tenScripting Now Available for HS3
    An updated version of tenScripting is now available that runs under HS3.
    While there are several changes to the way tenScripting runs, all of the original functionality has been preserved.
    This is a beta, to go along with the beta status of HS3. Please provide feedback either to this forum thread, or on the web site.
    With the elimination of vbScript, more users will be coding .net scripts, so anything you can do to help me make tenScripting easier to use would be appreciated. Please send your comments.
    Download here: http://www.tenholder.net/tenWare2/te...3/default.aspx
    tenholde
    tenholde
    So awesome! Thanks.
    huggy_d1
    Automating made easy
      Thanks Ed.
      Don
        Awesome!
        Nicolai L
          Fantastic!
            Does this beta also run under HS2?
            Gary
              Any version above 3.0 will only run on HS2. So, no.
              tenholde
              tenholde
                I am sure Ed meant any version above 3 will only run on hs3.
                If you want to work with HS2 just use the current version 1.4.4.
                  That IS what Ed meant,
                  tenholde
                  tenholde
                    From one who always needs help -- THANKS
                      tenscripting doesnt see scheduler
                      i imported scheduler.dll in tenscripting but the program doesnt see it. windows 8 vs 2012 prof x64
                        Wow!
                        I downloaded v3.2 and had the same problems! It appears that the .zip archive was corrupted, as parts of the project are just missing!
                        Hopefully this has been corrected as v3.3 on the web site. I downloaded it and tested it and all appears okay.
                        Sorry for the inconvenience. Please try again and let me know what happens.
                        tenholde
                        tenholde
                          it works ok now smootly , thank you !!
                            hs3 log
                            minor problem
                              I am pretty sure that HS2 resized the log display to accommodate the size of the entries.
                              I changed the WriteLog calls to fit the fixed size field.
                              tenholde
                              tenholde
