The latest version of the plugin connects and disconnects every 30 seconds when using the BLML2HS checkbox, and when using the ML/MS checkbox no variables are ever 'seen' in MS?
I'm using port 95 for BLMS2HS in both HS3 and MS (latest version).
I'm using port 96 for ML/MS in both HS3 and MS (latest version).
I have checked all of my devices in both the BLMS2HS and ML/MS columns, and saved...I waited until it finished saving.
I have restarted the plugin / HS3 / and MS.
Not sure what to do now? I'm logging your plugin, and HS3 shows a good 'heartbeat' to MS every 30 seconds...nothing about a disconnection.
The plugin worked fine on version 2.0.28
