When starting Z-Seer, I get a message that says "Unable to connect to HomeSeer, click OK to open the connection settings. This happens whether I run it on my HomeSeer computer or another computer on the network. On the HomeSeer computer, in the "Select System" dropdown, my HomeSeer IP address is listed but when I select it, I get the same error. On a different computer, I put in the IP of the HomeSeer system and I get that error. The message is very vague and doesn't give any information about WHY it's unable to connect.
I tried putting the .exe file in the HomeSeer HSPRO directory and in the HomeSeer directory. Neither one works. Now I get this error:
"Error initializing: Could not load file or assembly 'HomeSeerAPI, Version=1.0.2.1, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.Line: 0"
I'm not sure it's worth the trouble.
Odd....unless you are running Linux, that is the advice given by Rich (which works for me): https://forums.homeseer.com/showpost...&postcount=121
I put it in that directory and it's still not working. I'm not getting that long error though. I'm getting the "Unable to connect". I'm sure it's something simple but I sure don't see it. I've attached a document with some screenshots.
Maybe I'm not putting the right thing in the "Host Name / IP Address" field. I've tried just the IP, the IP with the port (81) and localhost. Nothing works.
Thanks for your help!Attached FilesLast edited by DC; October 3, 2017, 12:15 PM.
Guest
Check for current z-wave plug-in.
Make sure you are running the current z-wave plug-in.
I was having the same communication problem and tried moving the EXE file with no success.
I decided to go ahead and register the software even though it was not working. During registration, I got a message telling me to update the plug-in. I found that I was not running the current version, so I updated. (Actually, after the update, I accidentally uninstalled the plug-in, and had to add it back.)
In any case, after all this, Z-Seer+ communicates properly with HS3 even with the EXE file located in its normal location.
This may or may not be what others are experiencing, but it solved the problem for me.
Originally posted by Clement View PostI have the same problem even after following all the advice above. I have 3.0.1.87: Z-Wave version.
Same problem, Z-Seer cannot generate Map
I also have the same problem after purchasing and installing Z-Seer.
It geenrates only the Z_Wave interface along with its neighbors but log show:
Initializing connection to HomeSeer...
Cannot access HomeSeer: Object reference not set to an instance of an object.
Operating System: Microsoft Windows XP Professional - Work Station
System Uptime: 0 Days 1 Hour 34 Minutes 48 Seconds
IP Address: 192.168.1.145
Number of Devices: 309
Number of Events: 91
Available Threads: 200
Enabled Plug-Ins
3.0.0.29: ADIO-100
2.0.57.0: BLDSC
2.0.8.0: BLEmail
5.0.0.7: Global Cache
0.0.0.35: Pushover 3P
3.0.6132.16975: UltraGCIR3
3.0.0.36: X10
3.0.1.179: Z-Wave
