I've had this plugin for many years. I recently enabled it and saw calls from about two years ago on it.
I decided to reinstall it (not really removing anything) and just tested it.
I enabled debug and do not see any debug data from it. I also do not see anything in the reports from my testing for the last few minutes.
I have a W2C device configured on my line #1. I only utilize it for Steve's CID application along with using a netCID box on line #1.
I'm thinking maybe I changed something in the Homeseer phone settings such that I mucked up the BL Outgoingcalls set up.
Any suggestions to get this plugin working again?
The INI configuration file is:
Here are the HS log entries that I saw while dialing out just now. I have debug enabled in the plugin. Even though I have the DB functions off its still purging the DB (think its still there though). I guess it means that the plugin is doing something.
I remember many years ago switching to this plugin from Jim Doolittle's outgoing call plugin and wondering if I should go back to using it instead?
Its not like I really utilize it but like having some sort of log for outgoing calls.
[Settings]
debugLevel=true
loadSystemTrayIcon=false
helpFolder=/BLHelp/
sendToBLBroadcastClients=false
lastXOutgoingCallersNumber=10
lastOutgoingCallerDeviceCode=Y5
lastXOutgoingCallersDeviceCode=Y6
logToDatabase=false
daysToKeepCallLogs=365
debugLevel=true
helpFolder=/BLHelp/
logToDatabase=false
8/23/2012 9:18:26 AM - BLOutgoingCalls In - BLOutgoingCalls Auto Database Purge has started...
8/23/2012 9:18:26 AM - BLOutgoingCalls In - BLOutgoingCalls Auto Database Purge was successful!
8/23/2012 10:00:29 AM - Phone Line 1 - Clearing old Caller ID information
8/23/2012 10:00:48 AM - Phone Line 1 - Ignoring off hook due to incoming call
8/23/2012 10:01:18 AM - HSPhone - Muting rings disabled
8/23/2012 10:01:20 AM - Phone Line 1 - Internal answer is disabled, ignoring off-hook
8/23/2012 10:01:20 AM - HSPhone - Muting rings disabled
8/23/2012 10:03:14 AM - Phone Line 1 - Internal answer is disabled, ignoring off-hook
8/23/2012 10:03:41 AM - Event - Event Trigger "Message Off - Line 2"
8/23/2012 10:03:42 AM - HSPhone - Muting rings disabled
8/23/2012 10:03:42 AM - Phone Line 1 - Internal answer is disabled, ignoring off-hook
8/23/2012 10:03:43 AM - HSPhone - Muting rings disabled
