Discovery not finding payers
    Hi Dirk,
    I can not get HS3 to find my Sonos players. I have 2 P80s, 1 Soundbar, and 1 S1. All are working from the Sonos ap on my phones and computers. I have SSDP and UPnP set to automatic startup. I even tried putting a player in linking mode with discovery.
    Here's what the log says:
    Oct-19 9:24:15 AM Sonos CreateSonosControllers called but no devices found
    Oct-19 9:27:02 AM Sonos ReadIniFile called
    Oct-19 9:27:02 AM Sonos INIT: MaxNbrOfUPNPObjects set to 999
    Oct-19 9:27:02 AM Sonos DeleteIniSection called with section = TTSSpeakDevice and file = Sonos.ini
    Oct-19 9:27:51 AM Insteon Thermostat Foyer turning off HEAT after 13 minutes.
    Oct-19 9:29:13 AM Sonos PostBackProc for SonosControl called with page = SonosConfig and data = &id=RediscoverPlayersBtn&RediscoverPlayersBtn=Submit and user = default and userRights = 6
    Oct-19 9:29:13 AM Sonos postBackProc for SonosControl found Key = id
    Oct-19 9:29:13 AM Sonos postBackProc for SonosControl found Value = RediscoverPlayersBtn
    Oct-19 9:29:13 AM Sonos postBackProc for SonosControl found Key = RediscoverPlayersBtn
    Oct-19 9:29:13 AM Sonos postBackProc for SonosControl found Value = Submit
    Oct-19 9:29:13 AM Sonos DoRediscover called
    Oct-19 9:29:13 AM Sonos FindZonePlayers: Attempting to locate all connected ZonePlayers. This may take up to 9 seconds.
    Oct-19 9:29:15 AM Sonos DoRediscover called
    Oct-19 9:29:15 AM Sonos FindZonePlayers: Attempting to locate all connected ZonePlayers. This may take up to 9 seconds.
    Oct-19 9:29:24 AM Sonos FindZonePlayers - Discovery succeeded: 0 ZonePlayer(s) found.
    Oct-19 9:29:24 AM Sonos Warning No Zone Players found. Please ensure the network is functional and that ZonePlayer devices are attached.
    Oct-19 9:29:24 AM Sonos CreateSonosControllers called but no devices found
    Oct-19 9:29:24 AM Sonos ReadIniFile called
    Oct-19 9:29:24 AM Sonos INIT: MaxNbrOfUPNPObjects set to 999
    Oct-19 9:29:24 AM Sonos DeleteIniSection called with section = TTSSpeakDevice and file = Sonos.ini
    Oct-19 9:29:25 AM Sonos hspi.GetPagePlugin called for instance = and pageName = SonosConfig and user = default and userRights = 6 and queryString =
    Oct-19 9:29:25 AM Sonos GetPagePlugin for SonosControl called with pageName = SonosConfig and user = default and userRights = 6 and queryString =
    Thanks for your help.
    Originally posted by garwood View Post
    Hi Dirk,
    Could you describe the environment this runs on, starting with PI version, OS version. Did you give the PI proper allowance to get through the firewall? If in doubt, turn firewall off briefly and see if that makes a difference. Do note that in HS3, all PI run as separate executables and therefore need their own allowance/setting on the firewall.
    Dirk
      FIXED: The Wireless had not connected to my router. Players were instantly discovered when connecting the Wireless.
        Those pesky details
