Upgrading Linux Install
    I have HS version 3.0.0.208 running on a Linux box and want to upgrade to version 3.0.0.239.
    I'm not very fluent in Linux and want to know the correct steps for performing the upgrade.
    Thanks for any help.
    Upgrades are fairly easy to do if you have a bit of Linux command line knowledge. At a high level, the procedure is download the Linux tarball and copy it to your Linux machine, shut down HomeSeer (either from command line or from the web interface), back up your HomeSeer directory, untar the HomeSeer tarball over the top of your previous version.
    Typically HomeSeer will be installed in /usr/local/HomeSeer. If you want to minimize the amount of command line activity, you can do most of these steps from Windows or Mac using a program such as FileZilla.
      239 Upgrade
      Selected shutdown, backed up etc...
      Opened tar into a folder called '239' then ran ./go from root
      First error was UPNP. Unchecked that from network area and tried again.
      Error now is: Error in DoReadDataTunnel: Object reference not set to an instance of an object
      WTF I guess I just wait until 239 moves out of beta - and I wait to use my Alexa.
        Uh oh
        Re-read the part about installing over your existing so I untarred it over.
        Of course now I can't register it because I've already used it up. I'll have to call tomorrow to support.
          You can put in a help desk request for this issue and HST will get you going.
          http://helpdesk.homeseer.com/
            Help Desk
            I don't have an account and when I click to create one the section to do so is blank. Tried it in a couple of browsers. I'll just call a little later today.
              Try again now. I looked up your name in the licensing system and reset it for you.
                stuck again
                Thanks for helping! Registration failed - invalid license id/password combination however.
                On the lighter side, I just found a link to upgrade my Zee -correctly, as opposed to how I tried. Kinda funny.
                  wow
                  Waited on hold for ten minutes then had to leave a message. Hope they get back to me soon. Would like to get Alexa and HS3 working as I have the time today.
                    Yea, it's a holiday so the crew is on the light side today.
                      The invalid license id/password combination is typically caused by loading the wrong product.
                        Cool
                        Ok - so I did the upgrade following the correct link. Rebooted it (manually). Then loaded the page and registered.
                        I'm up and running with 239 now. Thanks for the help and input.
                        Now to go play with Alexa... (that sounds sorta weird)
                        Thanks again!
                          Thanks again!
                          Yea, let's hope the government isn't listening
