Well I guess that just proved me wrong and HST right and you were right to question the accuracy of the data
I would personally suggest starting fresh, clear the Envi database in the way you say, stop the plugin, delete the cc.db3 file in the HS directory and then re-enable the plugin to create a new database. As I do a INSERT OR REPLACE SQL command then it does not delete anything if it is already in there (only replacing it) so when no new data comes in via the history output the existing data stays in there.
