I have a problem with this type of certified Z-wave Plus thermostat:
http://products.z-wavealliance.org/products/1182
But the temp is set to 5 degrees.
To set the temp thru a parameter works fine.
Is there any log or something I can check to find if the problem is on the HS3 or on the thermostat side?
The vendor say that it forks fine with Fibaro HC
okt-20 20:29:06 Z-Wave Device: 1st Floor Bathroom Energy Save Heating Setpoint Set to 26 okt-20 20:29:06 Device Control Device: 1st Floor Bathroom Energy Save Heating Setpoint to (value) (26) by/from: CAPI Control Handler
