Duplicates in player table
    I upgraded to the recent beta and now I have duplicates in the player table.
    I tried clicking on the delete button but nothing happened.
    The new and old PI play very well together, these errors seem to indicate something else went terribly wrong. Was something else wrong before you decided to upgrade? Any devices deleted by hand out of the device management table, perhaps a HS backup used but not the right sonos.ini? Manually moved this install to another PC?
    When you restart the PI, are you still unable to use the delete button? I suspect your sonos.ini file to be incompatible with your HS database. Easiest way to fix that is to stop HS, delete the sonos.ini file and restart HS+PI BUT then all your events and linkgroups will be gone as well.
    Dirk
      Deleting the ini fixed this.
      Thank you!
