BL1Wire not showing sensors
    Using HS3 and BL1Wire plugin.... attached to via com10, using TEMP05 with two sensors, on Windows 7 64bit.
    The "sensor" tab shows "there are no sensors configured in the plugin" message...
    Yet the log shows that it polling data:
    7/19/2015 10:12:01 AM : v2.0.19.0 - comPortObject_DataReceived() started
    7/19/2015 10:12:01 AM : v2.0.19.0 - Process_Port() started
    7/19/2015 10:12:01 AM : v2.0.19.0 - Process_Port(): mySerialPort.BytesToRead --> 19
    7/19/2015 10:12:01 AM : v2.0.19.0 - Process_Port(): theData --> E00080038133B10]=75
    7/19/2015 10:12:01 AM : v2.0.19.0 - ComPortFunctions.Process_Temp05_Com_Port_Data() started
    7/19/2015 10:12:01 AM : v2.0.19.0 - ComPortFunctions.Process_Temp05_Com_Port_Data(): comPortData --> E00080038133B10]=75
    7/19/2015 10:12:01 AM : v2.0.19.0 - ComPortFunctions.Process_Temp05_Com_Port_Data(): Com Port Data:
    7/19/2015 10:12:01 AM : v2.0.19.0 - ComPortFunctions.Process_Temp05_Com_Port_Data(): d --> E00080038133B10]=75
    7/19/2015 10:12:01 AM : v2.0.19.0 - ComPortFunctions.Process_Temp05_Com_Port_Data(): Processing d --> E00080038133B10]=75
    7/19/2015 10:12:01 AM : v2.0.19.0 - ComPortFunctions.Process_Temp05_Com_Port_Data() finished
    7/19/2015 10:12:01 AM : v2.0.19.0 - Process_Port() finished
    7/19/2015 10:12:01 AM : v2.0.19.0 - comPortObject_DataReceived() finished
    Am I missing something on the setup please?
    Thanks.
    Anyone else using the BL1wire plugin with TEMP05? having the same issues that the sensor just wont show up?
      I have read all the posted threads on this subject... none seem to be related to the issue I have.
      I use hyperterminal and I can see the 2 sensors posting their temperatures. when I switch to BL1Wire there is nothing to see or capture. I just don't see how to add the sensors!!!
        I have tried everything to make this work!!! - from original thread it shows that the BL1wire log is showing sensor data capturing..... but it will not reflect on the "sensor" tab.....
        Once again I am looking for advice.
          Capture me a debug log of the sensors getting info and I will if there are any errors
          Cheers,
          Bob
            thank you - here is the log.
              OK I see an error in the log. I will check it out
              Can you try setting it to TEMP08 and see if that is any different
              Cheers,
              Bob
                I do not have TEMP08 only TEMP05.
                  I know but try selecting TEMP08 anyway and see if it acts differently
                  Cheers,
                  Bob
                    I set the value to TEMP08 - same results.
                      OK I will have a look and let you know
                      Cheers,
                      Bob
                        thank you so much.
                          Blade,
                          I shut everything down - using TEMP08 as the option for a TEMP05 device. Now I see the 2 sensors on "sensor" tab.
                          The only issue (not sure if it is my lack of knowledge) - but it only refreshes when I shutdown the BL1wire plugin.... turning it back on, then the sensors will post the new current temperate..... after that there are no other updates until I repeat the steps listed above.
                          Please advice. thanks in advance.
                            What is your TEMP05 set to for polling?
                            Cheers,
                            Bob
                              set to one minute...... if I use hyperterminal if reflects correctly.... it is like BL1wire just sites there waiting for something.....just like I can't explain why it now reads the sensor......!!
                              Again help is appreciated... I am trying to get this to work for summer project..
