Was looking at this as a possible HVAC interface for the Homeseer, trying to get some z-wave points into an alternate front end, but am having issues, wondering if anyone has suggestions.
Using Modbus over IP, have a slave set up with holding and input registers at 30001-10 and 40001-10.
Set up the Modbus device, tested connectivity, and put in all the registers as input to start. Kept getting "Error in Read: Write failure" followed by a "Read Error For..." for all 8 points I set up.
At one point in time they DID update. I have valid values. However, they won't continue to update.
I tried setting them to the holding registers instead, no luck. Set the holding registers to NOT be read only (allow writes), and the points updated once than stopped.
Looking at logs, looks like the socket continues to get dropped? This looks like an error between the plugin and Homeseer or Homeseer and Linux... not sure where the socket gets initiated, but seems to be that it's never really opened? Or dies to quickly?
Any help would be appreciated. Output from the log:
INFO|HSPI_MODBUS.WebConfig.postBackProc |Enabling logging to file: /usr/local/HomeSeer\Logs\HSPI_MODBUS._log
2016-11-01 08:56:51.7379| DEBUG|HSPI_MODBUS.Gateway.OnTimedEvent |Polling Modbus IP Gateway. Reading 8 registers from slaves
2016-11-01 08:56:51.7444| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 1 HoldingRegister:Int16
2016-11-01 08:56:51.7509| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
System.IO.IOException: Write failure ---> System.Net.Sockets.SocketException: The socket has been shut down
at System.Net.Sockets.Socket.Send (System.Byte[] buf, Int32 offset, Int32 size, SocketFlags flags) [0x00000] in <filename unknown>:0
at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0
--- End of inner exception stack trace ---
at Modbus.IO.TcpClientAdapter.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0
at Modbus.IO.ModbusIpTransport.Write (IModbusMessage message) [0x00000] in <filename unknown>:0
at Modbus.IO.ModbusTransport.UnicastMessage[ReadHoldingInputRegistersResponse] (IModbusMessage message) [0x00000] in <filename unknown>:0
2016-11-01 08:56:51.7714| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Domestic Hot Water
2016-11-01 08:56:51.7771| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 2 HoldingRegister:Int16
2016-11-01 08:56:51.7835| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:56:51.7897| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Domestic Cold Water
2016-11-01 08:56:51.7952| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 3 HoldingRegister:Int16
2016-11-01 08:56:51.8016| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:56:51.8075| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Furnace Supply
2016-11-01 08:56:51.8132| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 4 HoldingRegister:Int16
2016-11-01 08:56:51.8198| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:56:51.8259| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Furnace Return
2016-11-01 08:56:51.8316| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 5 HoldingRegister:Int16
2016-11-01 08:56:51.8380| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:56:51.8442| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Basement Temperature
2016-11-01 08:56:51.8501| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 6 HoldingRegister:Int16
2016-11-01 08:56:51.8566| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:56:51.8627| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Garage Luminance
2016-11-01 08:56:51.8682| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 7 HoldingRegister:Int16
2016-11-01 08:56:51.8749| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:56:51.8810| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Garage Temperature
2016-11-01 08:56:51.8865| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 8 HoldingRegister:Int16
2016-11-01 08:56:51.8929| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:56:51.8992| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Freezer Temp
2016-11-01 08:57:51.7380| DEBUG|HSPI_MODBUS.Gateway.OnTimedEvent |Polling Modbus IP Gateway. Reading 8 registers from slaves
2016-11-01 08:57:51.7463| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 1 HoldingRegister:Int16
2016-11-01 08:57:51.7551| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:57:51.7634| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Domestic Hot Water
2016-11-01 08:57:51.7712| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 2 HoldingRegister:Int16
2016-11-01 08:57:51.7801| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:57:51.7886| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Domestic Cold Water
2016-11-01 08:57:51.7965| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 3 HoldingRegister:Int16
2016-11-01 08:57:51.8054| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:57:51.8139| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Furnace Supply
2016-11-01 08:57:51.8217| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 4 HoldingRegister:Int16
2016-11-01 08:57:51.8307| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:57:51.8392| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Furnace Return
2016-11-01 08:57:51.8471| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 5 HoldingRegister:Int16
2016-11-01 08:57:51.8551| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:57:51.8614| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Basement Temperature
2016-11-01 08:57:51.8672| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 6 HoldingRegister:Int16
2016-11-01 08:57:51.8740| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:57:51.8802| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Garage Luminance
2016-11-01 08:57:51.8862| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 7 HoldingRegister:Int16
2016-11-01 08:57:51.8928| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:57:51.8992| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Garage Temperature
2016-11-01 08:57:51.9052| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 8 HoldingRegister:Int16
2016-11-01 08:57:51.9119| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:57:51.9181| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Freezer Temp
2016-11-01 08:58:06.2172| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 08:58:06.2697| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 08:58:06.3053| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:06.3528| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:06.3996| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:06.4415| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:06.4824| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:06.5240| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:06.5654| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:06.6047| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:15.1688| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 08:58:15.2100| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 08:58:15.2425| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:15.2768| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:15.3193| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:15.3621| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:15.4178| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:15.4592| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:15.5005| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:15.5419| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:45.8846| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 08:58:45.9267| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 08:58:45.9598| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:45.9958| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:46.0308| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:46.0698| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:46.1079| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:46.1534| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:46.1947| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:46.2363| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:51.7381| DEBUG|HSPI_MODBUS.Gateway.OnTimedEvent |Polling Modbus IP Gateway. Reading 8 registers from slaves
2016-11-01 08:58:51.7525| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 1 HoldingRegister:Int16
2016-11-01 08:58:51.7603| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:58:51.7662| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Domestic Hot Water
2016-11-01 08:58:51.7720| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 2 HoldingRegister:Int16
2016-11-01 08:58:51.7784| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:58:51.7844| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Domestic Cold Water
2016-11-01 08:58:51.7900| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 3 HoldingRegister:Int16
2016-11-01 08:58:51.7964| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:58:51.8031| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Furnace Supply
2016-11-01 08:58:51.8087| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 4 HoldingRegister:Int16
2016-11-01 08:58:51.8152| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:58:51.8213| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Furnace Return
2016-11-01 08:58:51.8267| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 5 HoldingRegister:Int16
2016-11-01 08:58:51.8333| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:58:51.8394| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Basement Temperature
2016-11-01 08:58:51.8449| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 6 HoldingRegister:Int16
2016-11-01 08:58:51.8515| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:58:51.8576| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Garage Luminance
2016-11-01 08:58:51.8634| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 7 HoldingRegister:Int16
2016-11-01 08:58:51.8697| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:58:51.8758| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Garage Temperature
2016-11-01 08:58:51.8815| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 8 HoldingRegister:Int16
2016-11-01 08:58:51.8879| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:58:51.8939| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Freezer Temp
2016-11-01 08:58:52.1971| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 08:58:52.2393| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 08:58:52.2725| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:52.3050| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:52.3376| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:52.3726| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:52.4108| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:52.4486| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:52.4867| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:52.5246| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:57.8125| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 08:58:57.8535| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 08:58:57.8859| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:57.9190| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:57.9572| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:58.0027| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:58.0481| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:58.0870| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:58.1246| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:58:58.1625| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:03.4634| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 08:59:03.5077| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 08:59:03.5406| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:03.5730| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:03.6109| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:03.6439| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:03.6761| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:03.7083| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:03.7461| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:03.7849| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:10.1827| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 08:59:10.2237| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 08:59:10.2563| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:10.2894| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:10.3220| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:10.3551| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:10.3878| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:10.4207| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:10.4533| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:10.4920| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:21.1937| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 08:59:21.2527| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 08:59:21.2859| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:21.3193| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:21.3526| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:21.3855| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:21.4183| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:21.4515| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:21.4842| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:21.5170| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 08:59:51.7382| DEBUG|HSPI_MODBUS.Gateway.OnTimedEvent |Polling Modbus IP Gateway. Reading 8 registers from slaves
2016-11-01 08:59:51.7513| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 1 HoldingRegister:Int16
2016-11-01 08:59:51.7649| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:59:51.7756| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Domestic Hot Water
2016-11-01 08:59:51.7854| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 2 HoldingRegister:Int16
2016-11-01 08:59:51.7944| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:59:51.8026| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Domestic Cold Water
2016-11-01 08:59:51.8108| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 3 HoldingRegister:Int16
2016-11-01 08:59:51.8200| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:59:51.8279| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Furnace Supply
2016-11-01 08:59:51.8378| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 4 HoldingRegister:Int16
2016-11-01 08:59:51.8508| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:59:51.8587| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Furnace Return
2016-11-01 08:59:51.8658| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 5 HoldingRegister:Int16
2016-11-01 08:59:51.8747| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:59:51.8808| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Basement Temperature
2016-11-01 08:59:51.8866| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 6 HoldingRegister:Int16
2016-11-01 08:59:51.8933| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:59:51.8991| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Garage Luminance
2016-11-01 08:59:51.9047| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 7 HoldingRegister:Int16
2016-11-01 08:59:51.9111| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:59:51.9172| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Garage Temperature
2016-11-01 08:59:51.9229| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 8 HoldingRegister:Int16
2016-11-01 08:59:51.9295| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 08:59:51.9363| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Freezer Temp
----------------- Logging finished on 2016-11-01 09:00:25.1638 -----------------
2016-11-01 09:06:06.0219| INFO|HSPI_MODBUS.WebConfig.postBackProc |Enabling logging to file: /usr/local/HomeSeer\Logs\HSPI_MODBUS._log
2016-11-01 09:06:16.3710| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 09:06:16.4135| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 09:06:16.4460| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:16.4785| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:16.5115| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:16.5504| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:16.5836| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:16.6165| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:16.6498| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:16.6831| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:27.7003| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 09:06:27.7551| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 09:06:27.7893| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:27.8232| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:27.8569| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:27.8913| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:27.9245| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:27.9663| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:28.0143| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:28.0580| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:38.0646| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 09:06:38.1098| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 09:06:38.1458| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:38.1846| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:38.2249| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:38.2585| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:38.2919| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:38.3252| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:38.3579| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:38.3911| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:49.3774| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 09:06:49.4199| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 09:06:49.4546| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:49.4885| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:49.5221| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:49.5556| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:49.5884| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:49.6226| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:49.6557| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:49.6926| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:06:51.7385| DEBUG|HSPI_MODBUS.Gateway.OnTimedEvent |Polling Modbus IP Gateway. Reading 8 registers from slaves
2016-11-01 09:06:51.7482| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 1 InputRegister:Int16
2016-11-01 09:06:51.7582| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 09:06:51.7645| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Domestic Hot Water
2016-11-01 09:06:51.7705| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 2 InputRegister:Int16
2016-11-01 09:06:51.7770| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 09:06:51.7834| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Domestic Cold Water
2016-11-01 09:06:51.7899| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 3 InputRegister:Int16
2016-11-01 09:06:51.7972| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 09:06:51.8039| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Furnace Supply
2016-11-01 09:06:51.8102| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 4 InputRegister:Int16
2016-11-01 09:06:51.8170| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 09:06:51.8286| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Furnace Return
2016-11-01 09:06:51.8350| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 5 HoldingRegister:Int16
2016-11-01 09:06:51.8420| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 09:06:51.8499| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Basement Temperature
2016-11-01 09:06:51.8557| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 6 HoldingRegister:Int16
2016-11-01 09:06:51.8622| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 09:06:51.8688| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Garage Luminance
2016-11-01 09:06:51.8748| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 7 HoldingRegister:Int16
2016-11-01 09:06:51.8818| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 09:06:51.8882| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Garage Temperature
2016-11-01 09:06:51.8943| DEBUG|HSPI_MODBUS.Gateway.Read |Reading Slave: 1 Address: 8 HoldingRegister:Int16
2016-11-01 09:06:51.9012| ERROR|HSPI_MODBUS.Gateway.Read |Error in Read: Write failure
2016-11-01 09:06:51.9120| ERROR|HSPI_MODBUS.Gateway.OnTimedEvent |Read error for Freezer Temp
2016-11-01 09:07:00.0823| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 09:07:00.1374| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 09:07:00.1714| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:00.2051| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:00.2406| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:00.2773| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:00.3103| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:00.3520| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:00.3852| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:00.4186| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:10.5847| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 09:07:10.6266| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 09:07:10.6604| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:10.6935| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:10.7263| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:10.7591| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:10.7922| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:10.8247| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:10.8576| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:10.8909| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:20.5343| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 09:07:20.5761| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 09:07:20.6342| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:20.6674| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:20.7006| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:20.7348| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:20.7675| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:20.8006| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:20.8460| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:20.8798| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:8:HoldingRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:30.4959| INFO|HSPI_MODBUS.plugin.PopulateRegisters |Populating register database for gateway [Modbus IP Gateway]
2016-11-01 09:07:30.5549| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Found 8 devices associated with this gateway.
2016-11-01 09:07:30.5886| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:1:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:30.6217| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:2:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:30.6546| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:3:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:30.6877| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:4:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:30.7209| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:5:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:30.7590| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:6:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:30.7919| DEBUG|HSPI_MODBUS.plugin.PopulateRegisters |Adding 1:7:InputRegister:Int16 to Modbus IP Gateway
2016-11-01 09:07:30.8248|
