On Vera I used Vera ALerts app to send messages to my Android tablets and samrt phones. On the corresponding Vera Alerts app I could then see all my Vera system related messages, I had it send me updates when my thermostat changed temperature settings, or when TRV's had commands to change and when they actually changed. I also made it send tts commands to my wall mounted tablets to let me know heating and AC status for example. This was a very useful tool. Is there a way of recreating something like that ?
Is there a Vera Alerts equivalent for HS ?
Push notifications. Does basically the same thing as vera alerts. http://forums.homeseer.com/showthread.php?t=163974
It doesn't do TTS though which vera alerts does. I use the Tasker plugin for TTS.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
I don't think there's a direct equivalent, but HSTouch is the way I do things like this. In the simplest form, you could set a device string to the alert message(s), and have a field in HSTouch display the string.
There are more elegant solutions as well, but require additional design effort. The attached image is the idle screen for one of my tablets. The box that says Door Open is a button. Pressing it will bring up a graphic that displays the status of all the doors. (If there are no doors open, the box is invisible.) The mailbox at the bottom indicates that the mail has been delivered. There is also a field that displays alert messages (it's transparent because there is no message to display).
For urgent messages, I send a text message to my phone.Mike____________________________________________________________ __________________
I remeber I think I was tinkering with Pushover on Vera too before switching to Vera Alerts. And I will also need the tasker plugin as I use tasker a lot on my phone and tablets. So that points me in the right direction, thanks
I do like the HSTouch idea, but I think that'll be further in the future for me after I get my whole system converted over. Still waiting for some vital hardware bits, so I made a start on everything non zwave (I havent got the zwave z net yet, its on order...)
Originally posted by mikee123 View PostI remeber I think I was tinkering with Pushover on Vera too before switching to Vera Alerts. And I will also need the tasker plugin as I use tasker a lot on my phone and tablets. So that points me in the right direction, thanks
Originally posted by mikee123 View PostOn Vera I used Vera ALerts app to send messages to my Android tablets and samrt phones. On the corresponding Vera Alerts app I could then see all my Vera system related messages, I had it send me updates when my thermostat changed temperature settings, or when TRV's had commands to change and when they actually changed. I also made it send tts commands to my wall mounted tablets to let me know heating and AC status for example. This was a very useful tool. Is there a way of recreating something like that ?
Whenever I want to send a "VeraAlert" message from Homeseer, In an event, I run a script which updates the text on the Multistring using Vera's HTTP commands, to the message I want to send. I have PLEG code which monitors the Multistring text, and when it changes (or not blank) will send a VeraAlart, the message being the Multistring text. So far it has worked quickly and flawlessly for months. With only those 3 devices, the Vera is actually very responsive and stable now. <sarcastic grin>
I've recently added a line at the end of the HS script to also have it log all messages to the HS log. I've used a message type of "VeraAlert" so I can easily find all alerts sent if I want to review them.
Originally posted by b_weijenberg View PostThe RFXCOM plug-in has an option to send Notify My Android (NMA) messages on warnings and alarm conditions.
See page 8 in the RFXCOM HS3 User Guide.
