Go Back   HomeSeer Message Board > User Interface Plug-ins > User Interface Discussion > ImperiHome Plug-in (3P)
Old July 15th, 2017, 09:26 PM
Ltek Ltek is offline
Seer Deluxe
Plugin Not updating Imperihome with new devices - without multiple tries
This has been a problem since day 1 of using the plugin. I've been using IH for 2 years on Vera, and never ever had a problem with a lag time to update the devices when I added new ones.
Please clarify exactly what needs to happen to get the refresh to occur?
It has taken me several cache rebuilds and forced IH refreshes to get it to work.
thx
Old July 18th, 2017, 09:10 AM
spud's Avatar
spud spud is online now
Moderator
a cache rebuild and then a reload from the IH app is enough to make new devices appear. (most of the time the cache rebuild is not even necessary)
Old July 18th, 2017, 09:56 AM
Seer Deluxe
Gotcha. When the device status updates, is it direct to Homeseer or does the plugin respond?
About 30% of the time the devices do not update status.. Even when I'm on the LAN.
I'm wondering if there is a way to debug when it happens?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Old July 18th, 2017, 10:02 AM
spud's Avatar
Moderator
the IH app polls the plugin for status values every X seconds (X being the refresh rate configured in IH), the plugin responds with the most up to date status values it has.
to debug, set the log level to Trace, and you will see the JSON data that is being sent.
Old July 30th, 2017, 01:41 AM
Seer Deluxe
Added 3 new multi Motions to HS3 today. Then manually added to your plugin: Motion, Temp, Lux, and Humidity for each, thus 12 new devices.
I rebuilt the cache 4 times and killed IH app on my Android... none showed up. The new devices show in the trace - but not in IH?
I messed with IH so much, it crashed after30 min of messing with it... then the devices showed up.
Is IH really as crappy as it seems? I have always had problems with it being slow on updating Vera device status, but it always showed newly added Vera devices immediately.
Old July 30th, 2017, 06:25 AM
spud's Avatar
Moderator
For new devices to appear in IH, killing the app is not enough you need to do a "reload" from the app.
For me it works very well if I follow this rule.
Old July 30th, 2017, 09:58 AM
Seer Deluxe
I did reload like 20 times... That was what finally hung/crashed IH. At least I now know IH is the issue, thanks for the help
HTML code is Off
Kodi plugin work with Imperihome Plugin? Ltek ImperiHome Plug-in (3P) 2 July 21st, 2017 12:53 AM
Devices missing in Imperihome Duc998 ImperiHome Plug-in (3P) 2 March 15th, 2017 06:37 PM
multiple devices connecting to imperihome kenrad ImperiHome Plug-in (3P) 2 June 30th, 2016 04:44 PM
Battery devices not updating after a few hours wienog HS3 / HS3PRO Discussion 11 February 9th, 2015 01:08 PM
xAP Plugin not updating HS Devices karls xAP Plug-in 18 January 11th, 2005 07:35 PM
