I'm reading over the plugin user guide which is posted but I'm confused as to what Global Cache hardware is needed with the plugin to be able to set an event that will fire off a series of IR commands such as, turn on tv, select input on AV receiver, etc?
The user guide mentions Is this hardware needed or can you just define a series of button press actions in an event using just the Global Cache IP2IR hardware?
