Having issues with .130. I did my normal update routine. Shut down BLSpeech, shut down BLRussound, kill the exe on the server then do the update on the plugin page. Once updated, restart BLRussound and then BLSpeech.
When I moved to .130 I followed the same routine but this time BLSpeech says I am on .130 but the plugin page says I am on .128 and .130 is there to update to.
First I checked options to make sure it was still on RNET since I have CAM6.6 and know it was added as an option. It is.
.130 reset some of my zone info. Normally I have the background to Green, the TurnOn Volume to 20, Balance = Center, Treble and Base = Flat and Loudness = On.
With .130 it removed the setting for the background and if you try to click on Green or Amber, it resets everything to zero (turnon, volume, balance, bass and treble).
I have reset all my settings for each zone except background color as it does not work anymore.
Michael
Michael
