HS3 Linux and Windows SONOS PI version
    #61
    Originally posted by teladog01 View Post
    EDIT: Never mind. For some reason the Playbar devices weren't updating properly. After restarting the Playbar, it is working again as it did before on the 3.0.0.x versions. Sorry for the false alarm.
    I've fixed the updating of HS (show playing TV) in next version, however, there is no track info what so ever so your events wouldn't work. I can fake out the Track to "TV Input", I think that would work for your events. Please confirm.
    Dirk
      #62
      Dirk
      Dirk, thanks for the response....My events didn't run this afternoon when I turned on the TV, so I did a some more testing. There are some fringe cases when the Playbar is power cycled that will trigger the events, but I wasn't able to nail down the exact parameters. Any other time though, the events don't trigger.
      It appears that the Player and Track devices are not changing when the TV input becomes active (except for those fringe cases after power on). These did change in the old version, which is what allowed my events to work obviously.
      So the new version needs a mechanism to trigger events based on when the TV Input starts playing. Do you think that is possible? Would you consider adding a new dedicated trigger, i.e. "Sonos TV Input Starts Playing" or something similar? I think it would also be appropriate to update the Track device, e.g. "TV", since that is what is done when the Line-In is playing on a Connect or Play:5.
      If that is not possible then maybe you could just update the Player and Track device accordingly as the old version used to. Although I suppose this could have unintended consequences if one plays a music track also titled "TV" (or whatever label you choose). Not very likely, but possible.
      And finally, it would also be nice to update the Artwork device to reflect the TV Input status. I'd be happy to send a file for the TV Input artwork if you'd like.
      Thanks for considering this and let me know if you need me to test anything.
        #63
        Sorry can't do all the stuff you ask for but here is a version that set the Track to "TV Input" which is very unlikely a track name ever.
        Please download zip file, unzip and copy to <HS Root directory>. Let me know when you have downloaded the file, so I'll remove it here.
        Dirk
          #64
          Dirk
          Hi Dirk.
          I've downloaded and tested the version 3.1.0.10 you posted. Good news is now the Playbar Player and Track devices update and I can trigger events again based on "TV Input". Thanks for that quick fix.
          But now there is a new problem with other events that use the action Play Radiostation. The Radiostation doesn't play and I get the following error in the HS log:
          Nov-18 6:26:24 PM	 	Sonos Error	ERROR in PlayURI for zoneplayer = Front Bedroom with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-sonosapi-stream:s34956?sid=254&flags=8224&sn=0 and isObjectID = False, MetaData=90.9 | KRCU (Classical)object.item.audioItem.audioBroadcastx-sonosapi-stream:s34956?sid=254&flags=8224&sn=0SA_RINCON65031_, Error =MyUPnPService.InvokeAction for ServiceID = [url]http://10.3.11.140:1400/xml/AVTransport1.xml[/url] while sending Action = SetAVTransportURI for URI = [url]http://10.3.11.140:1400/MediaRenderer/AVTransport/Control[/url] and Request = 0 x-sonosapi-stream:s34956?sid=254&flags=8224&sn=0 <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="R:0/0/63" parentID="R:0/0" restricted="false"><dc:title>90.9 | KRCU (Classical)</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s34956?sid=254&flags=8224&sn=0</res><desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/">SA_RINCON65031_</desc></item></DIDL-Lite> UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 402 with error = The remote server returned an error: (500) Internal Server Error.
          The error happens when using the action Play Radiostation, and for any Sonos player (not just the Playbar). I tried several different Radiostations from the action Play Radiostation and got similar errors. I rolled back to 3.0.1.9 and verified the error doesn't happen and the Radiostation plays fine in that version.
          Hope this is helpful. Let me know if you need me to test anything. Thanks again.
            #65
            Nov-18 6:26:24 PM         Sonos Error    ERROR in PlayURI for zoneplayer = Front Bedroom with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-sonosapi-stream:s34956?sid=254&flags=8224&sn=0 and isObjectID = False, MetaData=90.9 | KRCU (Classical)object.item.audioItem.audioBroadcastx-sonosapi-stream:s34956?sid=254&flags=8224&sn=0SA_RINCON65031_, Error =MyUPnPService.InvokeAction for ServiceID = [URL]http://10.3.11.140:1400/xml/AVTransport1.xml[/URL] while sending Action = SetAVTransportURI for URI = [URL]http://10.3.11.140:1400/MediaRenderer/AVTransport/Control[/URL] and Request = 0 x-sonosapi-stream:s34956?sid=254&flags=8224&sn=0 <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="R:0/0/63" parentID="R:0/0" restricted="false"><dc:title>90.9 | KRCU (Classical)</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s34956?sid=254&flags=8224&sn=0</res><desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/">SA_RINCON65031_</desc></item></DIDL-Lite> UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 402 with error = The remote server returned an error: (500) Internal Server Error.
            Good catch !!!
            Broke existing function to solve an issue with playing Favorites.
            Try the attached,
            Dirk
              #66
              Good catch !!!
              Try the attached,
              Dirk
              Looks like this one fixed it! No more errors with Play Radiostation events.
              Also, I see that alarm triggers are working again in this one. Yay! Thanks again.
                #67
                Dirk, new problem introduced with the last one you posted. I have the following event trigger:
                IF Sonos trigger - Sonos Track Change for player - <PlaybarName>
                AND IF Sonos Condition - hasTrack = TV Input for player - <PlaybarName>
                The event is running every time I pause my DVR, and then again when pressing play again. It did not used to do this so something has changed. Neither Player nor Track device Last Change time is changing, yet the event is triggering when it shouldn't.
                Thoughts?
                  #68
                  Thoughts?
                  Turn on debug, capture log. Means Sonos is sending events when that happens .....
                    #69
                    Here's a debug log and a screenshot of the event.
                    The debug period was about a minute long and I paused and unpaused the DVR several times in that period. The HS Log was spewing all kinds of stuff of course, but I could see that the event was firing every time I pressed play or pause on the DVR.
                    Let me know if you need any more info...thanks again.
                      #70
                      Try attached
                      Dirk
                        #71
                        Try attached
                        Dirk
                        Yep, that appears to have fixed it. You are the man, sir
                        Thanks for the excellent support!
                          #72
                          Dirk,
                          Things are going mostly well with the test build 3.1.0.10 you posted. Just wanted to report that sometimes I get the following error still when playing a Radiostation:
                          Nov-24 5:14:21 PM	 	Sonos Error	ERROR in PlayURI for zoneplayer = Bathroom with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-rincon:RINCON_000E58B6AE2501400 and isObjectID = False, MetaData=, Error =MyUPnPService.InvokeAction for ServiceID = http://10.3.11.135:1400/xml/AVTransport1.xml while sending Action = SetAVTransportURI for URI = http://10.3.11.135:1400/MediaRenderer/AVTransport/Control and Request = 0 x-rincon:RINCON_000E58B6AE2501400 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 501 with error = The remote server returned an error: (500) Internal Server Error.
                          I'd post a debug log but it I cannot reproduce it on demand. Most times the same station plays fine. Let me know if there is something I can do to help debug this.
                            #73
                            Dirk,
                            Dirk,
                            I'm still getting errors sometimes when starting radiostations. It's not limited to any single player and doesn't always happen, but seems to be more frequent recently. Here is my log for the past two days filtered on Sonos Error:
                            Feb-03 7:00:24 AM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Basement with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.124:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.124:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-03 7:00:27 AM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Kitchen with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.196:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.196:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-03 7:00:27 AM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Bathroom with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.135:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.135:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-03 1:09:33 PM	 	Sonos Error	ERROR in PlayURI for zoneplayer = Front Bedroom with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-rincon:RINCON_000E58B6AE2501400 and isObjectID = False, MetaData=, Error =MyUPnPService.InvokeAction for ServiceID = http://10.3.11.140:1400/xml/AVTransport1.xml while sending Action = SetAVTransportURI for URI = http://10.3.11.140:1400/MediaRenderer/AVTransport/Control and Request = 0 x-rincon:RINCON_000E58B6AE2501400 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 501 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-03 1:09:33 PM	 	Sonos Error	ERROR in PlayURI for zoneplayer = Bathroom with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-rincon:RINCON_000E58B6AE2501400 and isObjectID = False, MetaData=, Error =MyUPnPService.InvokeAction for ServiceID = http://10.3.11.135:1400/xml/AVTransport1.xml while sending Action = SetAVTransportURI for URI = http://10.3.11.135:1400/MediaRenderer/AVTransport/Control and Request = 0 x-rincon:RINCON_000E58B6AE2501400 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 501 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-03 1:09:34 PM	 	Sonos Error	ERROR in PlayURI for zoneplayer = Kitchen with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-rincon:RINCON_000E58B6AE2501400 and isObjectID = False, MetaData=, Error =MyUPnPService.InvokeAction for ServiceID = http://10.3.11.196:1400/xml/AVTransport1.xml while sending Action = SetAVTransportURI for URI = http://10.3.11.196:1400/MediaRenderer/AVTransport/Control and Request = 0 x-rincon:RINCON_000E58B6AE2501400 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 501 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-03 5:23:57 PM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Basement with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.124:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.124:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-03 5:24:02 PM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Kitchen with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.196:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.196:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-03 5:24:02 PM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Bathroom with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.135:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.135:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                            2/4/2016
                            Feb-04 6:59:34 AM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Basement with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.124:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.124:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-04 6:59:37 AM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Kitchen with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.196:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.196:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-04 6:59:38 AM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Bathroom with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.135:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.135:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-04 12:55:00 PM	 	Sonos Error	ERROR in PlayURI for zoneplayer = Front Bedroom with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-rincon:RINCON_000E58B6AE2501400 and isObjectID = False, MetaData=, Error =MyUPnPService.InvokeAction for ServiceID = http://10.3.11.140:1400/xml/AVTransport1.xml while sending Action = SetAVTransportURI for URI = http://10.3.11.140:1400/MediaRenderer/AVTransport/Control and Request = 0 x-rincon:RINCON_000E58B6AE2501400 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 501 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-04 12:55:00 PM	 	Sonos Error	ERROR in PlayURI for zoneplayer = Bathroom with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-rincon:RINCON_000E58B6AE2501400 and isObjectID = False, MetaData=, Error =MyUPnPService.InvokeAction for ServiceID = http://10.3.11.135:1400/xml/AVTransport1.xml while sending Action = SetAVTransportURI for URI = http://10.3.11.135:1400/MediaRenderer/AVTransport/Control and Request = 0 x-rincon:RINCON_000E58B6AE2501400 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 501 with error = The remote server returned an error: (500) Internal Server Error.
                            Feb-04 12:55:01 PM	 	Sonos Error	ERROR in PlayURI for zoneplayer = Kitchen with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-rincon:RINCON_000E58B6AE2501400 and isObjectID = False, MetaData=, Error =MyUPnPService.InvokeAction for ServiceID = http://10.3.11.196:1400/xml/AVTransport1.xml while sending Action = SetAVTransportURI for URI = http://10.3.11.196:1400/MediaRenderer/AVTransport/Control and Request = 0 x-rincon:RINCON_000E58B6AE2501400 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 501 with error = The remote server returned an error: (500) Internal Server Error.
                            Attached is a screenshot of one of the events that will sometimes generate these errors.
                            I'm running v3.1.0.11 now. Any ideas?
                              #74
                              Dirk,
                              2/4/2016
                              No idea. Recommend to set debug flag on, wait until it happens and cut/paste all debug info prior to the error. Do check that you do not try to run the event multiple times within a very short time frame.
                              Dirk
                                #75
                                Dirk
                                Dirk,
                                Here's the Sonos errors in the log from today:
                                Feb-05 5:26:10 PM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Basement with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.124:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.124:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                                Feb-05 5:26:10 PM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Living Room with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.109:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.109:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                                Feb-05 5:26:11 PM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Kitchen with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.196:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.196:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                                Feb-05 5:26:11 PM	 	Sonos Error	ERROR in SetPlayMode for zoneplayer = Bathroom with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.3.11.135:1400/xml/AVTransport1.xml while sending Action = SetPlayMode for URI = http://10.3.11.135:1400/MediaRenderer/AVTransport/Control and Request = 0 REPEAT_ALL UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 712 with error = The remote server returned an error: (500) Internal Server Error.
                                Feb-05 5:37:04 PM	 	Sonos Error	ERROR in PlayURI for zoneplayer = Front Bedroom with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-rincon:RINCON_000E58B6AE2501400 and isObjectID = False, MetaData=, Error =MyUPnPService.InvokeAction for ServiceID = http://10.3.11.140:1400/xml/AVTransport1.xml while sending Action = SetAVTransportURI for URI = http://10.3.11.140:1400/MediaRenderer/AVTransport/Control and Request = 0 x-rincon:RINCON_000E58B6AE2501400 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 501 with error = The remote server returned an error: (500) Internal Server Error.
                                Feb-05 5:37:06 PM	 	Sonos Error	ERROR in PlayURI for zoneplayer = Bathroom with UPNP Error = Read only tag / Transport is locked / Access denied. URI=x-rincon:RINCON_000E58B6AE2501400 and isObjectID = False, MetaData=, Error =MyUPnPService.InvokeAction for ServiceID = http://10.3.11.135:1400/xml/AVTransport1.xml while sending Action = SetAVTransportURI for URI = http://10.3.11.135:1400/MediaRenderer/AVTransport/Control and Request = 0 x-rincon:RINCON_000E58B6AE2501400 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 501 with error = The remote server returned an error: (500) Internal Server Error.
                                Attached is the Sonos debug log from when I restarted the plugin last night until now.
                                Thanks for your help.
