- This plug-in allows you to remotely monitor your security system: Zone Status, Area Status, etc.
- In HS3 each Zone as well as each Area is represented with a device
- The LCD status display is represented with a HS3 device
- Zones and Areas are updated dynamically
- The LCD status is updated through polling based on a user controlled timer
- With this plug-in you can send command to your system by simulating keypad key-presses
- Allows HomeSeer to request information on areas and to refresh the LCD status
