What's this error all about? It's Greek to me.
~!~Error~!~Initializing plug-in(1): Kinect Instance:Livingroom:HSPI::InitIO: Failed to init: Exception: System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.Kinect, Version=1.7.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.File name: 'Microsoft.Kinect, Version=1.7.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' at HSPI_KINECT.KinectApp.Init() at HSPI_KINECT.HSPI.InitIO(String comPort)WRN: Assembly binding logging is turned OFF.To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.Note: There is some performance penalty associated with assembly bind failure logging.To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
