Linkgroup Configuration Table - Unable to add entry
    Originally posted by The Profit View Post
    Hello Dirk,
    I just added those four lines to the sonos.ini file and it did have the new entry in the table.
    ...... so ....... does it work ? Can you add more entries now? If you make changes to this one entry, to they stay or do you lose them?
      HS4 4.2.6.0 &HSTouch Designer 3.0.80
      Plugin's:
      BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee, Nest, AK Bond
      weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
        BIZARRE !!!
        Any errors in the log file when you click the delete button?
          Originally posted by dcorsus View Post
          BIZARRE !!!
          I turned on the debug log flag and tried to delete it again, posting it for you below:
          Oct-11 9:45:20 PM SonosBuildButtonStringRef Found LinkgroupZoneSource = NewTableEntry2
          Oct-11 9:45:20 PM SonosBuildButtonStringRef Found LinkgroupZoneSource = FamilyRoom
          Oct-11 9:45:20 PM SonosDeleteIniSection called with section = TTSSpeakDevice and FileName = Sonos.ini
          Oct-11 9:45:20 PM SonosINIT: MaxNbrOfUPNPObjects set to 400
          Oct-11 9:45:20 PM SonosReadIniFile called
          Plugin's:
            BIZARRE !!!
            Plugin's:
              #21
              It is something with the ini file so it is indeed either something with the HS version, .net version, position of the stars, solar eclips ...... but deleting the PI and re-installing won't make a difference. If there is something with the .ini file structure, just deleting that would be something to try but I think you already tried that. So I would start by going to .375 but I read some concerning things, which makes me wonder whether you should go back to (was it) 368.
              I think you already know, but only delete or edit .ini files when HS3 is stopped (because it caches it)
              Dirk
                #22
                Dirk
                Plugin's:
                  #23
                  I have not tried deleting the Sonos.ini file....so the procedure for that would be to shut down HS3, delete Sonos.ini and then restart HS3?
                  Correct. I thought you already tried that. If not, highly recommended to rule out anything fishy in the ini file that's I'm not seeing. There were times that a blank here or there would signal the end of a section or a file and bad things would happen but that is a LOOOONNNNNGGGG time ago.
                  Dirk
                    #24
                    Dirk
                    Ok, I shut down HS3, deleted the Sonos.ini file and restarted HS3.....the manual linkgroup that you had me create was gone as expected, I tried to create a new one and had the same issue. So....is an update to HS3 .37? my best next step?
                    Plugin's:
                      #25
                      Dirk
                      Plugin's:
                        #26
                        That is exactly what was happening. Can you delete entries now?
                          #27
                          Plugin's:
                            #28
                            Dirk, just want to say thank you for your help resolving the issue I had....and thank you for all the work you do to keep our homes automated with great music!
                            Plugin's:
