Just a note for others using this plugin..
I LOVE THE PLUGIN.. but i think i found an unintended issue/Feature... with the interaction between HS2Pro and this plugin
I had noticed when i installed this a year or so ago... that my log file quit rolling at midnight.. (used to have a new file each day... but with BLLogfilemonitor it kept growing.)
Not a problem.. .. so i thought...
But.. observation leads me to believe that HS doesn't like LARGE log files... when it got into the 10's of MB's.. i started getting some odd errors...
WebServer stopped... Zwave died.. etc..
Don't think it is a homeseer problem per se..... i think the log process would lock up and stall the machine and cause issues.
I was having to reboot about once or twice a day to get things back to normal..
Solution..
I deleted the log file .. (started fresh).. and it has run for 5 days without incident.
Long term solution (aside from switching to HS3)..
Made two events
11:59 PM
Execute immediate script
hs.Plugin("BLLogMonitor").DisableHSLogMonitoring()
12:01 AM
Execute Immediate Script
hs.Plugin("BLLogMonitor").EnableHSLogMonitoring()
I think this will allow the log to Rollover/Prune itself.
I had been fighting the random lockup/errors for a couple months now... and it kept getting more and more frequent..
Pruning the log file (startover with log file) seems to have fixed it for the last 5 days...
I'm thinking the log off/ log on will keep it from coming back.
Cheers
Solution..
Made two events
11:59 PM
12:01 AM
Cheers
