From what I've read, my wife's Nissan 2010 Cube's factory wireless tire pressure sensors operate at 315Mhz. It would be nice if I could have HomeSeer check the cold tire pressure in the early morning and alert me if her tires need some air before they reach the critically low level (at which point an indicator light flicks on in her car and she tells me about it).
Can RFXCOM read tire pressure using a RFXtrx315?
Also, similarly, I have Orange Electronic aftermarket tire pressure sensors on my vehicle which operate at 433.92Mhz. Can I read my vehicles tire pressure using RFXCOM and the RFXrec433 that I already own? Because it's aftermarket, my vehicle doesn't have a TPMS indicator light built in, and I don't often remember to check my tire pressure using their wireless reader. If I had HS checking it for me every morning, I could safely forget about checking it using their reader.
Originally posted by b_weijenberg View PostThe RFXCOM receivers are programmed to receive the indicated protocols. other protocols are not decoded by the RFXCOM.
The list of known protocols is in the RFXtrx User Guide (on the RFXCOM download page)
Originally posted by Wadenut View PostTire pressure monitoring systems are very short range anyway. The antenna would literally need to be within a very few feet of the tires.
I put my Orange TPMS receiver in the garage and hooked it to line voltage with a 12 volt adapter. It has no trouble reading and displaying all four of the vehicle tire pressures, even when the vehicle is parked in the driveway and not the garage. It does seem to collect and display the initial tire pressure readings faster when the vehicle is in the garage though.
I'm using HomeSeer to have it collect verifiably fresh readings early each morning when the tires are cold, and so at a glance I know my tire pressure readings before getting in the vehicle. I find this works faster and better than plugging in to the vehicle's cigarette lighter after the vehicle starts. i.e. if a tire is low, I want to know that before leaving (when I can easily add air) and not somewhere down the road.
It's not fancy, but it works. I'll need to find a different solution for my wife's vehicle, since she has no standalone TPMS reader like I do. I had hoped rfxtrx315 would have worked out for her case, but I'm not reading any enthusiasm here for that type of application.Last edited by NeverDie; October 7, 2013, 12:06 PM.
