Changes:
- the RFX message processing to account for an invalid bit in the message
Fixes:
- the Vista Alarm config sections on the device edit page
- saving changes on the Loop and Partition options
To Install:
1. Shutdown HS3
2. Extract the zip contents to the Homeseer 3 folder.
The contents should end up in their respective folders. HSPI_VistaAlarm.exe and FTD2XX.dll in the homeseer 3 folder, and everything else in the proper html subfolder based on the Path in the zip folder.
4. Restart HS3 and goto to the Manage Plugin page
5. Enable the plugin and set the Com Port to your AD2USB port
6. Restart HS3 again if necessary
7. You will need to enable the Monitor (device address Vista 1) to get things rolling.
Setup:
1. Once the plugin is running it will create 6 new devices. You can always delete them and restart HS3 to have them recreated.
2. Configure your Partitions as before. You need to know the panel address typically 16 for a 20p. Check your panel programming if you are unsure.
3. Add your zones and RF devices as necessary
4. Test and report back to this thread
If you enabled Developer Mode on the Plugin Manage page, you will get a command window that will display the AD2USB messages. this might help with debugging or at least let you know the plugin is seeing panel msgs.
Fixes:
To Install:
1. Shutdown HS3
Setup:
