Most Insteon devices allows a user to set an X-10 address for that device. The X-10 settings will be saved as an internal setting of the device. This is a way to make it compatible with X-10. This worked very well with the HouseLinc software. Using the HouseLinc software I could set the X-10 address of my dimming module. With old X-10 software and an X-interface I could turn the device on/off/dim/status.
Where can I find the option in HS to set the X-address of an Insteon device?
