Plug-in loses contact with PLM after few days
    In general the Insteon plug-in works well, but every few days the plug-in loses contact with the PLM. Every Insteon command that is send via Homeseer is then not executed, but the PI does not generate an error. So it appears tht everything is working well but in reality nothing moves.
    When I look into the log file it seems to start when the PI receives the message" ..did not receive a response from the PLM"
    I've attached the full log file.
    Jan
    i see you that you are using the hub. this is most likely a network connectivity issue. please try the following:
    -swap the ethernet cable connecting the hub to your switch
    -try a different port on the switch
    Mark
    HS3 Pro 4.2.19.5
