HS3 Sonoscontroller beta testing forum
    #76
    Originally posted by chrkov View Post
    Trying to play with HSTouch. Is using the MusicCtrlGrp.xml file still valid? I cant seem to find the file if it is.
    MusicCtrlGrp.xml is not valid anymore, the whole MusicAPI as used in HS2 is gone and very unclear what and when will be made available in HS3 by the HS team.
    So for time being, no media content browsing in HST, all else, such as play/pause/.../track/artist/album/art.... is now available via "regular" HS devices that you "associate" to buttons or images that you drop onto your HST screens.
    Dirk
      #77
      Error
      Hi Dirk
      Just trying out v3
      Getting this error on one (of 7) zone players
      12/1/2013 9:43:11 AM ~!~Sonos Error~!~Error in DirectConnect for zoneplayer = Porch when getting the AudioInputName with Error = Exception from HRESULT: 0x80040212
      ________________________
      Dell Zino HD - HSPRo 2.x
      HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
      2 x Brultech ECM1240 with UltraECM
      USB UIRT
      Cooper Aspire Z-Wave Switches
      WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
      HM ST812-2 Flood Sensor
      HSM100 - Motion Detector with Light and Temperature
      2GIG Thermostat
      BLDSC - Alarm Plug-in
      BLUPS
      UltraLog (SQL2008)
      Jon00 Plugins
      Host XR3 BT and Jon00 BT Proximity
      Global Cache IP2IR
      Foscam FI8918W
        #78
        Originally posted by mark_anderson_us View Post
        Hi Dirk
        Just trying out v3
        Hi Mark, what kind of player is this? Did you rename the audio input on that player to something special?
        Dirk
          #79
          Hi Dirk
          it's a ZP120. I don;t see anywhere in the controller to rename the input. I don't recall ever having done it
          I've restarted several times this morning and it seems to have gone away now. Will let you know if re-appears
          USB UIRT
          2GIG Thermostat
          BLUPS
          UltraLog (SQL2008)
          Jon00 Plugins
          Global Cache IP2IR
          Foscam FI8918W
            #80
            Hmmm, just appeared 2 more times
            12/1/2013 12:45:59 PM ~!~Sonos Error~!~Error in DirectConnect for zoneplayer = Portable when getting the AudioInputName with Error = Exception from HRESULT: 0x80040212
            12/1/2013 12:46:11 PM ~!~Sonos Error~!~Error in DirectConnect for zoneplayer = Living Room when getting the AudioInputName with Error = Exception from HRESULT: 0x80040212
            Portable is S5
            Living Room is ZP80
            USB UIRT
            2GIG Thermostat
            BLUPS
            UltraLog (SQL2008)
            Jon00 Plugins
            Global Cache IP2IR
            Foscam FI8918W
              #81
              Portable is S5
              Living Room is ZP80
              Had a quick check in my log for the last month, no errors in mine.
              Are these audioinputs connected to something? Maybe turn the debug flag on and recreate and post the whole log.
              Dirk
                #82
                Best,
                Jakob Sand, I automate everything!
                  #83
                  I think the MusicDB doesn't have the info in it that it was looking for and that was supposed to be there.
                  So causes could be that you use an event for a radiostation that is not captured in the Music/RadiostationDB, perhaps that file was deleted, removed, corrupted?
                  When do you get this error? When you trigger some Sonos Action?
                  Dirk
                    #84
                    Dirk
                    I was an action - seems like the radiostation has chanced. I will try correct my events/rdo stations.
                    Best,
                      #85
                      Best,
                        #86
                        Originally posted by Jakob.Sand View Post
                        now I get this when I try to play a radiostation. I am on x.x.52 of Homeseer
                        Jacob, can you please add more info to your postings, it will speed up the process.
                        How are you trying to play this radio station? Is it an event/action, click on some button, Sonos Controller ....
                        Provide screen shots
                        Provide full error logs, not just the error, so turn the debug flag on and capture into before and after the error so I can try to figure out what is happening.
                        If I could read minds, I could be making a lot of money
                        If it is an event/action, I noted some postings by Spud that some trigger events were hosed up in the latest HS3 builds, so you may have to delete the action and recreate with version .52 and see if that fixes it. HS3 is unfortunately still changing (or breaking) functions so in order for me to recreate the problem, I need to know step-by-step what you are doing, what works, what doesn't, when did it break, what happened between it working and not working (ie what did you do)
                        Dirk
                          #87
                          Sorry about this.
                          HS3 seems to be really shaky ATM.
                          It is a Sono Action.
                          It used to work. only thing I have done with the sonos is:
                          1. paired to s3 to stero pair (does not show up in you plugins) but it is not the speakers I try to play on.
                          2. upgraded HS3 as new updates arrive....
                          I get this an only this in the log:
                          Dirk
                          Best,
                            #88
                            Did you turn the Sonos PI debug flag on?
                              #89
                              no :-)
                              here it comes.
                              Error in TransportStateChange getting track info. Error = Data provider or other service returned an E_FAIL status.. XML = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="PLAYING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E}Senest spillet: The stÞvle dance | De Nattergale{0x3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:52	  	 Sonos	 CreateRadioStationDatabase called with C:\Program Files\HomeSeer HS3\html\Sonos\MusicDb\SonosRadioStationsDB.mdb and Provider=Microsoft.Jet.OLEDB.4.0{0x3B}Data Source=C:\Program Files\HomeSeer HS3\html\Sonos\MusicDb\SonosRadioStationsDB.mdb for zoneplayer = Badeværelse
                              dec-12 22:41:52	  	 Sonos	 UpdateRadioStationsInfo called for Zone = Badeværelse with CurrentURI x-sonosapi-stream:s37309?sid=254&flags=32 and CurrentURIMetaData = {0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}
                              dec-12 22:41:52	  	 Sonos	 Badeværelse TrackInfo (Internet Radio Art) = x-sonosapi-stream:s37309?sid=254&flags=32
                              dec-12 22:41:52	  	 Sonos	 Badeværelse TrackInfo (Internet Radio) =
                              dec-12 22:41:52	  	 Sonos	 Badeværelse TrackInfo (title) = DR P4 København
                              dec-12 22:41:52	  	 Sonos	 Badeværelse TrackInfo (MediaInfo/Title) = DR P4 København
                              dec-12 22:41:52	  	 Sonos	 Badeværelse TrackInfo (CurrentURI) = x-sonosapi-stream:s37309?sid=254&flags=32 and TrackInfo (CurrentURIMetaData) = {0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}
                              dec-12 22:41:52	  	 Sonos	 GetcurrentTrackInfo called for zoneplayer - Badeværelse
                              dec-12 22:41:52	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse TransportState(TransportState) = PLAYING and previous state was = Stopped
                              dec-12 22:41:52	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse VarName = LastChange Value = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="PLAYING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E}Senest spillet: The stÞvle dance | De Nattergale{0x3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:52	  	 Sonos Error	 Error in TransportStateChange getting track info. Error = Data provider or other service returned an E_FAIL status.. XML = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="PLAYING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:52	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse VarName = LastChange Value = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="PLAYING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:52	  	 Sonos Error	 Error in TransportStateChange getting track info. Error = Data provider or other service returned an E_FAIL status.. XML = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="TRANSITIONING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:51	  	 Sonos	 GetcurrentTrackInfo called for zoneplayer - Badeværelse
                              dec-12 22:41:51	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse TransportState(TransportState) = TRANSITIONING and previous state was = Stopped
                              dec-12 22:41:51	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse VarName = LastChange Value = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="TRANSITIONING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:51	  	 Sonos Error	 Error in TransportStateChange getting track info. Error = Data provider or other service returned an E_FAIL status.. XML = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="TRANSITIONING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E}ZPSTR_BUFFERING{0x3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:51	  	 Sonos	 CreateRadioStationDatabase called with C:\Program Files\HomeSeer HS3\html\Sonos\MusicDb\SonosRadioStationsDB.mdb and Provider=Microsoft.Jet.OLEDB.4.0{0x3B}Data Source=C:\Program Files\HomeSeer HS3\html\Sonos\MusicDb\SonosRadioStationsDB.mdb for zoneplayer = Badeværelse
                              dec-12 22:41:51	  	 Sonos	 UpdateRadioStationsInfo called for Zone = Badeværelse with CurrentURI x-sonosapi-stream:s37309?sid=254&flags=32 and CurrentURIMetaData = {0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}
                              dec-12 22:41:51	  	 Sonos	 Badeværelse TrackInfo (Internet Radio Art) = x-sonosapi-stream:s37309?sid=254&flags=32
                              dec-12 22:41:51	  	 Sonos	 Badeværelse TrackInfo (Internet Radio) =
                              dec-12 22:41:51	  	 Sonos	 Badeværelse TrackInfo (title) = DR P4 København
                              dec-12 22:41:51	  	 Sonos	 Badeværelse TrackInfo (MediaInfo/Title) = DR P4 København
                              dec-12 22:41:51	  	 Sonos	 Badeværelse TrackInfo (CurrentURI) = x-sonosapi-stream:s37309?sid=254&flags=32 and TrackInfo (CurrentURIMetaData) = {0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}
                              dec-12 22:41:51	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse VarName = LastChange Value = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="TRANSITIONING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E}ZPSTR_BUFFERING{0x3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:50	  	 Sonos Error	 Error in TransportStateChange getting track info. Error = Data provider or other service returned an E_FAIL status.. XML = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="TRANSITIONING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E}ZPSTR_CONNECTING{0x3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:50	  	 Sonos	 CreateRadioStationDatabase called with C:\Program Files\HomeSeer HS3\html\Sonos\MusicDb\SonosRadioStationsDB.mdb and Provider=Microsoft.Jet.OLEDB.4.0{0x3B}Data Source=C:\Program Files\HomeSeer HS3\html\Sonos\MusicDb\SonosRadioStationsDB.mdb for zoneplayer = Badeværelse
                              dec-12 22:41:50	  	 Sonos	 UpdateRadioStationsInfo called for Zone = Badeværelse with CurrentURI x-sonosapi-stream:s37309?sid=254&flags=32 and CurrentURIMetaData = {0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}
                              dec-12 22:41:50	  	 Sonos	 Badeværelse TrackInfo (Internet Radio Art) = x-sonosapi-stream:s37309?sid=254&flags=32
                              dec-12 22:41:50	  	 Sonos	 Badeværelse TrackInfo (Internet Radio) =
                              dec-12 22:41:50	  	 Sonos	 Badeværelse TrackInfo (title) = DR P4 København
                              dec-12 22:41:50	  	 Sonos	 Badeværelse TrackInfo (MediaInfo/Title) = DR P4 København
                              dec-12 22:41:50	  	 Sonos	 Badeværelse TrackInfo (CurrentURI) = x-sonosapi-stream:s37309?sid=254&flags=32 and TrackInfo (CurrentURIMetaData) = {0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}
                              dec-12 22:41:50	  	 Sonos	 GetcurrentTrackInfo called for zoneplayer - Badeværelse
                              dec-12 22:41:50	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse TransportState(TransportState) = TRANSITIONING and previous state was = Stopped
                              dec-12 22:41:50	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse VarName = LastChange Value = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="TRANSITIONING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E}ZPSTR_CONNECTING{0x3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:50	  	 Sonos Error	 Error in TransportStateChange getting track info. Error = Data provider or other service returned an E_FAIL status.. XML = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="TRANSITIONING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:50	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse VarName = LastChange Value = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="TRANSITIONING"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:50	  	 Sonos Error	 Error in TransportStateChange getting track info. Error = Data provider or other service returned an E_FAIL status.. XML = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="STOPPED"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}PlaybackStorageMedium val="NETWORK"/{0x3E3C}AVTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}AVTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}CurrentTransportActions val="Set, Play, Stop, Pause, Seek, Next, Previous"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:50	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse TransportState(TransportState) = STOPPED and previous state was = Stopped
                              dec-12 22:41:50	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse VarName = LastChange Value = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="STOPPED"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}PlaybackStorageMedium val="NETWORK"/{0x3E3C}AVTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}AVTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}CurrentTransportActions val="Set, Play, Stop, Pause, Seek, Next, Previous"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:50	  	 Sonos	 SetTransportState called for zoneplayer - Badeværelse with value = Play
                              dec-12 22:41:48	  	 PHLocation	 Poll Timer elapsed
                              dec-12 22:41:43	  	 Sonos Error	 Error in TransportStateChange getting track info. Error = Data provider or other service returned an E_FAIL status.. XML = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="STOPPED"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:43	  	 Sonos	 CreateRadioStationDatabase called with C:\Program Files\HomeSeer HS3\html\Sonos\MusicDb\SonosRadioStationsDB.mdb and Provider=Microsoft.Jet.OLEDB.4.0{0x3B}Data Source=C:\Program Files\HomeSeer HS3\html\Sonos\MusicDb\SonosRadioStationsDB.mdb for zoneplayer = Badeværelse
                              dec-12 22:41:43	  	 Sonos	 UpdateRadioStationsInfo called for Zone = Badeværelse with CurrentURI x-sonosapi-stream:s37309?sid=254&flags=32 and CurrentURIMetaData = {0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}
                              dec-12 22:41:43	  	 Sonos	 AddDescToMetaData called for zoneplayer Badeværelse with modified XML = {0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="R:0/0/2" parentID="R:0/0" restricted="false"{0x3E3C}dc:title{0x3E}DR P4 København 96.5 (Euro Hits){0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&flags=32{0x3C}/res{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}
                              dec-12 22:41:43	  	 Sonos	 Badeværelse TrackInfo (Internet Radio Art) = x-sonosapi-stream:s37309?sid=254&flags=32
                              dec-12 22:41:43	  	 Sonos	 AddDescToMetaData called for zoneplayer = Badeværelse
                              dec-12 22:41:43	  	 Sonos	 Badeværelse TrackInfo (Internet Radio) =
                              dec-12 22:41:43	  	 Sonos	 Badeværelse TrackInfo (title) = DR P4 København
                              dec-12 22:41:43	  	 Sonos	 Badeværelse TrackInfo (MediaInfo/Title) = DR P4 København
                              dec-12 22:41:43	  	 Sonos	 Badeværelse TrackInfo (CurrentURI) = x-sonosapi-stream:s37309?sid=254&flags=32 and TrackInfo (CurrentURIMetaData) = {0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}
                              dec-12 22:41:43	  	 Sonos	 GetcurrentTrackInfo called for zoneplayer - Badeværelse
                              dec-12 22:41:43	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse TransportState(TransportState) = STOPPED and previous state was = Stopped
                              dec-12 22:41:43	  	 Sonos	 TransportChangeCallback for ZP - Badeværelse VarName = LastChange Value = {0x3C}Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E3C}InstanceID val="0"{0x3E3C}TransportState val="STOPPED"/{0x3E3C}CurrentPlayMode val="NORMAL"/{0x3E3C}CurrentCrossfadeMode val="0"/{0x3E3C}NumberOfTracks val="2"/{0x3E3C}CurrentTrack val="1"/{0x3E3C}CurrentSection val="0"/{0x3E3C}CurrentTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08H.mp3"/{0x3E3C}CurrentTrackDuration val="0:00:00"/{0x3E3C}CurrentTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="sonos.com-http:*:*:*"{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/res{0x3E3C}r:streamContent{0x3E3C}/r:streamContent{0x3E3C}r:radioShowMd{0x3E3C}/r:radioShowMd{0x3E3C}upnp:albumArtURI{0x3E}/getaa?s=1&{0x3B}u=x-sonosapi-stream%3as37309%3fsid%3d254%26flags%3d32{0x3C}/upnp:albumArtURI{0x3E3C}dc:title{0x3E}x-sonosapi-stream:s37309?sid=254&{0x3B}flags=32{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:NextTrackURI val="x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3"/{0x3E3C}r:NextTrackMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}res protocolInfo="x-rincon-mp3radio:*:*:*"{0x3E}x-rincon-mp3radio://live-icy.gss.dr.dk:8000/A/A08L.mp3{0x3C}/res{0x3E3C}dc:title{0x3E}A08L.mp3{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item{0x3C}/upnp:class{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}r:EnqueuedTransportURI val="x-sonosapi-stream:s37309?sid=254&flags=32"/{0x3E3C}r:EnqueuedTransportURIMetaData val="{0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}DR P4 København{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioBroadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}"/{0x3E3C}/InstanceID{0x3E3C}/Event{0x3E}
                              dec-12 22:41:43	  	 Sonos	 GetTrackMetaData called for zoneplayer = Badeværelse with URI= R:0/0/2 and BrowseOnlyMetaData = False
                              dec-12 22:41:43	  	 Sonos	 PlayURI called for zoneplayer Badeværelse with strURI = x-sonosapi-stream:s37309?sid=254&flags=32 and MetaData = R:0/0/2
                              dec-12 22:41:43	  	 Sonos	 SetTransportState called for zoneplayer - Badeværelse with value = Stop
                              dec-12 22:41:43	  	 Sonos	 PlayMusicOnZone for zoneplayer = Badeværelse found TrackIndex = 2
                              dec-12 22:41:42	  	 Sonos	 PlayMusicOnZone for Zone Badeværelse and query = SELECT * FROM Tracks WHERE Name = 'All RadioStations' AND Artist = 'RadioStation: DR P4 København 96.5 (Euro Hits)'
                              dec-12 22:41:42	  	 Sonos	 PlayMusicOnZone for Zone Badeværelse and MusicDBName = C:\Program Files\HomeSeer HS3\html\Sonos\MusicDb\SonosDB.mdb, ZoneUDN = , Artist = Album = Playlist = RadioStation: DR P4 København 96.5 (Euro Hits), Genre = , Track = , StartWithArtist = , StartWithTrack = , TrackMatch = , Favorite = , ClearPlayerQueue = False, QueueAction = qaPlayNow
                              dec-12 22:41:42	  	 Sonos	 PlayMusic called for Zone - Badeværelse with Artist= and Album= and Playlist=RadioStation: DR P4 København 96.5 (Euro Hits) and Genre= and Track= and StartWithArtist= and StartWithTrack= and TrackMatch=and Audiobook = and Podcast = and ClearPlayerQueue = False and QueueAction = qaPlayNow
                              dec-12 22:41:42	  	 Sonos	 HandleAction found sKey = AddInfoAction_9931_A0 and Value = RadioStation: DR P4 København 96.5 (Euro Hits)
                              dec-12 22:41:42	  	 Sonos	 HandleAction found sKey = PlayerListAction_9931_A0 and Value = RINCON_000E58D260CC01400
                              dec-12 22:41:42	  	 Sonos	 HandleAction found sKey = CommandListAction_9931_A0 and Value = Play Radiostation
                              dec-12 22:41:42	  	 Sonos	 HandleAction called with evRef = 9931 and SubTANumber = 0 and TANumber = 1 and UID = 4932
                              dec-12 22:41:42	  	 Sonos	 ActionConfigured returns True
                              dec-12 22:41:42	  	 Sonos	 ActionConfigured found sKey = AddInfoAction_9931_A0 and Value = RadioStation: DR P4 København 96.5 (Euro Hits)
                              dec-12 22:41:42	  	 Sonos	 ActionConfigured found sKey = PlayerListAction_9931_A0 and Value = RINCON_000E58D260CC01400
                              dec-12 22:41:42	  	 Sonos	 ActionConfigured found sKey = CommandListAction_9931_A0 and Value = Play Radiostation
                              dec-12 22:41:42	  	 Sonos	 ActionConfigured called with evRef = 9931 and SubTANumber = 0 and TANumber = 1 and UID = 4932
                              dec-12 22:41:42	  	 Event	 Event Trigger "Music WC Radio Station 08:30 P1 Morning Weekday - - Copy"
                              dec-12 22:41:42	  	 Event	 Event Music WC Radio Station 08:30 P1 Morning Weekday - - Copy triggered by the event page 'Run' button.
                              Best,
                              Jakob Sand, I automate everything!
                                #90
                                Originally posted by Jakob.Sand View Post
                                no :-)
                                here it comes.
                                Sonos seems to refuse to play this station.
                                Possible causes:
                                - your PI Music DB is out of sync w/ the Sonos DB. When was the last time you (re)built the musicDB? I think this radio station was discovered by the PI as part of a Radio station that you had marked up in Sonos as a favorite radiostation, is that correct? You didn't delete that by any chance now did you?
                                - Maybe the Music DB has multiple entries and we pick up the wrong one but resync/rebuild the PI's musicDB should fix that.
                                - I assume you tried to play this radio station from the Sonos Controller and nothing is wrong with that radiostation.
                                - Some bug
                                Dirk
