Originally posted by TimeTempest
View Post
HS3 on Synology
Synology Docker
*** See https://forums.homeseer.com/showpost...3&postcount=27 for updated Docker Instructions ***
Ok so I'm new to HomeSeer. Trying to decide whether to run this of Synology or buy a HomeTroller. So I decided to make a docker image based on the latest beta with Debian Jessie running Mono 4. Here are the step I went through to make it work.
Install Docker from the Synology package centre and start the package
Then ssh into Synology using command:Code:ssh -p ‘SSH-PORT’ admin@’SYNO-IP’
Code:sudo -i
Then create the container with the following: (you may have to modify the ttyACM0 to something else if your z-wave stick appears as a different device on your server)(Feel free to change the port settings to suit your needs)
Code:docker run -d -p 2080:80 -p 10401:10401 -p 10400:10400 -p 10300:10300 -p 10200:10200 -p 11000:11000 --device=/dev/ttyACM0:/dev/ttyACM0 --name=Syno-HomeSeer fastfreddi/docker-homeseer
While still as root, create your script: (http://www.lagmonster.org/docs/vi.html for vi commands)
Code:vi /volume1/DockerAuto.sh
Code:case $1 in start) /var/packages/Docker/target/usr/bin/docker start Syno-HomeSeer ;; stop) /var/packages/Docker/target/usr/bin/docker stop Syno-HomeSeer ;; *) echo "Usages: $0 [start|stop]" ;; esac
Then run:Code:chmod 755 DockerAuto.sh
Create a schedules task called: Docker Start
Select user “root”
Choose event: Boot-up
Then in task settings, type: /volume1/DockerAuto.sh start
Create a schedules task called: Docker Stop
Select user “root”
Choose event: Shutdown
Then in task settings, type: /volume1/DockerAuto.sh stop
Enable both tasks and save settings.
Then reboot Synology DiskStation to ensure that image is functioning properly.
Go to address ‘SYNO-IP’:2080 to try the interface.
I am not very familiar with HomeSeer, so I would appreciate feedback with regard to anything that is non-functional in the image. Then I'll try to fix it. I am also new to Docker.Last edited by FastFreddi; March 19, 2017, 05:33 PM.
Sinology Docker Build Image
For those who would prefer to build their own image instead of downloading mine (fastfreddi/docker-homeseer).
This image was made with a Dockerfile containing:
Code:FROM docker/debian:latest RUN apt-get update && apt-get upgrade -y && apt-get install -y apt-utils && apt-get install -y mono-vbnc && apt-get update && apt-get install -y mono-vbnc && apt-get install -y libmono-system-web4.0.cil && apt-get install -y libmono-system-design4.0.cil && apt-get install -y libmono-system-web-extensions4.0-cil && apt-get install -y libmono-system-runtime-caching4.0-cil && apt-get install -y flite && apt-get install -y chromium && apt-get update && apt-get install -y chromium && apt-get install -y libmono-system-data-datasetextensions4.0-cil && apt-get install -y libmono-system-xml-linq4.0-cil && apt-get install -y sudo && apt-get install -y wget && wget http://homeseer.com/updates3/hs3_linux_3_0_0_291.tar.gz && tar xvf hs3_linux_3_0_0_291.tar.gz && rm hs3_linux_3_0_0_291.tar.gz CMD su root && cd /HomeSeer && ./go
Code:docker build -t docker-homeseer .
I will actually redo this container as the way I have it set up, HomeSeer is the long worker process, meaning that when HomeSeer shutdown, so does the container. This can cause issues if trying to make certain types of changes within the container. I will create a container where a bash shell will be the worker process and HomeSeer will start with a script.
Moving from WHS to Synology
Well I'm finally thinking about moving completely off my Windows Home Server over to my Synology DS1511+ and will need to do something about my HS3 installation on the WHS.
I have an the following interface Units:
- INSTEON 2413U USB Interface
- ISY-994i with the Z-Wave module
My list of Plugins include:
- EnvisaLink
- HSTouch Server
- ISYInsteon
- Nest
- UltraMon3
- UltraSMTP3
Looks like I have 4 USB ports on the back of the Synology unit so I should be able to plug in my 2413U and ISY-994i.
I'm going to read through this thread again, but what I'm looking for is anyone that has any updated step-by-step directions that could make all of this work.
It looks like a Synology App is being used to install a Linux Virtual Machine (VM) and somehow the USB "devices" are being made available to the Linux install. I may be reading this wrong, so when I get more time later today, I'll be back to read through the various posts again...
Rich
Great posts and thanks for the insight.
Is it fare to say that it is possible to run HS3 on Synology with a Homeseer Spartstick+ and have all the functionality that you can achieve on a HomeTroller? If so, any issues with Synology reboots?
I mention as I am looking at eliminating the dedicated hardware. Many thanks.
John
Docker Synology Update
Ok so I finally have an easy to apply solution to run HomeSeer on Docker in intel-based Synology. The first step is to ditch the Synology Docker package. Stop the package or better yet uninstall it. The you have to install an updated version of Docker (>1.12) to be able to use macvlan. An unofficial spk for manual install in package centre can be found here: https://drive.google.com/file/d/0B8M...ew?usp=sharing
Once installed, reboot your DiskStation and start the package.
Then ssh into your DiskStation
Code:ssh -p SSH-PORT admin@SYNO-IP
Code:sudo -i
Code:docker network create -d macvlan --subnet=10.0.3.0/24 \ --gateway=10.0.3.1 -o parent=eth0 pub_net
Code:docker run -it -d --net=pub_net --ip=10.0.3.2 --device=/dev/ttyACM0:/dev/ttyACM0 \ --name=Syno-HomeSeer --restart on-failure fastfreddi/ubuntu-baseimage-homeseer:latest
I think I remembered everything!
Also, if you would like a web interface to manage your Docker Containers, as you will no longer be able to use Synology's interface for this, you can try:
Code:docker run --name portainer -d -p 9000:9000 \ -v /var/run/docker.sock:/var/run/docker.sock \ -v /volume1/docker/portainer:/data \ --restart always portainer/portainer
To access and change things within the container:
Code:docker exec -it Syno-HomeSeer /bin/bash
Create a triggered task called: HomeSeer Start
Select user “root”
Then in task settings, type: docker start Syno-HomeSeer
Create a triggered task called: HomeSeer Stop
Select user “root”
Then in task settings, type: docker stop Syno-HomeSeer
Hope this helps. I'm still testing out this HomeSeer Container so let me know if anything is non-functional.
Hope this helps.
Originally posted by connoleg View PostThanks fastfreddi, this last part I couldn't get working, the container gets created but i can't access it from the browser...just times out.
If you SSH into your NAS as admin, then sudo -i, then docker ps, under ports, does it say: 0.0.0.0:9000->9000/tcp ?
