The other day I upgraded my HomeSeer Pi2 to a Pi3 and also upgrade to Raspian Jessie from Wheezy. The main reason was to have the system boot from hard drive instead of sd card. I used rsync to copy the working HS3 to the new Pi.
After a bit of a struggle I got it working except for the thermostats. I did lose all of the events I had which is disappointing.
I found the links concerning mono and did the compile of version 3.12.1. It seems ok. I also did the mozroot cert commands.
Dec-24 14:58:48
Honeywell WiFi Thermostat Failed to retrieve thermostat data - error occurred, will retry Dec-24 14:58:48 Honeywell WiFi Thermostat Error retrieving data for device 2XXXXXX: The request timed out
It shows that it is connected on the HS3 Webpage but I am sure it isn't.
I also see this in the log when starting HS3:
Dec-26 18:02:01 Error DeSerializing object (byte): Could not find type 'System.Collections.SortedList+KeyList'. Source=mscorlib
Any idea what to check next?
Steve
Dec-24 14:58:48
Steve
