Method 1 (BEST AND EASIEST)
That's it! The whole process should only take less than 5 minutes and when you start HSPRO, your existing devices, events and plug-ins should all work as before.
Method 2 (if method 1 does not work)
If your HS2 installation is in a bad state and Method 1 did not work, use this method instead.
- Back-up your entire HS2 folder
- Download the HSPRO "updater" from our downloads page
- Run the HSPRO updater. You'll receive a warning about upgrading the wrong version of the program. Ignore that and click through it.
- http://www.homeseer.com/downloads
- - Install this version changing the install location to your HomeSeer 2 directory (last location HomeSeer was installed to).
- - If you were running a HomeSeer beta update to the same beta from the HomeSeer message board
- - Copy over from you backup to the HomeSeer 2/config directory
- config directory - Settings.ini file
- config directory - config database - - Copy over from you backup to the HomeSeer 2/scripts directory
- Scripts directory - startup.txt - - License HomeSeer with your new HS Pro license.
