My HS3 ZEE was working fine until this morning when I added three new devices. Now remote access does not work, I get a connection failure message.
Assuming it's not simply the case that the server is down...
If I try to connect through myhs.homeseer.com with a browser on my PC, then I get an error that the it cannot create a connection to 127.0.0.1, which is obviously not the address for the device.
When I try to connect from my android phone I just get Connection Failed with Server.
I have restarted the HS3 Zee. It is running HS3 ZEE S2 Edition 3.0.0.297 (Linux).
Thanks in advance
Chris
Thanks in advance
Chris
