I also saw handles moving up slowly and moved to .387 but now now I cannot get it to start. The startup process gets about 3/4 of the way and sits for a while and then comes back with it shut down. Details give:
Problem signature:
Problem Event Name: APPCRASH
Application Name: HS3.exe
Application Version: 3.0.0.387
Application Timestamp: 5a134419
Fault Module Name: clr.dll
Fault Module Version: 4.7.2117.0
Fault Module Timestamp: 59cf5105
Exception Code: c00000fd
Exception Offset: 000187fa
OS Version: 6.3.9600.2.0.0.272.7
Locale ID: 1033
Additional Information 1: 1403
Additional Information 2: 1403c701083761d4e0bcdfb0e98a06e4
Additional Information 3: 9921
Additional Information 4: 9921e24fe9c708a7058981d0e16ee4a5
The handles for HS3.exe are still at about 108 when it crashes.
Also noticed this in the hs_sentry.log:
11/20/2017 9:19:08 PM:Error accessing web server: The operation has timed out
11/20/2017 9:21:08 PM:Error accessing web server: The operation has timed out
11/20/2017 9:23:08 PM:Error accessing web server: The operation has timed out
11/20/2017 9:25:08 PM:Error accessing web server: The operation has timed out
11/20/2017 9:27:08 PM:Error accessing web server: The operation has timed out
11/20/2017 9:28:16 PM:Error accessing web server: Unable to connect to the remote server
11/20/2017 9:28:37 PM:Error accessing web server: Unable to connect to the remote server
11/20/2017 9:28:37 PM:Cannot access HomeSeer, shutting down system and re-starting...
11/20/2017 9:28:42 PM:Starting the HomeSeer HS3 Application
11/20/2017 9:29:03 PM:Error accessing web server: Unable to connect to the remote server
Problem signature:
Locale ID: 1033
