Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > CFGuy Plug-Ins/Scripts > WeatherXML
WeatherXML Discussion area for WeatherXML
Closed Thread
  #41
Old February 23rd, 2016, 09:01 AM
CFGuy's Avatar
CFGuy CFGuy is online now
Have A Blessed Day
3.0.0.42
Devices:
* Added Solar Radiation to HSTouch devices.
* Fixed error when the HSTouch Moon Phase information items were not selected
Alert Triggers
* Fixed error that caused alert triggers to not load when the first trigger was deleted. This would happen when the plugin was restarted.
* Fixed error that under certain conditions a new trigger could not be added.
* When testing a trigger the selected script will now run as part of the test.
Web Pages
* Added Humidity and Quanitative Precipitation Forecast to the Hourly Forecast web page
XML Output
* Fixed XML output to correctly add the HS IP to the condition Icon URL
Jeff Farmer
HS 3.0.0.312, HSPhone
Other Plugins In Use: APCUPSD, EasyTrigger, FBitSeer, HSTouch Server, Kinect, PHLocation, Pushover, RFXCom, UltraGCIR3, UltraMon3, UltraPioneerAVR3, X10, Z-Wave
Hardware: GoControl Irrigation Controler, Schlage Lever Lock, Schlage Deadbolt, Way2Call Hi-Phone, RFXCom RFXrec433 Receiver, WGL 800, TI-103, Z-Net, Pioneer 1120, Pioneer 1021, Panasonic BDT-110, Panasonic BDT-210 x2
  #42
Old March 1st, 2016, 09:48 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.43
Maps
* Fixed the problem with downloading the animated radar map from Weather Underground.
  #43
Old March 10th, 2016, 07:51 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.44
* Speak Devices - New Feature. If you are not using Speak Items a new device will be created that is the parent device for Speak Devices.
If you are using Speak Items you will have a new device created for each Speak Item.
The old Speak Items will continue to work to give everyone time to learn the new devices. Most likely as you get used to the logic of the new devices you will be able to get by with less Speak Devices than you had Speak Items.
The file weatherXMLSpeakDevices.pdf is in the HomeSeer HS3\html\weatherXML\ directory. It explains how the logic and the setup works.
  #44
Old March 20th, 2016, 08:23 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.45
XML Output
* XML file output now uses the Speak Device text. This is selected on the Location setup.
Location Setup
* Change Location Speak Item to Speak Device Dropdown
* On the locations page, the selection of an Event to run after the import is now a dropdown instead of a textbox
Speak Items
* Fix the date to speak as Month day, year and not MM/DD/YYYY
* Split updated variable to updated date and updated time
* Add Todays High Time and Todays Low Time to Speak Variables
Email Action
* Event Action Send Email does not convert the date days to letters instead of numbers
Alert Triggers
* Fixed a bug that didn't allow editing trigger #1
* Fixed bug that would not match the first word in the alert title or text.
Documentation
* Started an update of all weatherXML documentation. Each Admin page will have a link at the top of the page to a PDF file for options and Settings.
4 Sections are done so far.
1. Quick Start
2. Settings - Settings and Web pages
3. Locations - Locations and Units pages
4. Speak Devices - Setup and Logic for Speak Devices
HSPhone
* HSPhone can not be used by plugins. To get around this, in the VR Control by Phone, a script is now called. The text to be spoken is sent to the script named weatherXML_HSPhone.vb. The script is not over written during the install of future versions of weatherXML so you can modify the script as you want.
Linux
* The correct dll for SQLite is now being installed in HS3 Linux. On the database page select SQLite for the database. You can then have weatherXML start saving the weather data to the database.
  #45
Old March 21st, 2016, 07:54 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.46
Trigger Alerts
* Fixed issue that caused the wav File to not always play. This allows the wav file to be anywhere on the HomeSeer computer.
Linux Database
* On the Database tab there is a button to Create the SQLite Database or Modify it if new fields are missing.
  #46
Old April 10th, 2016, 08:03 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.47
Speak Devices
* Added an option to select a wav or mp3 file to play before the speaking.
Devices
* The Misc Group Parent Device has some options on the weatherXML tab. Select to setup a Spoken Log Device. You can keep a log of the last 5, 10 or 25 things that weatherXML speaks.
* Fixed the pathway for the device image.
  #47
Old April 11th, 2016, 12:52 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.48
Documentation
* Added a new pdf to document the Schedules page.
  #48
Old April 12th, 2016, 09:39 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.49
Devices
* Fixed Humidity Prepend for HSTouch Devices
Plugin
* Removed the Speak on Startup option
* Fixed proper Version Number
Documentation
* Added Documentation for Misc Devices and new Last Spoke Log Device
  #49
Old April 27th, 2016, 09:12 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.50
XML Output
* Fixed error that was looking at the wrong ini setting for the port number that HS3 is using.
  #50
Old August 15th, 2016, 08:38 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.51
weatherXML Event Triggers
* Added Equals to weatherXML Condition events
Replacement Speak variables
* Added test mode to the alert replacement variables function (replaceVariablesAlert)
* Add Sunrise and Sunset to speak device variables
Devices
* The HSTouch Moon Phase was not setting the device string.
Database
* Added database table to save the daily access totals by provider.
  #51
Old September 5th, 2016, 11:33 AM
CFGuy's Avatar
Have A Blessed Day
3.0.52
Devices
* Fixed bug that was not setting the Solar Radiation device
Debug
* Fixed log output to not put the API in the logged URL
Speak Devices
* Added code for the forecast day and night condition text to use the Custom condition text.
* Fixed error with loading the custom condition values
* Fixed bug where the selected speak device's text was not getting set during the locations conditions schedule run
* Added code to select a speak device for the forecast info as well as the condition info.
* Added condition speak device text to the output xml file. Key: current/conditionString Existing forecast/speakString xml key is still in the xml file.
* Added forecast speak device text and condition speak device text to the output xml file. forecast/forecastString
Plugin Integration
* PHLocation is now available for more than one location
Location Setup
* Added Section headers on the Locations page to make each stand out more.
* Moved PHLocation Setup to locations page to allow any location to be a follow me.
  #52
Old September 5th, 2016, 12:30 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.53
Plugin Integration
* Changed PHLocation device dropdown to match on plugins interface instead of the editable Location 1.
Alerts
* Now removes the * from the alert text.
  #53
Old September 6th, 2016, 10:38 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.54
Locations
* Fixed an error where the selected Forecast Device was not being saved correctly.
* Fixed a bug where the xml output file variables were not getting set on plugin startup.
HS Events
* Add HS event action to turn off individual downloads instead of just all downloads.
* Add HS event action to turn on individual downloads instead of just all downloads.
Speak Devices
* Added a variable to allow adding a delay in the Speak Devices. From 1 to 19 Seconds.
  #54
Old September 15th, 2016, 02:17 AM
CFGuy's Avatar
Have A Blessed Day
3.0.0.55
Speak Devices
* Added a play after media file to speak devices. You can now play a wav or mp3 both before and after the speaking.
Alert Triggers
Plugin Integration
* Modified the code to look at the PHLocation device value as well as the string when finding the Latitude, Longitude and Location City.
  #55
Old October 2nd, 2016, 04:01 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.56
* Location Setup
A new option added to allow you to have weatherXML use the Station ID only for Current Conditions. All the other data (Forecast, Daily, and Hourly) will use the Latitude and Longitude. To set this option, select a Station in the Station ID dropdown. The checkbox will be displayed below the Station ID dropdown.
  #56
Old December 14th, 2016, 09:32 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.57
* Download xml files
Added feature to select any of the schedules to save a backup of the xml file that is downloaded. Save directory is data\weatherXML\backup
Go to the Schedules page and click the checkbox labeled Save Backup.
* Location Updates
Fixed the forecast text update to not update with a blank string. Builds a default forecast string with the temp, wind and precipatation values.
Fixed the import for Weather Underground to look for the error message when the xml download times out.
Added Count total for WU download errors in the xml file.
* Speak Devices
Added a speak device variable for the PHLocation City from the Follow Me feature.
Fixed an error where the Speak Devices Move Up/Move Down buttons were not displaying correctly.
* NOAA Alerts
Added more options to the Alert Triggers.
Alert Name Contains
Alert Name Not Contains
Alert Title Contains
Alert Title Not Contains
Alert Summary Contains
Alert Summary Not Contains
  #57
Old December 25th, 2016, 06:40 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.58
Devices
* Fixed bug that was not following the setting for rounding the current rain totals. Rain Last Hour and Rain Today.
  #58
Old December 27th, 2016, 12:42 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.59
Fixed error with the rounding of the rain values.
  #59
Old January 10th, 2017, 05:23 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.60
* Download XML Files
Fixed the download to not continue with the import when the xml file did not download correctly.
  #60
Old January 12th, 2017, 01:15 AM
CFGuy's Avatar
Have A Blessed Day
3.0.0.61
* Images
Fixed error with downloading a Google image when the submitted data has a comma in the numbers.
Closed Thread
HTML code is On
Movie Manager Release / Bug Fix Info CFGuy Movie Management 0 March 9th, 2012 08:27 PM
Release Info/Bug fixes weatherXML for HS2 CFGuy WeatherXML 0 November 5th, 2011 07:34 PM
3.2.0.0 Release Info JustinGould WapSeer (3P) 12 November 6th, 2010 02:36 PM
Info needed on inline modules - EON3 site light on for info Moby58 Australasia 4 November 1st, 2004 02:29 AM
