Originally posted by jon00
View Post
Jon00 Philips Hue Wi-Fi Lamp Controller for Homeseer 3 & Homeseer 4
Guest
Jon00,
still having issues on a freshly installed win7 SP1 32 bit. when i check the evenviewer it states:
Code:System - Provider [ Name] Application Error - EventID 1000 [ Qualifiers] 0 Level 2 Task 100 Keywords 0x80000000000000 - TimeCreated [ SystemTime] 2013-11-20T20:41:18.000000000Z EventRecordID 2453 Channel Application Computer HomeseerServer Security - EventData Jon00PhilipsHueHS3.exe 1.0.0.0 520f1bd5 clr.dll 4.0.30319.1008 517a1be7 c0000005 0006c6cc 40c 01cee630dbb3fde0 C:\Jon00PhilipsHueHS3\Jon00PhilipsHueHS3.exe C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll 1aee0e60-5224-11e3-8122-485b397ebbad
Code:- System - Provider [ Name] .NET Runtime - EventID 1023 [ Qualifiers] 0 Level 2 Task 0 Keywords 0x80000000000000 - TimeCreated [ SystemTime] 2013-11-20T20:41:17.000000000Z EventRecordID 2452 Channel Application Computer HomeseerServer Security - EventData Toepassing: Jon00PhilipsHueHS3.exe Framework-versie: v4.0.30319 Beschrijving: het proces is beëindigd als gevolg van een interne fout in de .NET-runtime op IP 66C2C6CC (66BC0000) met afsluitcode 80131506.
(sorry its in dutch)
after searching the web i found somestatements regarding applications for multi CPU platforms (32bit and 64) hope his helps and you can help me.
P.S. also installed in a win7 64bit Vm which worked fine.
Thanks in advance
Bart BakelsRegards Bart
Win7 64Bit on Intel NUCI7 with SSD
HSPRO 3.
Devices; 1370 Events; 691
Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
Multiple Bridges
Does the plugin support multiple bridges to expand past the 50 light limitation of the one?
Philip
pabbott@cpak.com
Originally posted by pabbott@cpak.com View PostDoes the plugin support multiple bridges to expand past the 50 light limitation of the one?
Philip
pabbott@cpak.com
Excellent plugin! Thanks!
It has been a couple of years since I've done any homeseer scripting so I'm real rusty. This may be a simple question - Is there a way to read the values of a particular setting using getvar? I'm trying to retrieve and subsequently store the "PLast" value. My intent is to use a hue iphone app to set colors like I want, then run a script to grab the value and store it as a string in a virtual device for later recall.
Thanks for any help!
You can read the PLast value (and other values) from the Jon00PhilipsHue.ini file
The command would be:
Dim PLast As String
PLast= hs.GetINISetting("Presets", "PLast", "", "Jon00PhilipsHue.ini")
Jon,
Does your plugin support the new Philips Hue Strip Lighting that just came out?
Thanks,-Todd
____________________________________________________________ ________________
HS2Pro: 2.5.0.81 :: HS3Pro (beta) || Plugins:| SmartHome PowerLinc USB, Global Cache, BLBackup, DooCPU Monitor, DooMotion, BLOutlook, BLIcon, BLOutgoingCalls, OutgoingCalls, ROC-Rnd, HSTouch iPhone, UPS Monitor, DooMenuBar, BLSpeech, HSTouch Server, WAF AB8SS, mcsTemperature, VWS, BLChart, RFXCOM, ISY Insteon, iAutomate RFID, iTunes, NetCAM, DSC Security, Nest
Originally posted by jon00 View PostI don't own any but as they are just registered as another Hue lamp on the bridge, I would say Yes!
Off to the Apple Store!
-Todd
jon00,
thanks for the HUe HS3 plugin, However i have a question, Is er way to speedup the execution of hue actions. After executing an command it takes between 3 to 10 seconds before it executes. I think this is the checking interval of the client?
The reason that i ask this is that i trigger hues on movement,and would be preferable to have an instant control possibility?
thanks in advance.
BartRegards Bart
HSPRO 3.
