Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > CFGuy Plug-Ins/Scripts > WeatherXML
WeatherXML Discussion area for WeatherXML
Closed Thread
  #61
Old February 1st, 2017, 11:54 PM
CFGuy's Avatar
CFGuy CFGuy is online now
Have A Blessed Day
3.0.0.63
Random integration
* IMPORTANT NOTE.
If you are using both weatherXML and Random plugins.
weatherXML had a public function that was the same name as one of HS3's functions. I have renamed the function. Random was using that function to get a list of available weatherXML variables so you must update both. Random 3.0.0.0 goes with weatherXML 3.0.0.63
Images
* Added code to not allow setting a replacement image for the curcond images
Installation
* Modified the install to put the dll files in the bin directory instead of the Bin directory. The install now matches the HS3 SDK on which directory is correct.
Admin Pages
* Removed the Speak Items page. The old style of speak Items no longer work. All speaking is now handled via the speak devices.
Misc Maps
* Added a warning if the size of the images exceeds the allowed maximums.
Devices
* Added Status Value graphics to the HSTouch Barometer Direction device. Uses new png versions of the direction images.
* Added Status Value graphics to the HSTouch Wind Direction devices. Uses new png versions of the direction images.
Jeff Farmer
HS 3.0.0.312, HSPhone
Other Plugins In Use: APCUPSD, EasyTrigger, FBitSeer, HSTouch Server, Kinect, PHLocation, Pushover, RFXCom, UltraGCIR3, UltraMon3, UltraPioneerAVR3, X10, Z-Wave
Hardware: GoControl Irrigation Controler, Schlage Lever Lock, Schlage Deadbolt, Way2Call Hi-Phone, RFXCom RFXrec433 Receiver, WGL 800, TI-103, Z-Net, Pioneer 1120, Pioneer 1021, Panasonic BDT-110, Panasonic BDT-210 x2
  #62
Old June 15th, 2017, 09:01 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.64 (Beta Release)
* Added a setting to control how many of the backup files to keep. Oldest ones are deleted as new ones are saved.
* Fixed a bug with the download backup that was saving the wrong file for the Alerts backup.
* The map rotation device option is now hidden until at least one map has been setup.
* Added setting to allow selecting which locations will create Global Variables.
* Now tracks the device refIDs based on actual devices instead of storing the refID in an ini file.
* Added the ability to set an image width or height for display on the weatherXML users Map page.
* Added the ability to resize a downloaded Map image
* Fixed the Event device references to work correctly
* Fixed the PHLocation dropdowns to use the Location 1 first setting.
  #63
Old June 15th, 2017, 09:02 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.68 (Beta release)
* More changes to the functions for standardizing the device addresses.
* Fixed an issue with the image rotator device that would not display the dual image from NOAA correctly.
  #64
Old June 15th, 2017, 09:03 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.69 (Beta Release)
Fixed Map Rotation device to use the new name format for Radar image.
Fixed bug where the Map Rotation device was not incrementing correctly
  #65
Old June 15th, 2017, 09:04 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.70
* Releasing Beta version 3.0.0.69 as Release version 3.0.0.70
  #66
Old July 21st, 2017, 07:32 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.71
Maps
* Radar is now saved as Radar_1.gif and a second copy with the date in the name to prevent caching in HSTouch.
Location Page
* The Database link on the schedule page no longer shows when no location is set to use an Access database.
* Add a time format dropdown to the location setup
Tide Information
* Added Tide Information devices. Setup is on the HSTouch tab but can be used anywhere that you want to display the information.
* Tide information is no longer stored in an ini file. It is stored in the device plugin extra data.
Misc Devices
* The Last Spoken Log device now has a weatherXML tab that displays all of the current log entries
  #67
Old July 21st, 2017, 07:34 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.72
* Fixed an error that was not downloading the radar image unless you setup both the normal and non cache name.
* Fixed an error when switching from Cumulus File to a different provider the Scheduled does not change from File Watch
* Alert global variables are now set before the alert trigger
* Added code to add the Moon Phase Status Graphics and the Wind Direction Status Graphics
  #68
Old July 21st, 2017, 07:36 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.73
* Removed code that produces the weatherXML javascripts that are in the html/weatherXML directory. These were left over from HS2 and do not work with HS3.
* Fixed issue where the documentation pdfs were not loading.
* Humidity Device is now updating.
* Fixed error causing some of the maps to not build the Device Status Graphics correctly.
  #69
Old October 11th, 2017, 09:26 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.74
* No longer using an ini file for maps.
* The Map Schedule is set by location, instead of just one schedule does all locations.
* The Map Group parent device now has buttons to add a new map and to Update Group Maps.
* The forecast devices now replace the wind direction abbreviations with the full spelled out text. Ex SW - South west
* The Map Group parent device has a setting to control which directory the maps are downloaded to. The directory must be under the images\weatherXML directory.
* Added the ability to sort the order of the maps on the user map page.
* No more confusing Download and Device checkboxes. All maps are now devices. The download is controlled by the entered URL.
* Added Logging Level to Event Actions. You can now set Event actions to set logging level to Debugging, Do a download and import, set logging level back to Errors.
* Temperature devices in the HSTouch Daily Group now create a Status Graphic for each 10 degree range from -100 to 100 giving the ability to use the Satus graphic in HSTouch and have the thermometer icon change to match the temperature.
  #70
Old October 11th, 2017, 09:27 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.75
* New Script to import maps that were missed due to a setting value missing or a map not set to use a device.
  #71
CFGuy's Avatar
Have A Blessed Day
3.0.0.76
* Beta release of the alpha changes for .74 and .75
  #72
Old October 11th, 2017, 09:28 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.76
* Release version of the changes for .74 and .75
  #73
Old February 20th, 2018, 05:15 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.77
* Added option to select the number of places to round the UV total.
* Added to forecast: Precipitation Day Forecast, Night Forecast, and Total Day + Night Forecast available in inches or millimeter.
* Added Historical data: Rain totals for any of the past 7 days. Accumulated Rain Totals for past 7 days.
* Setup for the new precipitation devices is on the HSTouch\ Data Values Devices admin page.
  #74
CFGuy's Avatar
Have A Blessed Day
3.0.0.78
* New Event Action: Update Specific Map - This allows you to update a specific map more often then updating every map in a location.
  #75
Old February 20th, 2018, 05:16 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.79
* Fixed an error that caused the support page to not always load.
  #76
Old February 20th, 2018, 05:17 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.80
* Extra logging to debug an error.
  #77
Old February 20th, 2018, 05:18 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.81
* Added extra logging to figure out what was causing the PHLocation Lat and Lon to be changed to an integer.
  #78
Old February 20th, 2018, 05:20 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.82
* Fixed error that was rounding to an Integer, the imported values from PHLocations Lat and Lon devices.
  #79
Old May 30th, 2018, 08:57 AM
CFGuy's Avatar
Have A Blessed Day
3.0.0.86
* Alert Conditions in events will trim the spaces on start and end of a condition.
* Added CURL as an option for Windows XP users using NOAA. Used for Alerts and Forecasts.
* Added Date Check for WU forecast to not import a forecast with a non current date. (WU Users)
  #80
Old May 30th, 2018, 12:38 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.87
* Fixed error where the "Use CURL" option was not saving the setting. (Only needed for those using Windows XP to run HomeSeer.)
* Fixed error: importForecastHourly: Input string was not in a correct format.
Closed Thread
HTML code is On
Movie Manager Release / Bug Fix Info CFGuy Movie Management 0 March 9th, 2012 08:27 PM
Release Info/Bug fixes weatherXML for HS2 CFGuy WeatherXML 0 November 5th, 2011 07:34 PM
3.2.0.0 Release Info JustinGould WapSeer (3P) 12 November 6th, 2010 02:36 PM
Info needed on inline modules - EON3 site light on for info Moby58 Australasia 4 November 1st, 2004 02:29 AM
