Just bought a tesla model S. It rocks. I thought there would be some disappointment but there is none. Anyway, this truly seems like a car made for homeseer in my opinion. It has a streaming API location as other data can be gathered. I sense a plugin and if I had more programming knowledge I would develop one. Anyone else have one? I know they are expensive but they are worth every penny...
Tesla
Tesla
I've had it for over a week and the range is pretty accurate depending on what you base it on. With the 85 kw battery I get about 240 miles on a charge but I rarely use more than a hundred with my job. I have a nema 14-50 outlet installed in my garage which cost about $300 bucks to have installed but it charges at about 29 mi/hr.
I did get the tech and audio package. I didn't get the performance vehicle and I'm glad I didn't because this thing is plenty fast.
I've had a Tesla S Performance w/ 85kw battery since Thanksgiving. It is a wonderful car and lots of fun to drive. Acceleration and handling is fantastic and really surprises everyone who goes for a drive.
I have a VB script that I run under HS that accesses the Tesla REST API. I poll the car every 15 minutes (I could trigger the script more often, but I don't know what I'd use the data for) and grab the data and simply put it into monthly .CSV files and then use Excel to read the CSV and do graphs for charge state, etc. The attachment Tesla_Charge_Log_2013_06.pdf shows an example of a graph showing charge state and temperature. You can see how it maintains the battery charge. I also have some Excel VBA that takes the lat/long from the API and gets the address from Google maps so I can follow my trip.
I haven't seen the need for the Tesla Streaming API -- I'm the only driver & I know where I'm driving so the 15 minute samples from above are just fine.
The attachment HS_Daily_Summary_2013.pdf shows the details on power. I've got solar generation. I gather Solar from the sun via a Davis weather station, use a SMA device to get solar generation data, and a TED5000 to gather power statistics on house consumption & Tesla charge demand. This is all done via scripts grabbing the data with HTTP requests.
Last attachment is Tesla S Log Book.pdf is combination of manually recording data from Tesla Charge & Trip displays & combining it with TED5000 power data. Tesla shows you its figures on Battery to Wheel efficiency, but with real power data you can see Panel to Battery & Panel to Wheel efficiency. This is still somewhat manual as I haven't found all of the data in the Tesla API. [And yes, you'll note I had some issues with the car, but I knew I was going to be a beta tester -- Tesla has done a great job on service by timely responding to all issues. I still love the car and my brother bought one on my recommendation]
As for range, I count on 200 miles from a normal charge with normal freeway speeds of 70ish, AC or Heating as you desire. I've gone 225, but had do go lower speed to do that and it's no fun driving below 60.
The EPA rating of 265 is based on 55mph, flat land, ...Last edited by RBergquist; July 2, 2013, 01:52 AM. Reason: Added a picture of the Tesla S charging near Lake Tahoe
WOW what a pricetag on that thing..sweet though..
i drive a crew cab on 35's 60 miles each way to work then local kids sports.. i went through 8.5 gallons yesterday.. 6.3 just to-fro workHW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
$3.15 a gallon... yes gallon not litre over there!!!!
here is a pic.. http://www.supermotors.net/getfile/9...618_185611.jpg
Originally posted by wpiman View PostSend one to my house and I'll happily write you a plugin.HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Originally posted by prsmith777 View PostShweet !
Man I'd love to have one of these. My concern is living out in the boonies hours away from a major city. Baton Rouge is over 100 miles away and New Orleans is over 200 miles. What would I do for service?
Originally posted by jayman13 View PostCould you share your script?
Attached is a zip with the script, Excel spreadsheet, and sample generated .csv files. See readme.txt for some notes on setting it up
.Attached Files
Very nice car!
Yup here now it costs a bit under a $100 to fill up with gas in my area around $4 plus these days.- Pete
Tesla
Originally posted by RBergquist View PostAttached is a zip with the script, Excel spreadsheet, and sample generated .csv files. See readme.txt for some notes on setting it up
I live 175 miles from the nearest Service Center. When I had an early fatal failure, they picked it up and brought it to the Service Center & returned it to my house when it was fixed. I use their Anywhere [or some other marketing name] service option.
