Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion > HAI/OMNI Panel for HS3 Plug-in (rmasonjr)
HAI/OMNI Panel for HS3 Plug-in (rmasonjr) Discussion about Rob Mason's HAI/OMNI Panel Plug-in
Old May 15th, 2018, 11:02 PM
amarch amarch is offline
Seer
connection Issue
i Tried what you suggested still no luck?
could it b a memory issue?, this omni system has a lot of switches, buttons, zones. could that be an issue?
Old May 16th, 2018, 09:41 AM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
OverSeer
In the other thread, the logs say it took roughly 3 mins to fully download all the panel info, but that is not out of the ordinary.
If the plugin is disconnecting, it could be network-related.
Is your panel plugged into a managed switch?
64 Z-Wave Nodes, 162 Events, 293 Devices
Old May 16th, 2018, 11:23 AM
Seer
I Tried moving it to different switches and even tried a router and still the same results
is there anyway we can talk?
Old May 16th, 2018, 02:12 PM
Seer
Connection Issue
is it possible that it takes 24hrs to retrieve the config from the controller?
that's a big problem. it finally connected after 24hrs
Old May 16th, 2018, 02:16 PM
rmasonjr's Avatar
OverSeer
No, it shouldnt take that long at all. Your 3min connection time was about the longest I have ever seen.
Tell me about your setup - are you using expansion panels? How many Areas/Zones/Units/Flags/Buttons, etc.
Old May 22nd, 2018, 10:28 AM
Seer
1 Area
20 Zones
98 Units
14 Buttons
2 thermostats
I tried on a smaller system and it connected no problem
Old May 22nd, 2018, 11:51 AM
cowsr4eating cowsr4eating is offline
Seer Plus
Don't know if this helps. I have a similarly large Onmi config.
I have the following and no connection issues. I'm running HS3 in a VM running Windows 10. Running 3.0.2.4 of plugin
1 Area
24 Zones
98 Units
28 Buttons
3 thermostats
Takes me almost 5 minutes to start:
May-22 10:48:12 AM OMNI ---------------------------
May-22 10:48:12 AM OMNI Plugin startup is complete.
May-22 10:48:12 AM OMNI Synchronization complete.
May-22 10:44:21 AM OMNI Synchronizing OMNI devices with HomeSeer...
May-22 10:44:21 AM OMNI Requesting initial system troubles
May-22 10:44:15 AM OMNI Requesting Output status...
May-22 10:44:14 AM OMNI Requesting Area status...
May-22 10:44:14 AM OMNI All configuration and properties retrieved.
May-22 10:44:13 AM OMNI -->Reading properties...
May-22 10:43:27 AM OMNI -->Reading configuration...
Old May 22nd, 2018, 11:59 AM
Seer
ok so your using a PC, I'm using this Home Seer Zee S2 which is a raspberry pie.
I'm wondering if this unit is the problem?
my issue with the connection, is that it restarts itself after completing its configuration.
Old May 22nd, 2018, 03:31 PM
Seer Plus
Could be an OS-specific issue, Linux vs. Windows. I moved to Linux, but had functionality issues specific to HS Touch. The Omni plugin (was HAI plugin at that time) worked fine on Linux as far as I could tell.
Would be an interesting data point to know the Omni Config size and plugin start time of Omni users with Linux on a PC and Linux on a Zee.
I'm on an older version of the plugin too. With all of the issues people have been reporting I have been afraid to upgrade.
Old May 22nd, 2018, 09:42 PM
Seer
I ran home seer on my pc with the Omni plug-in and it connected first time with no issues. so there is definitely an issue with the raspberry pie and large configurations.
the question now is what is the issue with the zee s2 processor power or storage space?
is there anyway to figure this out?
Old May 23rd, 2018, 10:21 AM
Pete's Avatar
Pete Pete is offline
OverSeer
There are known Omni network hardware issues which have been documented over the years.
Really though this relates to an early network transport communicating with the serial bus on the Omni Panel. It happens with an abundance of network devices on your home network and it is not related to the number of pieces of hardware or devices or automation lines used on the OmniPanel.
The fix is to install a router between the network port on the Omni Panel and the rest of your network. Initially here tested it with a Linksys WRT-54G with DD-WRT router. Later implemented a custom OS OpenWRT micro router which today is mounted inside of my Omni Pro media can.
The router "fix" has been done by a couple (or more) Homeseer Omni Plugin users which did have network issues and I believe today do not have any network issues.
Try it yourself.
To check on Utilization of an Homeseer Plugins in Linux just install and use HTop. You can break the view to seeing Homeseer console and each plugin autonomously.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.435
HTML code is On
Omni connection issue peterborg HAI/OMNI Panel for HS3 Plug-in (rmasonjr) 40 February 20th, 2018 04:53 PM
Connection issue Mario23 HSTouch™ 4 May 9th, 2012 09:08 PM
Connection issue proudme HSTouch™ 4 April 25th, 2011 03:09 PM
connection issue with 1.0.0.6??? Aquatic HSTouch™ 5 May 24th, 2009 08:04 PM
RG6 connection issue rknuppel General Home Automation Hardware Discussion 15 February 21st, 2006 04:38 PM
