Locks not showing up
    Do I need to change a setting somewhere to be able to see my Schlage lock?
    Coincidentally I was just trying this with my kwikset lock. I couldn't find it.
    I remember reading somewhere to change the 'control use' option under the advanced tab of the device to anything other than 'not specified'. I did that and it works now. Try it and see.
      I don't have an equivalent setting.
        It's under the Status Graphics tab of the lock's control child device.
        Cheers
        Al
          Cheers
          Al
          thanks for pointing out the right tab.
            I'm new, what does this allow you to do exactly? I don't really know what IFTTT does.
              IFTTT is a cloud based rules engine that allows you to integrate many disparate systems. From a HS3 perspective, it's a way to integrate systems with HS3 that don't have a plugin. Since it's cloud based, the integration breaks when your internet connection is down, but it still has its uses. Here's a full list of all the things that are currently supported by it: https://ifttt.com/search/services. The rules engine is pretty limited as it only allows triggers without any conditions.
              Cheers
              Al
