In wall Android tablet mount
    Has anyone got any suggestions on in wall tablet / mount (good and/or bad experiences)?
    I'm looking for something small for downstairs, that will always be where its mounted (7" should be enough room to display what I want)...
    Was thinking of something like http://www.geekland.co/7-Android-40-...K-VIA-E002.htm with WiFi and a battery. The basement isn't finished yet so now's probably the best time to do this if I'm going to.
    I thought about buying a $50-80 Android tablet and using double sided tape to plaster it to the wall, briefly... the cost was about right if it would have worked... but the aesthetics are terrible
    Trying to keep this under ~250, way under if possible. The darn things only going to display a few custom HSTouch screens after all is said and done.
    Looks to be almost the same as the one that HST used to sell: http://board.homeseer.com/showthread.php?t=156066
    Cheers
    Al
      You mean like this?
Name:	2014-12-17 20.34.12.jpg
        I made a picture frame for a 10" tablet. Total cost $99
        Sent from my SCH-R970X using Tapatalk
        HS4Pro on a Raspberry Pi4
        HSTouch Clients: 1 Android
          Originally posted by wposner View Post
          You mean like this?
          [ATTACH]43087[/ATTACH]
          That is nice and would be a decent fit too.
            I might take a shot at this if I can't get the cost down on an in wall mount with power. Who knows... could be fun.
              Zipato Wall Tablet 7
              Has anyone seen or used one of these things?
              Its from Europe so the z-wave interface might not work in North America but it looked interesting.
                I ued an AV box behind the frame that allows for a wall outlet and a set of RCAs. I used a wall outlet with dual USBs and a wall plate to cover the hole where the RCAs would go. Then I just used the Nexus USB charging cable to supply power, duct-taped everything securly to the frame and used the 3M velcro to attach it over the AV box.
