This stopped working for me a couple of days ago. Elliott
Is DropBox trigger working for anyone in IFTTT?
Originally posted by MrMxyzptlk View PostDropbox changed public folders to shared folders.
They have been emailing that the change was coming for months now.
The plugin will need updated or you need to change your public folder permissions."Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
So, IFTTT can't access the files unless I change the view permissions? I see the filse are uploaded when they should.
(Where do I do that?)HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Spud, we need help!HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
IFTTT does not pick up the changes, yes. The file is created just fine.
Dropbox did some changes to the "public" area, and I can't for the life of me figure out what I need to do to make IFTTT see the change.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
I tested with some old IFTTT applets and saw some strange things, but then I recreated 2 applets from scratch to test both public and private folders, and it seems to work.
I'm supposed to receive 2 SMS every 15 minutes and so far it has worked flawlessly
Try to recreate your applets from scratch, and maybe try to relink the Dropbox service in IFTTT
I still got nothing.
After some more tests here is what I found:
- IFTTT seems to check if there is a new file in your dropbox only every 15 minutes, so you have to wait at least 15 minutes before jumping to any conclusion
- Overwriting an existing file in your dropbox (or even uploading a file with a name that existed before but that you deleted) does not seem to work consistently. It worked for me yesterday, but it doesn't seem to work this morning.
So you need to make sure that the IFTTT plugin uses a different name each time by using advanced mode to provide a name for the file with a replacement variable that will change over time. I used $time in the example below but I think you could use a timer or a counter.
Let me know how it goes
Originally posted by spud View PostSo you need to make sure that the IFTTT plugin uses a different name each time by using advanced mode to provide a name for the file with a replacement variable that will change over time. I used $time in the example below but I think you could use a timer or a counter.
Can I use $date too? Some of my Events trigger at the same time every day.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Er.... spud?
I don't have any fields for entering the file name....?
My version os 3.0.1.2 and as far as I can tell, it's the latest version (and I couldn't find it in the beta section either).HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
