mwolter - I found a severe bug in the 2.3.0 development code that causes crashing after about 60 seconds. I've fixed it (hopefully). To continue using the development code with this fix, run
npm -g update
I will run this 2.3.0 test version on my home system for a day or two to make sure it is stable. Assuming it is, I'll then publish it on npm, at which time, you should switch to the published version. To do that, all you need to do is:
npm -g uninstall homebridge-homeseer-plugin-2018
npm -g install homebridge-homeseer-plugin-2018
The first command will remove the 'git' development version. The second will then re-install from npm. This should be ready by Sunday for you to switch back to the 'regular' published package track.
As an FYI, once you are back to the 'regular' npm version, all you need to do for future updates is
npm -g update
npm -g update
npm -g update
