Personally I would also like to see a log of say the last 10 times the lock was unlocked/locked and which code was used.
BLLock beta
Originally posted by gelessor View PostIt would be nice to know not only the last person to unlocked the lock, but also to date stamp the time that it occurred.
You can see all of the last locked/unlocked data in the activity log
I need you to do the following:
1. Shutdown HS
2. Edit hspi_BLLock.ini and change debugLevel=true and save the file
3. Restart HS
Once HS is started for a couple minutes go to the options web page in the plugin and turn off debug logging.
Then email me the BLLock-Detailed.log file from your HS root folder
You can get my email from my web site.
It would be great also if you could run the script in this thread and send me the output of that as well.
Here is the thread:
http://board.homeseer.com/showthread.php?t=147828
Actually, your email address I do not see, only form pages to fill out for a mailing list and etc. I sent you a PM so you can reply and I will see your email address.
Regarding the log file for your information script, it is the same content as the Kwikset deadbolts that mwaite posted in the other thread. Would it help for you to also see the device information file contents for this scene controller that is being mistaken as a lock?
It is now working for me. However, when I enter a code on the lock, it gets logged saying "User Code xxx Entered," where xxx is a number, and has nothing to do with the code I really entered, nor does it represent any user configured in the plugin. Even if I put my name in the user slots, it still just logs that code. Is this normal for now? I thought that until Homeseer adds some features, it would still correlate the user code entered to a username.
Edit:
OK, so I tried several different codes, and it is always the same pattern. If I enter a code for usercode 1 (according to the lock), then it logs "User Code 501 Entered." If I enter a code for usercode 2, it logs "502," and etc. Is there a way to use the plugin user list to convert these to friendly names?
Originally posted by Blade View PostDid you assign users to the lock?
What I did was to enter test users within the plugin, and then go try a lock code on the door. The plugin still logs a number, 501, 502, etc.
Was I supposed to enter something in the "User Code" box on the plugin? I understood that is unused right now.
That fixed that bug.
Something else I've noticed...
It would be good if it would check the real status of the lock upon Homeseer start. It always reports unlocked at first within the plugin, even if it is really locked. It's not until you do something with the lock that the plugin is in sync with reality.
I will check it when I get home.
ThxLast edited by Blade; March 24, 2011, 06:04 PM.
