Originally posted by Flame
View Post
Dirk
Sub LinkAGroupOfZones(ByVal LinkGroupName As String, ByVal SourceZoneName As String, ByVal DestinationZonesString As String)
'Sub LinkAGroupOfZones(ByVal SourceZoneName As String)
Dim pi As Object
'Example Dim LinkgroupName As String = "Test"
'Example Dim SourceZoneName As String = "Family Room"
'Example Dim DestinationZonesString As String = "Master Bedroom;20;1|Kitchen;20;1"
pi = hs.Plugin("SONOSCONTROLLER")
If pi Is Nothing Then
hs.writelog("Script", "empty")
Exit Sub
End If
Try
pi.SetLinkgroupZoneSource(LinkgroupName, SourceZoneName) ' store the zone source info
Catch ex As Exception
hs.writelog("Script", "Error in calling SetLinkgroupZoneSource with error = " & ex.message)
Exit Sub
End Try
Try
pi.SetLinkgroupZoneDestination(LinkgroupName, DestinationZonesString) ' store the zone destination info
hs.writelog("Script", "Error in calling DestinationZonesString with error = " & ex.message)
Exit Sub
End Try
Try
pi.HandleLinking(LinkgroupName, True) ' Link!
hs.writelog("Script", "Error in calling HandleLinking with error = " & ex.message)
Exit Sub
End Try
End Sub
Sub UnLinkAGroupOfZones(ByVal LinkGroupName As String)
Dim pi As Object
Exit Sub
End If
Try
pi.HandleLinking(LinkgroupName, False) ' UnLink!
Exit Sub
End Try
End Sub
