10:06:58 PM
                12/17/2013 10:06:58 PM HSTouch Server Debug 10:06:58:0696 ~ String change event, value is: 1
                12/17/2013 10:06:58 PM HSTouch Server Debug 10:06:58:0852 ~ String change event for N1 to string: IP: 192.168.1.103 Online: 0 days 0 hrs 5 mins 0 secs Last offline: 12/17/2013 6:15:59 PM Ping1: 1 msec Ping2: 1 msec Ping3: 1 msec Last updated: 12/17/2013 10:06:58 PM
                12/17/2013 10:06:58 PM HSTouch Server Debug 10:06:58:0852 ~ String change event, value is: 1
                12/17/2013 10:06:58 PM HSTouch Server Debug 10:06:58:1007 ~ String change event for N4 to string: IP: 192.168.1.100 Online: 14 days 4 hrs 25 mins 1 sec Last offline: 12/3/2013 5:40:59 PM Ping1: 0 msec Ping2: 0 msec Ping3: 0 msec Last updated: 12/17/2013 10:06:58 PM
                12/17/2013 10:06:58 PM HSTouch Server Debug 10:06:58:1007 ~ String change event, value is: 1
                12/17/2013 10:06:58 PM HSTouch Server Debug 10:06:58:2722 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                12/17/2013 10:06:58 PM HSTouch Server Debug 10:06:58:2722 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                12/17/2013 10:06:59 PM HSTouch Server Debug 10:06:59:3640 ~ String change event for N5 to string: IP: 192.168.1.165 Offline: 3 days 2 hrs 41 mins 9 secs Last online: 12/14/2013 7:21:49 PM Ping1: timed out Ping2: timed out Ping3: timed out Last updated: 12/17/2013 10:06:59 PM
                12/17/2013 10:06:59 PM HSTouch Server Debug 10:06:59:3640 ~ String change event, value is: 0
                12/17/2013 10:07:00 PM HSTouch Server Debug 10:07:00:8454 ~ Status change N6 Command: 3Level: 0 Status: IP: 192.168.1.110Online: 0 days 0 hrs 8 mins 0 secsLast offline: 12/17/2013 9:57:00 PMPing1:1msecPing2:2msecPing3:1msecLast updated: 12/17/2013 10:05:59 PM
                12/17/2013 10:07:00 PM HSTouch Server Debug 10:07:00:8610 ~ Sending DEVICECHANGE notification to clients REF:3136 Cmd: 3 CAPI Stat: IP: 192.168.1.110Online: 0 days 0 hrs 8 mins 0 secsLast offline: 12/17/2013 9:57:00 PMPing1:1msecPing2:2msecPing3:1msecLast updated: 12/17/2013 10:05:59 PM
                12/17/2013 10:07:00 PM HSTouch Server Debug 10:07:00:8610 ~ Value change N6 NewVal: 0OldVal: 1
                12/17/2013 10:07:00 PM HSTouch Server Debug 10:07:00:8610 ~ String change event for N6 to string: IP: 192.168.1.110 Offline: 0 days 0 hrs 0 mins 0 secs Last online: 12/17/2013 9:57:59 PM Ping1: timed out Ping2: timed out Ping3: timed out Last updated: 12/17/2013 10:07:00 PM
                12/17/2013 10:07:00 PM HSTouch Server Debug 10:07:00:8610 ~ String change event, value is: 0
                12/17/2013 10:07:00 PM HSTouch Server Debug 10:07:00:9857 ~ String change event for N99 to string: IP: 8.8.8.8 Online: 0 days 23 hrs 20 mins 54 secs Last offline: 12/16/2013 10:45:10 PM Ping1: 35 msec Ping2: 49 msec Ping3: 35 msec Last updated: 12/17/2013 10:07:00 PM
                12/17/2013 10:07:00 PM HSTouch Server Debug 10:07:00:9857 ~ String change event, value is: 1
                12/17/2013 10:07:02 PM HSTouch Server Debug 10:07:02:3434 ~ String change event for N7 to string: IP: 192.168.1.166 Offline: 3 days 2 hrs 17 mins 10 secs Last online: 12/14/2013 12:24:50 PM Ping1: timed out Ping2: timed out Ping3: timed out Last updated: 12/17/2013 10:07:02 PM
                12/17/2013 10:07:02 PM HSTouch Server Debug 10:07:02:3434 ~ String change event, value is: 0
                12/17/2013 10:07:06 PM ISY Insteon EVNT: ISY Heartbeat message.
                12/17/2013 10:07:06 PM ISY Insteon EVNT: Event Queue is now empty.
                12/17/2013 10:07:13 PM HSTouch Server Debug 10:07:13:2267 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                12/17/2013 10:07:13 PM HSTouch Server Debug 10:07:13:2267 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                12/17/2013 10:07:28 PM HSTouch Server Debug 10:07:28:2007 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                12/17/2013 10:07:28 PM HSTouch Server Debug 10:07:28:2007 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                12/17/2013 10:07:31 PM ISY Insteon EVNT: ISY Heartbeat message.
                12/17/2013 10:07:31 PM ISY Insteon EVNT: Event Queue is now empty.
                12/17/2013 10:07:43 PM HSTouch Server Debug 10:07:43:1688 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                12/17/2013 10:07:43 PM HSTouch Server Debug 10:07:43:1688 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                12/17/2013 10:07:57 PM ISY Insteon EVNT: ISY Heartbeat message.
                12/17/2013 10:07:57 PM ISY Insteon EVNT: Event Queue is now empty.
                  #53
                  Apparently these are some new thermostat API's that are undocumented. So the message is correct, they are not supported by the plug-in.
                  Searching the forum and HS docs has not provided any other details.
                  Bob Paauwe
                  ISYInsteon Plug-in
                    #54
                    Lost Communications Link With ISY
                    Hi Bob,
                    Seems I lost my link...
                    12/18/2013 12:47:59 AM ISY Insteon Syncing ISY Variables.
                    12/18/2013 12:47:59 AM ISY Insteon ISY Sync deleting variable TempHome
                    12/18/2013 12:47:59 AM ISY Insteon COMM: Failed to get response from ISY (The underlying connection was closed: A connection that was expected to be kept alive was closed by the server.).
                    12/18/2013 12:47:59 AM ISY Insteon COMM: - For command: []
                    12/18/2013 12:47:59 AM ISY Insteon COMM: - Using Authorization [Basic dXM2OkAkdHIwQnVyZw==]
                    12/18/2013 12:47:59 AM ISY Insteon COMM: ISY configuration query attempt 0 failed.
                    Will try a restart of HomeSeer...
                    That worked....
                    Rich
                      #55
                      OK last edit of this post for the night... got to get to sleep...
                      I'm not sure what is causing the Thermostat errors. They did not seem to be there when I posted the first logs having to do with the timing issue???
                      Seems that the Event option called "Thermostat Action" are NOT working, but the ISY Thermostat ones do... None of my Events using Thermostat Action worked, but when I changed them all to the ISY... version all work now. The "Thermostat Action" ones did not.
                      The "Thermostat Action" seems to be tied as well to the ISY Thermostat as it shows the thermostat as "1st Floor Thermostat - Main" and that matches the ISY Folder and name...
                      So I guess there are two ways with you plugin to control the Thermostat?
                        #56
                        Great Plugin.. Just Purchased and Registered...
                        Hi Bob,
                        Thanks for all the help. No need to wait for the Trial to run out, I've jumped in and purchased the plugin!
                        Still having issues with Thermostat WARNINGS...
                        12/19/2013 11:45:30 PM ISY Insteon EVNT: ISY Heartbeat message.
                        12/19/2013 11:45:30 PM ISY Insteon EVNT: Event Queue is now empty.
                        12/19/2013 11:45:35 PM HSTouch Server Debug 11:45:35:7312 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                        12/19/2013 11:45:35 PM HSTouch Server Debug 11:45:35:7312 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                        12/19/2013 11:45:50 PM HSTouch Server Debug 11:45:50:7332 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                        12/19/2013 11:45:50 PM HSTouch Server Debug 11:45:50:7332 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                        12/19/2013 11:45:56 PM ISY Insteon EVNT: ISY Heartbeat message.
                        12/19/2013 11:45:56 PM ISY Insteon EVNT: Event Queue is now empty.
                        12/19/2013 11:46:05 PM HSTouch Server Debug 11:46:05:7224 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                        12/19/2013 11:46:05 PM HSTouch Server Debug 11:46:05:7224 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                        12/19/2013 11:46:20 PM HSTouch Server Debug 11:46:20:7273 ~ WARNING accessing thermostat plugin CurrentFan, may not be supported ISY Insteon
                        12/19/2013 11:46:20 PM HSTouch Server Debug 11:46:20:7273 ~ WARNING accessing thermostat plugin IsOperating, may not be supported ISY Insteon
                        12/19/2013 11:46:21 PM ISY Insteon EVNT: ISY Heartbeat message.
                          #57
                          Hello!
                          I am unable to install this update.
                          It goes through and gets to the end, and stops says it can't find a file.
                          I have navigated to the location of where the file is located, and it won't finish.
                          Any ideas?
                          I did notice the older version had a setup.exe in the zip, this new one does not.
                          Thanks for your help,
                          Travis
                            #58
                            Hi Travis,
                            Sorry you're having problems.
                            Originally posted by thedishking View Post
                            Hello!
                            Any ideas?
                            What file does it say it can't find (or what's the location)? I think the only file that the installer needs is the isy_insteon.ini file located in the HomeSeer2/Config directory. I thought it was supposed to create that one if it doesn't exist.
                            According to HomeSeer, that was only needed for very old versions of windows.
                            Bob Paauwe
                            ISYInsteon Plug-in
                              #59
                              Hi Bob,
                              Here is the location:
                              C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Temporary Directory 1 for ISYInsteon-1.0.4.11.zip\
                              Thanks for your help!
                              Travis
                                #60
                                Travis,
                                It seems like the install package can't property run from where it got unzipped. I don't know why. What happens if you open the zip file and copy the .msi file to somewhere else (your documents folder or desktop) and then double click on the .msi file to do the install?
                                Maybe it has something to do with the account that's being used? Based on the path, it looks like you're running it as administrator so I wouldn't think you'd have permission problems.
                                Bob Paauwe
                                ISYInsteon Plug-in
