Jim,
Upgraded to your latest version in the Updater, and now can't get this code to execute. Would you help?
Sub Main
DIM DStr, dm
DIM Sensor
Set dm = hs.plugin("DooMotion")
For each MS in dm.MotionSensor HERE IS WHERE I GET THE ERROR
Set Sensor = MS
Sensor.NormalElapsedTime = 1
Select Case Left(Sensor.Name,6)
Case "Living"
Sensor.OccupancyElapsedTime = 45
Case "Outsid"
Sensor.OccupancyElapsedTime = 30
Case "DS Hal"
Sensor.OccupancyElapsedTime = 15
Case Else
End Select
hs.WriteLog "Motion", Sensor.Name & " OET set to " & sensor.OccupancyElapsedTime & " mins"
Next
Set Sensor = nothing
End Sub
Sub Main
DIM DStr, dm
DIM Sensor
Set Sensor = MS
Case "Living"
Case "Outsid"
Case "DS Hal"
Case Else
End Select
Next
End Sub
