UltraNetatmo3 (Netatmo Urban Weather Station) HSPI For HomeSeer3
    Description
    UltraNetatmo3 is a HomeSeer3 plug-in that allows you to use HomeSeer to track and monitor temperature, humidity, barometric pressure, rainfall, CO2 levels, noise level and weather alerts using the Netatmo Urban Weather Station.
    The Netatmo Urban Weather Station includes an indoor module that measures temperature, humidity, barometric pressure, CO2 levels, and noise levels inside your home. It also includes an outdoor module that measures outdoor temperature and humidity levels.
    The Netatmo Urban Weather Station also supports up to 3 optional indoor modules that measures temperature, humidity and CO2 levels and an optional rain gauge that measures rainfall.
    How It Works
    • UltraNetatmo3 HSPI queries the Netatmo Urban Weather Station API servers to obtain reading from your Netatmo Urban Weather Station.
    • UltraNetatmo3 HPSI automatically creates HomeSeer devices depending on which modules are connected.
    • Error Try/Catch logic to ensure plug-in doesn't fail with an unhandled exception.
    • Multiple threading allows UltraNetatmo3 to query the Netatmo API servers for station readings and weather alerts without disrupting the performance of HomeSeer.
    Example Usage
    • You can use HomeSeer to trigger events based on any number of environmental readings such as temperature, humidity, barometric pressure, rainfall, CO2 levels, noise levels, etc.
    Change Log
    Version 3.0.5368.34529 - Released Sept 14, 2014
    • Initial release
    Version 3.0.5468.36623 - Released Dec 21, 2014
    • Minor bug fixes.
    Version 3.0.5514.11670 - Released Feb 05, 2015
    • Fixed Co2 device not updating.
    Version 3.0.5579.17363 - Released Apr 11, 2015
    • Modified plug-in so Netatmo device properties are no longer reset.
    Version 3.0.5880.31182 - Released Jan 06, 2016
    • Modified plug-in to use api.netatmo.com instead of api.netatmo.net.
    Version 3.0.6139.30308 - Released Oct 22, 2016
    • Modified the program to use the new Netatmo API.
    • All unit conversions now use the user settings defined within the Netatmo application.
    • Added new temperature and pressure trend HomeSeer device.
    Version 3.0.6140.17903 - Released Oct 23, 2016
    • Added missing NNE wind direction in HomeSeer wind direction devices.
    Ultrajones
    Ultrajones
    Screen Shots
    [Screen Shots]
