Originally posted by jeubanks
View Post
Coming Soon: Life360 Plugin
Originally posted by cowinger View PostI thought I had your name right the first time then I saw that blank plugin and the name was different. John, I will go look for your plugin.
Doesn't look like it's "live" in the actual store yet for purchase....
I seem to have maybe found a bug. Below is the AWAY setting for my wifes phone and you will see its set to 0 = Away but the location is Home.
Mine below, is currently away and is set the same. This is causing all kinds of issues has it is detecting she is away while at home and running my away routines.
Any ideas?
Originally posted by mbg0333 View PostI seem to have maybe found a bug. Below is the AWAY setting for my wifes phone and you will see its set to 0 = Away but the location is Home.
Any ideas?
When migrating from the previous test versions to the more recent did you do a full install? (DELETE devices) so they are recreated with new managed devices?
There was a major change in Places/Locations/Devices that did require a full Delete of devices and a recreate for the function to work. Moving forward a full device delete should not be needed anymore.
John, I noticed this error in my log this morning. Not aware of any issues with functionality, just reporting it for your info.
Jun-23 7:45:13 AM
Life360 ERROR
Updating Places before device update Failed.Newtonsoft.Json.JsonReaderException: Error reading JObject from JsonReader. Path '', line 0, position 0. at Newtonsoft.Json.Linq.JObject.Load(JsonReader reader, JsonLoadSettings settings) at Newtonsoft.Json.Linq.JObject.Parse(String json, JsonLoadSettings settings) at HSPI_Life360.Life360.GetCircles(String BearerToken) at HSPI_Life360.CurrentPlugin.BuildPlacesDictionary() at HSPI_Life360.CurrentPlugin.UpdateLife360Devices(Object obj)-Wade
Originally posted by cc4005 View PostJohn, I noticed this error in my log this morning. Not aware of any issues with functionality, just reporting it for your info.
Jun-23 7:45:13 AM
Life360 ERROR
What version are you running? That will tell me if the change I put in to try and address this worked or not.
Same device name issue
I'm happy to see that life 360 is in homeseer. Been using life360 for years and it's a great app.
One thing I notice was if you have two people with the same name it won't update on homeseer. My exmple is that my son and my self have the same first name. So the plug in picks it up and can't tell the difference. I guessing. So what I did was change my name on the life360 website. To dad as my first name and everything is working good now.
Originally posted by gsegovia15 View PostI'm happy to see that life 360 is in homeseer. Been using life360 for years and it's a great app.
Getting the following errors. Not sure why, I have not changed anything.
Removal of Places from HS3 Failed Newtonsoft.Json.JsonReaderException: Error reading JObject from JsonReader. Path '', line 0, position 0. at Newtonsoft.Json.Linq.JObject.Load(JsonReader reader, JsonLoadSettings settings) at Newtonsoft.Json.Linq.JObject.Parse(String json, JsonLoadSettings settings) at HSPI_Life360.Life360.GetToken(String Username, String Password) at HSPI_Life360.CurrentPlugin.RemoveLife360Place() at HSPI_Life360.CurrentPlugin.BuildPlacesDictionary()
Devices Not UpdatedNewtonsoft.Json.JsonReaderException: Error reading JObject from JsonReader. Path '', line 0, position 0. at Newtonsoft.Json.Linq.JObject.Load(JsonReader reader, JsonLoadSettings settings) at Newtonsoft.Json.Linq.JObject.Parse(String json, JsonLoadSettings settings) at HSPI_Life360.Life360.GetToken(String Username, String Password) at HSPI_Life360.CurrentPlugin.UpdateLife360Devices(Object obj)
