HS3 Linux Installation Instructions
This is a sticky topic.
    It's a PITA. I used screen pictures of my events.
    Auto mator
      Try long hand via the browser.
      Your old text file is at /HomeSeer/updater.txt
      There is a link in the text file updater.txt. Put it in your browser.
      See if that works.
      Auto mator
        HS3 linux won't start after 1st reboot
        Just did a reinstall of Debian and HS3 on my Raspberry Pi2 B+.
        It did successfully startup and run after installation.
        But on first reboot it didn't start as a HomeSeer.service like I configured.
        Then I tried the go script and got this message(would not startup).
        The assembly mscorlib.dll was not found or could not be loaded.
        It should have been installed in the `/usr/lib/mono/4.5/mscorlib.dll' directory.
        This directory appears empty???
        My Mono...
        mono --version
        Mono JIT compiler version 4.2.3 (Stable 4.2.3.4/832de4b Wed Mar 16 13:34:50 UTC 2016)
        Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-proj ect.com
          My Mono...
          mono --version
          Which sub commands did you install with mono? There should be two or 3 separate mono components that need to be installed.
            Solved startup problem
            Using this post https://forums.homeseer.com/showthread.php?t=186864 I had forgotten to create the systemd file as shown.
              Ok, so you got it working?
                HELP with Initial Seup of HS in Linux Debian 8
                I just installed in Debian 8.
                the ./go runs after su only and I need to remove sudo in the Mono line.
                I get a couple of errors. and I don't see any Plugins to download other than the HSTouch.
                Also I will like to auto start in case of power off, and I'm not a Linux guy, so som ehelp will be appreciated. I see some Scripts up there, but not sure where to put them or call them. I assume /etc/init.d/ and call xxx.sh ? IT measn if it is in the folder it will auto start?
                Here my Startup
                HomeSeer Linux starting...
                10:49:32:7682:[Database]->Opening (Mode=Read Only) up HomeSeer LOG database /HAL/HomeSeer/Logs/HomeSeerLog.hsd
                10:49:32:8279:[Startup]->Loading Settings
                10:49:32:8700:[Startup]->Settings Loaded.
                10:49:35:0035:[Startup]->
                10:49:35:0037:[Startup]->*********************************************************** *********************
                10:49:35:0042:[Startup]-> HomeSeer version 3.0.0.318 Edition: HS3 Pro Starting Now
                10:49:35:0044:[Startup]->*********************************************************** *********************
                10:49:35:0046:[Startup]->
                10:49:35:0185:[Startup]->Creating Class Objects...
                10:49:35:0197:[Startup]->COM port classes started.
                10:49:35:0221:[Startup]->Application interface class started.
                10:49:35:0261:[Startup]->Web server class started.
                10:49:35:0268:[Startup]->E-Mail SEND class started.
                10:49:35:0272:[Startup]->E-Mail RECEIVE class started.
                10:49:35:0299:[Startup]->Plug-In Interface class started.
                10:49:35:0310:[Startup]->Local voice recognition class started.
                10:49:35:0330:[Startup]->Database SAVE process started.
                10:49:35:0333:[Startup]->Loading configuration file ...
                10:49:35:0413:[Database]->Opening (Mode=Read Only) up HomeSeer database /HAL/HomeSeer/Data/HomeSeerData.hsd
                10:49:35:0643:[Database]->Loading Devices...
                10:49:35:0652:[Load Config]->2 total devices loaded.
                10:49:35:0669:[Load Config]->Loading Event Groups...
                10:49:35:0699:[Load Config]->Loading Events...
                10:49:35:0713:[Load Config]->0 total events loaded.
                10:49:35:0715:[Load Config]->Loading COUNTERS...
                10:49:35:0737:[Load Config]->Loading TIMERS...
                10:49:35:0792:[Startup]->HomeSeer version is: 3.0.0.318
                10:49:35:0794:[Startup]->Creating Speaker Client Interface Object...
                10:49:35:0805:[Startup]->This version of HomeSeer is registered as a HS3PRO version.
                10:49:35:0922:[Info]->Remote plug-in API interface started on port 10400
                10:49:35:0924:[Startup]->Checking for available plug-ins
                10:49:35:2984:[Plug-In]->Found plug-in: HSTouch Server, version: 3.0.0.68
                10:49:35:2998:[Startup]->Initializing Plug-Ins
                Plugin: HSTouch Server Instance: starting...
                Connecting to server at 127.0.0.1...
                10:49:35:5466:[Info]->Plugin HSTouch Server has connected. IP:127.0.0.1:57052
                Connected, waiting to be initialized...
                10:49:35:8140:[Plug-In]->Finished initializing plug-in HSTouch Server
                10:49:35:8228:[Web Server]->Local IP address is: 192.168.2.254
                10:49:35:8251:[Web Server]->Web Server started on port 80
                10:49:35:8254:[Web Server]->UPNP Discovery started
                10:49:35:8399:[Startup]->Start automation engine...
                10:49:35:8414:[Startup]->Initializing Speaker Client Interface
                10:49:35:8443:[Speech]->Listening for remote speaker connections on port 10401
                10:49:35:8482:[Database]->Opening (Mode=Read/Write) up HomeSeer Energy database /HAL/HomeSeer/Data/Energy/Energy.hsd
                10:49:35:9444:[Startup]->Updater services starting...
                10:49:35:9455:[Startup]->Starting DDNS service...
                10:49:35:9489:[Startup]->Running the startup script Startup.vb
                10:49:35:9587:[HSTouch Server]->Server started on port 10200
                10:49:36:1962:[Error]->Compiling script Startup.vb: Visual Basic.Net Compiler version 0.0.0.5943 (Mono 3.8 - tarball)
                Copyright (C) 2004-2010 Rolf Bjarne Kvinge. All rights reserved.
                vbnc : Command line : error VBNC2017: The library 'System.Data.DataSetExtensions.dll' could not be found.
                There were 1 errors and 0 warnings.
                Compilation took 00:00:00.1806940
                10:49:36:1966:[Startup]->Starting Event Scheduler...
                10:49:36:1976:[Startup]->HSSentry is disabled in Setup, sentry will not be started.
                10:49:36:1982:[Startup]->Start up complete.
                Type 'shutdown' to shutdown HomeSeer
                > 10:49:36:2950:[Info]->System connected to MyHS Service, waiting for acknowledge...
                10:49:36:3563:[Info]->System connected to MyHS Service successfully.
                10:49:36:4713:[Warning]->Dynamic DNS update failed. Invalid License ID or password. The password is CASE SENSITIVE.
                10:49:36:4715:[Warning]->The update process has been suspended until the configuration in setup is updated with the correct information.
                10:49:36:4717:[Warning]->To disable the update, remove your License ID from the Dynamic DNS setup.
                10:49:38:0379:[Web Server]->Web Server authorized local login successful from: 192.168.2.254 User: default
                updating devices
                updating devices
                  I just installed HS Linux version 3.0.0.318 and overall it started fine except for this :
                  In the logs :
                  May-26 3:08:21 PM Error
                  Compiling script Startup.vb: Visual Basic.Net Compiler version 0.0.0.5943 (Mono 3.8 - tarball) Copyright (C) 2004-2010 Rolf Bjarne Kvinge. All rights reserved. vbnc : Command line : error VBNC2017: The library 'System.Data.DataSetExtensions.dll' could not be found. There were 1 errors and 0 warnings. Compilation took 00:00:00.2045940
                  I don't know if it's related but I'm not able to expand the list of plugins when I go to
                  Plugins-> Manage -> Additional Interfaces and expand
                  I get this error message in the GUI interface :
                  Please wait for the updater control file failed to be downloaded or parsed.
                  This alone makes HS3 unusable for me as I cannot install any plugin...
                  Any pointers?
                    try this
                    mozroots --import --sync
                      Originally posted by jpsavaria View Post
                      In the logs :
                      Any pointers?
                      This sounds like an issue with you mono implementation. as it relates to the second problem you noted, the latest version of HS3 forces communication with the plugin update servers to be encrypted. this is more secure than it used to be. older versions of mono don't have a certificate store pre-loaded with trusted root or intermediate certficates. I beleive that the certificate management component was added to mono around about version 3.8, but some Linux distributions require you to add that component with a specific command switch. I have three questions:
                      1. Which version of Linux are you installing this on?
                      2. Also, which version of Mono are you running?
                      3. Lastly which options did you use to install Mono?
                        Originally posted by Pete View Post
                        Here running well too. Thank you Rich!
                        I noticed you LAN IP address is standard network address from your setup.
                        I'm running HS3 in a Docker Container but its picking up an IP address from what ever controls docker Ip address.
                        This stops me using MyHS :-(
                        Do you know how to get around this or have any hints?
                        David
                          Hello David,
                          Welcome to the Homeseer forum!
                          I have never used Docker here or MyHS here for my Homeseer machines.
                          Been using VPN for remote access to the home mothership (well and home network).
                          Utilize HS3 Designer for my Wintel touchscreens.
                          I am currently running Oracle Virtual Boxes on the main Homeseer in Ubuntu mothership.
                          The IP's / subnets of the VB's are totally different than the main Homeseer Mothership IP address. (DHCP).
                          Doing W7 virtual boxes and all the remote stuff works fine this way.
                          BTW you are the first person I have seen running (or trying) HS3 using Docker.
                          Auto mator
                            Since it is over a year ago I did some updating, I now want to update to the latest Linux HS3Pro version. Lost my notes on this so I am not sure how to do the update.
                            Just copy over the files? Or is there a more sophisticated way for this
                            Some things I already have / or did:
                            I have two options, using a command-line or webmin.
                            Already downloaded the latest files in
                            /downloads/hs3_linux_3_0_0_368.tar.gz and run tar to get it unpacked in /downloads/HomeSeer
                            Now what would be the next step? Copy over all the files to /user/local/HomeSeer ? But than all my other files are overwritten I guess? And I can start all over again?
                            Any advise on how to do this (manually) ?
                            My old files in /usr/local/HomeSeer
                              First Note: the as-is build of HomeSeer extracts to ./HomeSeer. When extracting, you should be in the directory above. In my case, that is /opt. In you case that appears to be /user/local.
                              I usually do something like this:
                              (download file)
                              cd /opt/download
                              wget https://homeseer.com/updates3/hs3_linux_3_0_0_383.tar.gz
                              Attach to screen and shutdown HomeSeer
                              screen -r
                              > shutdown
                              (create a current compressed tar file of HomeSeer directory for backup)
                              cd /opt
                              tar cvjf hs-20171119.tbz HomeSeer/
                              This will extract the update image on top of HomeSeer.
                              tar xf /opt/download/hs3_linux_3_0_0_383.tar.gz
                              Second NOTE: if you grab the install file it WILL overwrite your configuration. I've done this before. You need the file with a name similar to above.
                                @timmymac123 Thanks that helped me upgrading. Where are the "latest builds" announced since I did find: the hs3_linux_3_0_0_368.tar.gz as download and you mention hs3_linux_3_0_0_383.tar.gz
                                Do I need some more actions after updating (I did a reboot).
