HS3 Linux Installation Instructions
    Originally posted by ncherry View Post
    Sorry to poke my nose in here but the command above won't work. It needs an additional option (z to uncompress the gz file)
    tar zxvf hs3_linux_3_0_0_149.tar.gz
    Here's the results after I loaded up 149 on my system:
    HomeSeer Version:HS3 Standard Edition 3.0.0.149 (Linux)
    Most modern tar commands can pick out the compression format.
    Here, from a current Debian release:
    tmac@debian:~/Downloads$ tar tvf hs3_linux_3_0_0_149.tar.gz
    drwxr-xr-x root/root         0 2014-12-10 15:42 HomeSeer/
    drwxr-xr-x root/root         0 2014-11-21 11:42 HomeSeer/scripts/
    -rw-r--r-- root/root       228 2014-11-21 11:42 HomeSeer/scripts/ShutDown.txt
    -rwxr-xr-x root/root       934 2014-11-21 11:42 HomeSeer/scripts/Startup.vb
    -rwxr-xr-x root/root        36 2014-11-21 11:42 HomeSeer/install.sh
    drwxr-xr-x root/root         0 2014-11-21 11:42 HomeSeer/temp/
    -rwxr-xr-x root/root        14 2014-11-21 11:42 HomeSeer/run_command.sh
    TAR would imply the -j for bzip2, -J for xz, etc. It looks at the magic number of the compression format to figure it out and set it right.
      Cubox-i4Pro its working!
      Hey I got it working! I had to install debian jessie on the cubox so I could install Mono-complete. Mono was not available for Wheezy (ARM processor)
      I noticed that my trail License Trial with 7 days left
      I just installed it today I thought it should be 30 days?
      Any one know what could be the issue?
      I have weatherXML plugin working !
      Also My yahoo email is not working . SSl I believe is not working in Linux may be someone else can let me know if that is the case. pop.mail.yahoo.com Port 995
      Any ways still getting familiar with HS3
      HS2 Environment
      Zotac 1.83 GHz Quadcore
      HomeSeer Way2Call
      Netiom-Xap board
      opnode 1-wire 1.2.7
      Plug-In's
      WeatherXML 1.0.0.32
      Pwr Link USB 1.0.0.13
      mcsTemp V6.2.0.14
      mcsXap V3.0.0.0/3.0.0.20
      IM Connector 4.87.2.5
      Sip Connector 2.56.2.4
      RFXCOM 15.0.0.22
      Odroid X2
      Asterisk 11.5.1
      FreePBX 2.11.0.42
      WebMin 1.720
      Xap Switchboard by Mi4
      There is no place Like 127.0.0.1
        That's good news! I had weatherxml running on a pi, but it wouldn't serve up the weatherxml configuration pages. Are yours working?
        Sent from my SCH-R970X using Tapatalk
        HS4Pro on a Raspberry Pi4
        HSTouch Clients: 1 Android
          Yes the config pages work. PLUG-INS / WeatherXML drop down shows all the setup pages and they load fine .
          Had fun setting up the data. I had set to mysql thinking that I needed to but not necessary
          then were to see the weather forecast page its under users.
          I since setup a custom page under setup/ Web Site Settings.
          Custom Page 1 Title Weather
          Custom Page 1 URL http://192.168.x.x:9001/weatherXML
          Weather shows up under Views
          HS2 Environment
          HomeSeer Way2Call
          Netiom-Xap board
          opnode 1-wire 1.2.7
          Plug-In's
          WeatherXML 1.0.0.32
          mcsTemp V6.2.0.14
          RFXCOM 15.0.0.22
          Odroid X2
          Asterisk 11.5.1
          FreePBX 2.11.0.42
          WebMin 1.720
            Nice. I need to revisit this when I get time...
              Well this is great my trial never changes still has 7 days left. I guess I won't need a license? this is very weird. I will need to get this fixed.
              HS2 Environment
              HomeSeer Way2Call
              Netiom-Xap board
              opnode 1-wire 1.2.7
              Plug-In's
              WeatherXML 1.0.0.32
              mcsTemp V6.2.0.14
              RFXCOM 15.0.0.22
              Odroid X2
              Asterisk 11.5.1
              FreePBX 2.11.0.42
              WebMin 1.720
                Linux USB Sound
                Is there a way to get HS3 sound to work with a usb Sound stick? installed on the same linux box as HS3
                HS2 Environment
                HomeSeer Way2Call
                Netiom-Xap board
                opnode 1-wire 1.2.7
                Plug-In's
                WeatherXML 1.0.0.32
                mcsTemp V6.2.0.14
                RFXCOM 15.0.0.22
                Odroid X2
                Asterisk 11.5.1
                FreePBX 2.11.0.42
                WebMin 1.720
                  I recently installed HS3 on one of XBMC Buntu boxes and sound works just fine from the digital outputs and external USB sound dongles (with optical and analog stuff on it).
                  You cannot break anything goofing around with this.
                    Pete Nice to know, My Cubox-i4pro has dig audio but need to change it to the USB sound card and not having and luck getting it to change.
                    lsusb shows the USB sound card
                    alsamixer shows the Cubox Dig spdif as the default audio interface
                    I believe I need to change the default to my C-Media Headphone Set
                    I change it in alsmixer but it changes it back to the spdif.
                    Any Idea were I can update this?
                    My HS3 has no sound yet. Hope to here it speak soon.
                    HS2 Environment
                    HomeSeer Way2Call
                    Netiom-Xap board
                    opnode 1-wire 1.2.7
                    Plug-In's
                    WeatherXML 1.0.0.32
                    mcsTemp V6.2.0.14
                    RFXCOM 15.0.0.22
                    Odroid X2
                    Asterisk 11.5.1
                    FreePBX 2.11.0.42
                    WebMin 1.720
                      Where is Linux package for download?
                      Perhaps I'm missing the obvious, but where to I find for download the linux package? I have purchased an upgrade from HS2 to HS3 license and understand that this covers the Linux package as well. Please advise and thanks in advance.
                        +1
                        I remember being puzzled by this as well when I first went to look for the HS Linux download. There really should be a standard location to go to for getting the HS linux downloads (both current and prior versions), instead of the current way, which AFAIK is only through links posted by HST in forum announcements.
                        It's not my business, but if it were, I'd also have a bootable "live" distro (preferably one that boots from RAM, so that it's also fast) so people shopping for Home Automation could easily try HomeSeer3. That would allow potential users to quickly try HS3, with 100% zero risk to their existing computer setup, regardless of what software or OS they have.
                          Yeah, it's kind of difficult to find, but if you use this URL:
                          http://homeseer.com/updates3/hs3_linux_3_0_0_149.tar.gz
                          just replace the 149 with the next version number.
                          As of this writing, 152 is not available for Linux...
                            BTW, was there ever a .150 or .151 release? If not, it serves to underscore the value of having an actual download page that people can go to. Otherwise, it's just hard for anyone but die-hards to keep track of it all.
                              I'm not sure. I am on .125 (Linux) and I *really* need the new HSTouch plugin (.59), but it requires .147 and above of HS3.
                              I've been watching the latest beta threads and there are mixed reviews.
                                Hi Rich,
                                Where can I download the latest Linux version? I'm doing a fresh install.
                                JK
