Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer General Discussion Area
HomeSeer General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer.
  #21
Old July 20th, 2017, 06:06 PM
integlikewhoa integlikewhoa is offline
Seer Master
Quote:
Originally Posted by Rupp View Post
Have you tried Tasker for fence type detection? I suspect none of these are going to work as they all work the same way. I've tried this app and IFTTT and both false trigger to the point where they are not usable.
I use tasker and autolocation now and it has alot of options for me. It really working great, just browsing others and testing.
  #22
Old August 8th, 2017, 09:48 AM
Seer Master
Quote:
Originally Posted by egmontr View Post
Did you whitelist the App in the "Battery Optimizations"? (For Samsung thru Smart Manager)
In the new EgiGeoZoneBT 1.1.2 I tried to suppress the false triggers.
Go to the App settings and check "ignore false reports".
Where is the main place to show your changelog and talk about the latest beta versions? I see your on 1.1.43 now? What about the regular EgiGeoZone is it working as well as the BT betas are?
  #23
Old August 8th, 2017, 01:49 PM
sooty sooty is offline
Super Seer
My experience using an Android 7.0 device is that EgiGeozone (non BT version) is rock solid when using the Pathsense API. I don't get any false triggers.
Paul..
  #24
Old August 8th, 2017, 03:06 PM
Seer Master
Quote:
Paul..
I'm using the beta BT version right now with Pathsense and its working good with no falses.
I did have one time one two phones that we came back from a weeked vacation where we drove up north for a 4 day weekend. When I got home neither phone would recognize we were home. Even though it should we were less then 50m from home it would not turn green and kick on that we were. I had to click google then back to Pathsense and both phones then turned green and fired off that we were home. Not sure if someone know why that happened. We used our phones during the drive and didn't fly or anything.
  #25
Old August 9th, 2017, 09:23 PM
taylormia taylormia is offline
Seer
I use Backitude https://play.google.com/store/apps/d...ackitude&hl=en on Android 7.0 for location in conjunction with the PHLocation plugin https://forums.homeseer.com/forumdisplay.php?f=1488. Works great for triggering events based on geofence or location. Also both the app and plugin are free.
  #26
Old August 9th, 2017, 10:13 PM
rmiles7721's Avatar
rmiles7721 rmiles7721 is offline
Seer Master
Also using Tasker and Autolocation for quite some time now. I have also used Owntracks as well but wanted to be able to update HS with more information than it provides.
  #27
Old August 10th, 2017, 02:57 AM
ScottRennie ScottRennie is offline
Seer Deluxe
I have started using Taskers 'Cell Near' option. It works really well and, so far, has resolved the incosistencies I was seeing with all the other location based options.
  #28
Old August 11th, 2017, 07:00 AM
egmontr egmontr is offline
Seer
Quote:
The main place is here
https://egigeozone.de/beta/default_en.html
and here vor non Beta
https://egigeozone.de/history/default_en.html
But sometime it takes some time until I update
The 1.1.43 is only an documentation issue in the Play Store. It should be 1.1.4.
Yes, but has no Bluetooth support.
  #29
Old August 11th, 2017, 12:14 PM
Seer Master
I don't need Bluetooth but was using that version per your request that is was a Beta with some newer features to test. You might have meant this but I just want to be clear, is the non BT version now updated to include these beta features that are in the BT version. Sorry for asking again.
  #30
Old August 13th, 2017, 10:18 AM
Seer
Yes, now the non Beta has quite all included.
HTML code is Off
Geofence / Location / Wifi not always on issues on Android, advice needed mikee123 HS3 / HS3PRO Discussion 7 May 13th, 2017 11:10 AM
Location 1 and Location 2 renaming sparkman UltraGCIR HSPI 2 January 13th, 2013 11:38 AM
A list of simple questions, but not simple for me JeffNielson HomeSeer Z-Wave Plug-in 2 September 1st, 2012 06:35 PM
Silly Question: Location 1=Room / Location 2=Floor or vice versa? Krumpy Insteon Plug-in (Mark Sandler) 1 November 16th, 2011 12:50 PM
Android Client version 1.0.0.0 is in the Android Market rjh Clients - Android 69 January 31st, 2011 12:13 PM
